Have DeskJet 952C but no manual. The light on the left with the X button keeps flashing. The ink cartridges don't feel like they are out of ink. Is this ink. Any suggestions?
    Sergeant:
    Champion:
  • 255 Answers
Carts are bad, or contacts where carts install on printer are bad, try to clean contacts on cart and printer, if no joy replace printer.
Posted on Sep 07, 2009
Testimonial: " Thanks, hadn't thought of that, will give it a shot. Many thanks. Could be yeo old printer is just ready to go to pasture, forever off. JRS "
Empty cartridge light keeps flashing
These cartridges don't have anything internally to check for new ink. They simply work on a basis of counting pages and page coverage to estimate ink levels. As such it is perfectly normal for your printer to warn of low ink once the cartridge has been refilled.
A low ink warning in itself should not stop your printer from printing though. If it does it is likely that the light is actually indicating a problem recognising the cartridge after refilling. I would recommend cleaning the copper contacts on the front of the cartridge and checking for any messages on the connected PC or laptop for more information.
Oct 16, 2012 | HP DeskJet F380 All-In-One Printer
I have an hp deskjet 940c. I don't know if this is the same model as deskjet inkjet. Anyway what light is on or off on the front when a new ink cartridge(s) is needed?
For the HP 940c, there is only one light to indicate a possible low ink cartridge. The LED above the cartridge symbol (the only one without a button) will flash. (Note: this LED is the second from the left.) When you see the error code, open the printer's top cover. If the error is a low ink issue, the LED will stop blinking.
With the cover open, the cartridge carrier will move until the yellow arrow lines up with an icon on the printer itself. These five icons are in order from left to right (as you look at the cartridges) : tri-color ink cartridge problem, black ink cartridge problem, tri-color ink low, black ink low and cartridges OK. If both cartridges are low, replace the one indicated by the arrow. Then the cartridge carrier will move to indicate the other cartridge is low. (If only one has a problem, after you replace it, the carrier will move to the cartridge OK symbol.)
If HP offers the full-feature software for your OS, then install the software. Use the HP Deskjet Toolbox to get exactly which cartridge needs to be replaced without needing to be ready to replace both (or to monitor your ink level (approximate ink level)).
The manual for the Deskjet 940c is available as a PDF from HP: http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=125&prodTypeId=18972&prodSeriesId=35985 .
I hope this helps.
Apr 11, 2011 | HP DeskJet 940c InkJet Printer
How do i clean my head on my hp deskjet 952c printer?
just full ink cartridge and wipe print head under it, this model not same with other model that the printer head separate with ink cartridge.
Mar 25, 2010 | HP DeskJet 952c InkJet Printer
WHAT DOES THE TOP TEAR DROP SHAPED BUTTON MEAN WHEN IT IS FLASHING ON A HP DESKJET 3820
The flashing teardrop light indicates your ink is about out.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 29, 2009 | HP DeskJet 3820 InkJet Printer
One of the two red lights below the X button is flashing. cant print. I need help
Some of ink cartridges is failed.If flashing left light replace color cartridge.If flashing right replace the black cartridge.
Nov 10, 2009 | HP DeskJet 9800 InkJet Printer
Ink is leaking from bottom of HP 952C printer. Cartridges will not move when top is opened. How do I clean it?
open the system and then slide the cartridges to the side like you are changing them, then clean them out
Jul 20, 2009 | HP DeskJet 952c InkJet Printer
Ink cartridge
This is the HP site for your 952c printer. Has most answers to your problems.
http://h10025.www1.hp.com/ewfrf/wc/product?product=60653&lc=en&cc=us&dlc=en&submit.y=8&submit.x=7&lang=en&cc=us
Dec 29, 2008 | HP DeskJet 952c InkJet Printer
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
How to remove the top of the 952c to get to the ink reservoir.
HP 952c = Deskjet Printer
Like ALL HP deskjets of this design:
Turn Printer ON (allow for test cycle), then lift top hinged panel.
Print cartridges will be parked in protected area to the right.
When top panel is lifted, they will move out for easy access.
They will NOT move out if printer is OFF.
So Please turn ON as first step.
Best to install new cartridges as opposed to cleaning.
If cleaning, utilize software option for clogged cartridges.
If they are leaking, replace them with new cartridges.
All this is available on HP web site.
Aug 04, 2008 | HP DeskJet 952c InkJet Printer
139 people viewed this question
k24674
