Question about GE DBXR463EDWW Electric Dryer
My Ge electric dryer, model dbxr463egww, will turn on and run for about 10 minutes and then kick off. We can immediately restart it, and it will run for another 10 minutes. Doesn't matter which heat setting or timing option we select. Already tried cleaning it out with a shop vac no success. Any suggestions? My husband thinks it is the cyling thermostat??
  • 3 Answers
SOURCE: ge dryer
i built these machines... before doing anything ...check your fuse box or breaker .... 240 v .... it goes out often ... if its not that ... its probably your element ... ...open your door and on the top of the opening ... there 2 screw ... take the top off then the front ... 2 other screws ...take out drum ...and check element ... its about 60 for a new one
Posted on Nov 30, 2007
SOURCE: GE Profile Electric Dryer, Blower nt getting up to speed
On all the ones I've seen with this problem, they've needed a new blower motor. Don't take that as the golden answer because even G.E. tech support doesn't know. It could be the control board, but I haven't seen that yet. G.E. always recommends replacing the inlet thermister, which is accessed through a little cover on the back. Good luck & welcome to the wonderful world of complex electronic appliances.
Posted on Jan 28, 2008
  • 71 Answers
SOURCE: GE Electric Dryers Automatic Cycle won't advance/turn off
check the vent probly cloged or vent hose kinked, or heater is broken.
Posted on Dec 21, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Profile Dryer - sensor problem
When I pull up the exploded view of your model, it does not show an individual moisture sensor, but is does show disconnect plug(s) for it. I can only assume that the sensor bars are an intrical part of one of the front bulkhead components. That all being said, the most common reason for your symptoms is when people use fabric softener sheets in the dryer, the sheets leave a waxy type coating on the silver sensor bars inside the drum, near the air inlet to the lint filter. If you clean those two (usually about 4 inch long x about 1/4 inch wide) metal bars off, they will be able to detect the moisture level of the clothing again, and your dryer will work on auto dry again.
Posted on Jan 24, 2009
TheMobilian
  • 8220 Answers
SOURCE: GE Select clothes dryer model DSXR453EVOWW
Open the door and remove the screws holding down the top. Then raise the top and you can get to the screws holding the front on. Get the front out and then the drum can come out so you can clean that guy out and replace that belt. How about some repair PHOTOS?
Posted on Sep 12, 2009
Ge dbxr463gd1ww stops before cycle ends
Sounds like a safety or limit switch cutting it out, if you wait 2 minutes and it restarts then repeats.
Aug 27, 2013 | GE Dryers
Dryer starts but will not continue to run
Check two things:
The area under the drier, the front panel there comes off.
1.There is a problem with lint, dust etc in the intake or a bad thermostat.
2. The door switch is bad or loose or the door is not staying tightly closed.
Mar 06, 2013 | General Electric DBXR463EGWW 6.0 Cu. Ft....
How to replace start switch on ge dryer
Hi tamalac
Go to this webpage and you will see how to disassemble your dryer for repair.
It is not the same model as yours, but will disassemble about the same
Please take time to rate me
Bud
http://www.youtube.com/watch?v=yIPnnUqJ6Ds
Oct 17, 2012 | General Electric DBXR463EGWW 6.0 Cu. Ft....
Amana Electric Dryer Model NDE 7800YW squeals when running will quite after 5 to 10 minutes
my amanadryer will run for 10 minutes and then start squealing and quit.wait 15 minutes and it will restart and do the same thing. any help???
Mar 09, 2010 | Dryers
GE Dryer model DDE5700GCLAD
Your dryer is exhibiting symptoms of a restricted/plugged exhaust vent. Remove the vent tube from the rear of the dryer and inspect it for restrictions all the way to the outside vent hood,(including the vent hood), i.e., lint build up/water retention, pinched-off, too long, animal nest, etc. Also make sure your lint filter is being cleaned after each load.
A blower malfunction could also cause your symptom. Do not overload the dryer as this also can restrict air flow.
Most dryers can only be vented 10 to15 ft. and should be cleaned twice a year.
Always utilize the shortest distance/shortest vent concept.
Jul 06, 2009 | GE DVLR223 Dryers
Replace the operating thermostats. Eric
Jul 06, 2009 | Dryers
Timer will only start from one location, will run 10-15 minutes, then stop. I can restart it immediately at the above location.
HI, this is a simple fix. just replace that defective timer module. it is malfunction and, will fail soon.
Jun 22, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore Dryer model #66912690 The dryer stops
replace motor drive,,,defective motor...onthejob
Feb 08, 2009 | Kenmore 62602 Electric Dryer
GE DBXR463EDWW Electric Dryer Logo
292 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
