Question about Kenmore Elite HE4 Electric Dryer
Water leaking from bottom of machine onto floor during fill and wash cycle
  • 110 Answers
There are 3 bolts are bottom front compartment, may be taken off with a phillip screwdriver, or it may be a torx. when you take it off, cut your washer on and see where it is leaking, your gasket could be broken, your hoses or pump.
Posted on Sep 11, 2009
Why does it leak all over floor after last spin cycle?
my washing machine leaks water onto the floor during each spin ...
https://answers.yahoo.com/question/index?qid...
Feb 3, 2010 - During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. ... It happened to us due to over loading. ...something can get betwen the two tubs it this all fails your tub seal is ...
Sep 30, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
Bosch WFVC6450UC Washer leaks at bottom
How about loose fill hose connections?
How about incomplete shutoff of the internal fill control valve between wash cycles?
Sep 22, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
Water is leaking onto floor during filling and also during the rinse cycle.
you will have to check the hoses coming from the water inlet solinoids as it sounds as if there is a leak in one of them.
Jul 27, 2011 | Kenmore 23822 Top Load Washer
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Replace water pump. Common problem. Unscrew the control panel ,two screws on each end. Flip control panel over and unsnap gold brackets from base to the back. Lift up housing and disconnect lid switch, remove housing. The water pump is in the front lower that has two hoses , disconnect hoses and unsnap pump. My sister fixed hers in about 25 minutes.
Apr 06, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Washing machine
If water is leaking only during the times when it is supposed to be coming in , then the first places to check are at the hose connections and the hoses themselves. If it continues to leak after the water stops coming in , then you have to look at the drain connection and finally at the drum seal.
Nov 22, 2007 | Maytag Neptune FAV6800AW Top Load Washer
GWL11 Machine adds water during spin cycle and leaks on floor
diverter valve is not switching to pump the water out. instead it is resurculating back into the tub.
Oct 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Kenmore Elite HE4 Electric Dryer Logo
248 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
