Question about Nokia 6133 Cellular Phone
My Nokia 6133 will not fully turn on
My Nokia 6133 is acting up. I called someone and the line was fuzzy so i turned it off and turned it back on and now it just gives the blank screen with the battery like it is charging and has been doing that for hours, even when i plugged it in to charge. i tried takin out the battery twice. help!
How to format nokia 6133
hi,
  1. Power on the Nokia 6133. Turn the Nokia 6133 on and allow it to load the home screen.
  2. Navigate to options. Press the "Menu" key on the Nokia 6133. Select "Options" and press "OK".
  3. Select the memory card folder. Highlight the memory card folder. Press "OK".
  4. Select options. Select "Options". Highlight "Format memory card".
  5. Confirm the format. When prompted, select "Yes". Wait patiently while the Nokia 6133 formats the memory card.
  6. Enter a name. When the Nokia 6133 is finished formatting the memory card it will ask you for a name. Enter a name into the Nokia 6133 for the memory card. The Nokia 6133 allows the name to be up to eleven characters and numbers.
Aug 02, 2010 | Nokia 6133 Cellular Phone
I dropped my nokia 6133 - the battery came out. I put it back in and turned off and then turned the phone back on. I can get get and make calls but the screen is white - display came back on briefly but...
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-5 or 6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Feb 21, 2010 | Nokia 6133 Cellular Phone
Phone turned off can not get to turn back on
May it battery gets damaged somehow and that's my your cellfone a acting fishy you can replace your battery and can come back to original position. ;)
Good luck
Dec 13, 2009 | Nokia 6133 Cellular Phone
My Nokia 6133 doesn't turn on anymore
Try taking the battery out and plugging it in to see if it powers up for an extended period of time. If it does, the battery needs to be replaced. If it still powers down there is an internal problem with the phone, you could take it in for repair if you have warranty service on it. The repair is likely to cost more than getting a new phone. Most carriers will offer you a discount if you have had your phone for at least 2 years.
Oct 19, 2009 | Nokia 6133 Cellular Phone
I have a nokia 6133 and it wont turn on
you may need a new battery, if so do as it says. contact the service.
Jun 29, 2009 | Nokia 6133 Cellular Phone
Xbox 360 Blurry/Fuzzy Screen
The machine is overheating and the graphics chip on the main board is acting up cause of it. Make sure there is no dust or dirt blocking the air vents that would cause the system to heat up more then normal.
If that doesn't do it then maybe think about getting a cooler for the system, here is a website that talks about a few of them. Click here.
If that doesn't help then your mainboard is going bad and would need to be replaced.
May 29, 2009 | Microsoft Xbox 360 Console
Nokia 6133 will not power up
check battery first if ur batt is good try to reprogram ur phone to latest versionn using jaf box......
Feb 06, 2009 | Nokia 6133 Cellular Phone
Nokia 6133 white screen
you need to change the LCD or flexcable.
Apr 04, 2008 | Nokia 6133 Cellular Phone
Problem with Audio on Handset
that mean you handset speaker have problem change the speaker or buy new phone for more happy moment
Sep 13, 2007 | Nokia 6133 Cellular Phone
Nokia 6133 Cellular Phone Logo
102 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
