I have a LG RZ-42PY10 42'' Plasmareen which changes to red after 10-15 mins and then turns off.What could it b?I removed the back cover and powered the unit up. Neither of the fans is functioning. Does this offer any clues?
  • arnaud73 Sep 07, 2009
    i'll have a go to change fan....ty
  • 430 Answers
The fan has failed. Thus unable to keep the less and getting red hot and off ! Replace the Fan. But first check for fan blockages. This also be a clue of no connection of the fan with the rest tv.
Posted on Sep 07, 2009
LG RZ 20LA90standby light flashes from red to green
Hi, this description usually indicates power supply failure, you can verify this by checking the output voltage of power supply. Cause of the error can be electrolyte capacitors. You can identify them by swelling at the top of the condenser. If you have the technical ability? so there are a few more options for testing. In any case always possible to replace all power supply. Good luck! Let me know if everything worked out, or if you need further guidanc
Feb 28, 2011 | LG RZ-20LA70 20 in. LCD Television
Power up problems
It sounds like the power is pulsing - that would explain your speakers. Speakers wouldn't make that sound if they were getting power at a steady rate. Look for a bad capacitor. It's possible you have one or more capacitors that have gone bad. They charge to a certain point, then somehow complete a circut momentarily and discharge, giving a pulsing flow of electricity. You can look for visible signs (leaking capacitors, or capacitors that are leaning over), or you can just start testing them with a voltmeter. If you find a bad one, you'll have to get a replacement and solder it in place.
Aug 06, 2007 | LG RZ-20LA70 20 in. LCD Television
I have a Gigabyte 7vt600p-rz motherboard. How do i disable the Bios Security password on it so i can change the boot sequence ?
Clear cmos, you should have a clear cmos jumper on your motherboard, just move the jumper from the normal position to the clear cmos and then back. Or you can remove the lithium battery for atleast 15 min.
Nov 17, 2010 | Gigabyte 7VT600P-RZ (GA7VT600PRZ)...
Keeps turning itself off with a red light next to
have you changed the lamp in this set. If you look by the red light it probably says lamp
Aug 07, 2009 | Televison & Video
When I turn on the tv, green light blinks for a
Its your ballast. it has as short. i recommend changing the ballast. while you are inside the set, i would run a break point test on the power board to be safe but, im sure its the ballast.
Mar 09, 2009 | Televison & Video
LG 42lc7d 42" lcd
Replace power supply and this should take care of all of you problems part number is EAY34797001.
Josh
Feb 09, 2008 | LG RZ-20LA70 20 in. LCD Television
LG RZ-20LA70 How do you....
I'm trying to plug in a RZ-20LA70 TV into a Sony DVP NS29 DVD player? Which wires (red, blue, green) go into the coaxial, audio L, audio R, video slots? Thanks, Simon
Jan 14, 2008 | LG RZ-20LA70 20 in. LCD Television
LG RZ 37LZ55 37 in HDTV LCD Screen Dead
This is likely due to a failed power supply. Replacing the power supply board should solve the problem.
http://www.reviewcentre.com/reviews110919.html
Cr1spy
Jan 10, 2008 | LG RZ-37LZ55 37 in. HD-Ready LCD...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
