Question about Toshiba Tecra 8100 Notebook
Do you need a separate driver dor touchpad (or
Do you need a separate driver for touchpad (or synapse??) I have a mouse driver listed in system devices, but nothing else. At any rate, the 'touchpad' isn't working and I'm wondering how to get it going. Thanks - Mike
    Sergeant:
  • 338 Answers
Hi mike,
I think you may need a driver for the touchpad, it should be on the
CD you purchased with the notebook, if you lack this, simply download and install driver from the manufacturers home page here:
http://eu.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=EU
good luck
Posted on Sep 07, 2009
Testimonial: "thank you for your timely response. I have been on the Toshiba web site, and there is nothing available past 'S' models, mine being a T8100. "
  • Andrej.cet Sep 08, 2009
    you may try to see the archive section on toshiba.com,
    else google and find drivers for touchpad in some tech forums, do not get fooled by pay-sites such as devicedrivers
  • 428 Answers
The fact is from experience as a systems engineer, it is not all the time that a device requiring a driver is listed in the system devices. I have encountered this more than once. Once you are sure sure your device is not broken down i.e. in good working order, what you should do is go online to the support page of the manufacturer to download the driver and install it. You did not mention your manufacturer, else I would have provided you a link for download. Not to worry, just type “manufacturer name and model driver download” into google and run a search. For example “hp 6735 driver download.”
Testimonial: "my fault for not including model! (toshiba tecra 8100) there are no drivers on toshiba site, I suppose the notebook is too old."
Touchpad not active
Press the "Fn" and "F9" keys simultaneously.
Test your touchpad. If it works, it was simply disabled. Press the same key combination any time you want to toggle your touchpad on or off.
Plug an external mouse into a USB port on your laptopicon1.png if the key combination didn't work. Follow onscreen prompts to install the mouse driver--if necessary. You can also move the cursor using the "Tab" key and the arrow keys, as well as click by pressing "Enter" until the mouse is operational.
Click the link in the Resources section if you are using a Toshibaicon1.png Satellite with Windows Vista. Follow the onscreen prompts to download and re-install the driver.
Open a web browser and navigate to Synaptics.com if you have a different Toshiba model or operating system. Synaptics brand touchpads are used in all Toshiba laptops, and this site provides a generic driver.Hover your mouse over "Support" on the top menu, then select "Drivers" from the drop-down menu.
Select your operating system from the list provided and download the generic driver
Follow the onscreen prompts to install your new driver, and then test the touchpad again. If it still does not work, take your laptop to a licensed repair technician.
Jan 06, 2014 | Toshiba SATELLITE 1905-S301 TOUCHPAD AND...
PS/2 Compatible Mouse driver (for touchpad) cannot be disabled. I dislike touchpads and always use a cordless external mouse. System check reports that the 'current version' PS/2 driver is installed....
try drivermax.com but go to uninstall/or remove programs to get rid of it first. Driver max updates 2 drivers free, per day and runs autocheck on your drivers condition. Just choose the mouse driver from the list as first..
Aug 17, 2013 | Toshiba Satellite Computers & Internet
How do you unlock the mouse touch pad?
1. The touchpad and external mouse drivers should be able to work together. Just make sure that you have the touchpad enabled. To see if you have the touchpad enabled, hold the Fn key and press F9. The combination Fn-F9 locks and unlocks the touchpad. If pressing Fn-F9 once, twice, thrice does not seem to lock/unlock your touchpad.. then you might not have the Toshiba hotkeys working or enabled. So lets forget it and try step 2. If Fn-F9 solved your problem.. there you go !
Arrow The way it works is you have to keep holding Fn key and have to hit F9 once, that should lock the touchpad. Again if you keep holding Fn and hit F9 again, that should unlock it and so on..
2. Sometimes this solves the problem.. Do a power cycle of your computer.. i.e., unplug the AC.. take the battery out.. Plug the AC back in and try to turn computer ON with AC alone (i.e, leave the battery out and just start computer with AC power).. Once windows loads up and everything is fine, then turn system off. Unplug AC.. put battery back in.. Plug AC back in and restart computer.. All should be working now.. if not, keep reading..
3. Click on START>go to RUN>type devmgmt.msc
4. Now in the Device Manager, click on the + sign next to Mice and other pointing devices. Right click on each device listed under "Mice and other pointing devices" and Uninstall ALL the MOUSE Devices you see listed there..
attention Make sure you ONLY uninstall the Mouse devices and not ALL devices from Device Manager like your CD, Display etc.. Just uninstall the devices listed under Mice and Other pointing devices after you have clicked on the + sign to the left of it..
5. Go to http://support.toshiba.com there click on Downloads.. select your computer.. Product=Portable, Family=Satellite, Model=M35X-S149.. then click on "GO" button on the right.. Again in the next page that comes up click on "Downloads"..
6. In the page that came up saying Downloads ( All operating systems, All categories ), at the top drop the list Filter by Operating System and select Windows XP (I am assuming you have XP.. if you have another OS, select that instead).. then on the right of it, drop the list Filter by Category and select Touchpad.. then click on the button "Apply Filters"..
7. Now you just see two drivers listed..
09-30-2004 Toshiba Utility
Touchpad Toshiba Touchpad Enable/Disable Utility for Windows XP (v1.27.0.3; 09-24-2004; 5.34M)
06-15-2004 Driver
Touchpad Alps Touchpad Driver for Windows XP/2000 (v6.0.303.5; 05-26-2004; 2.43M)
Click on the Download link on the right.. Save them to your computer somewhere in a folder or desktop, where you can remember.. After the files are downloaded, double-click on the file.. Unzip.. then Run.. and it will install the driver..
8. Restart your computer.. Now the Touchpad should be working fine.. Try Fn-F9 combination.. i.e, keep holding Fn key and tap F9 once, twice to see if it locks/unlocks the touchpad..
If above doesnt solve it, then please post any errors that you get and I will see if we need to try something else.
Thanks for using fixya...
Sep 15, 2009 | HP Compaq nc6000 Notebook
My touchpad mouse won't work. it does not respond
If you are using XP, check your mouse settings under Control Panel. Make sure that your Touch Pad is enabled. If it is but it still won't work, have a mouse plugged into a USB port that will work correctly. Then download the latest driver from the Acer site for your touchpad. Uninstall the driver that is currently being used by your system. Then install the updated driver that you downloaded. This should allow you to use your Touch Pad. If not, you may have to take your laptop in for servicing.
Jul 15, 2009 | Acer Aspire One PC Notebook
My mouse button is lock how do i unlock it
5.Install Drivers
06-15-2004 Driver
If above doesnt solve it, then please post any errors that you get and I will see if we need to try something else. Thanks, CF
Jun 25, 2009 | Computers & Internet
Can't "tap" on my Dell touchpad
I had the same problem after purchasing an HP laptop with a Synaptics TouchPad. After using a wireless mouse for awhile, the TouchPad stopped working. The TouchPad light was white, indicating it was enabled. No TouchPad devices was listed anymore in the Mouse Properties in the Control Panel. I tried reloading the driver but nothing changed.
After shutting down the laptop and removing the battery (according to owner’s manual) it worked again. After turning on the laptop, make sure the TouchPad works. Then go to Control Panel, Mouse, Device Settings tab, and make sure a Synaptics TouchPad is listed in the Devices list and that the Enable button is grayed out.
May 28, 2009 | Dell F3534 Touchpad
My acer aspire touchpad frozes
right click My Computer >> Manage >> Device Manager.
See if the drivers are installed
May 22, 2009 | Acer Aspire One PC Notebook
TOUCHPAD
go to control panel = mouse pointer = look for the pointing device, maybe its called synaptics pointing device on you too then you can unchecked the buttons and even the whole device itself from it.
Feb 05, 2009 | HP Pavilion dv6000z Notebook
Extensa 5420
try to download these drivers http://www.acerpanam.com/synapse/data/7117/documents/Touchpad%20v.9.0.1.0.zip (driver)
http://www.acerpanam.com/synapse/data/7117/documents/Touchpad_v.9.0.1.zip (utility)
This should fix your problem.
Oct 04, 2008 | Acer Computers & Internet
Acer 5100 aspire
Visit naerest PC SERVICCE for help couse is nothing i can do from here...
Beni
Apr 09, 2008 | Acer Aspire 5100-5022 Notebook
Toshiba Tecra 8100 Notebook Logo
130 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
