Question about Acer Aspire M3641 Dual Core E2200 PC Desktop
How do i remove the front panel to change CD/DVD drive? I do not have a manual for my desktop - I can remove the side panel but not the front panel. thanks you
  • wheaties96 May 11, 2010
    Send me a few photos of your desktop, focusing on the tower unit where the CD/DVD drive is located. Take a few different shots to give me the best "look" at your tower as possible.
  • 916 Answers
You need to remove the side and then remove the front. The front is connected by latches which are on the top bottom and opposite side of the machine. Once you do that the drive should slide out the front of the machine. You may need to use a flat head screw driver to get the panel off.
Posted on Sep 07, 2009
Cant reach the connections to change the psu on an el1352g-41
After you remove the side panel you should be able to remove the front panel of your case by unhooking those 3 black clips and pulling that side by those clips forward and to the left.
Once the front panel is off or most of the way off then you should be able to remove the CD/DVD drive assembly. Then you will be able to get to those connections.
Here's what I'm looking at:
May 22, 2012 | Computers & Internet
Disk wont eject from inspirion 1720
cd drive right? might be jammed in there should be a small hole in side or front panel to eject manually might need to remove from desktop and do it that way. not easy
May 14, 2012 | Dell Inspirion / Studio / Vostro / XPS...
How remove DVD From desktop Compaq Presario
have to be a little more clear with the question depends on where you want them removed if the computer oh intalar system for a non-dvd if the system goes to control panel and look for oction says oh add remove program
if you want to put a DVD without need only to plug the computer and remove the cable and put the other one wants to
Oct 17, 2010 | HP Compaq Presario Media Center SR1750NX...
Need to replace cd-rom drive, how difficult? dell dimension 3000 pc desktop
It is not difficult to change cd/dvd drive.
Open cpu cabinet.
Then remove icd cable and power cable from cd/dvd drive.
Then remove screws of old cd/dvd drive.
Then you can pull it from cabinet from front side.
Then put your new cd/dvd drive into it's position then lock it with screws.
Then connect ide cable from motherboard and power cable to drive.
Then you can use it.
If you connect to drive with 1 ide cable means if you connect harddrive and cd/dvd drive with 1 cable then set harddrive as master and cd/dvd rom as slave you can set it slave with jumper settings.
It is in back side of cd/dvd drive.
There is instruction how to slave it with jumper.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 17, 2010 | Dell Dimension 3000 PC Desktop
I have a Gateway 300x Micro-Tower case circa 2002 and I can not open the case, without breaking it. I'm trying to install a new audio card and can't get at the 300x innards. Help!
Most of these towers are vertical style, therefore the big button is just to the left of the Gateway symbol. Push it in and pull the left panel away from the case.
Jan 11, 2009 | Computers & Internet
DVD drive bay
yes you should be able to play CD on the DVD reader.
Dimension 2400 have drive slide mounted on the side of the hard drive, cd drive and floppy. they are different for each device. you need the 2 side mount for the dvd. in order to mount them in the Dell.
the drive is inserted from the inside of the box toward the front. The front panel will prevent the device from pop out.
yes, 3 party DVD, CD drive will be shorter and fater that what Dell porvide, but it will work, al long as the opening is accessable.
get the HP DVD driver.
Nov 04, 2008 | Dell Dimension 2400 PC Desktop
Cd drive
1.If the keyboard has a CD/DVD Eject key, press it. The Eject key is usually placed by the volume knob and is marked by a triangle pointing up with a line underneath.
2.Double-click My Computer .
3.Right-click the icon for the CD, CDRW, or DVD drive that is stuck, and then click Eject.
4.If the CD or DVD drive door button is a long clear plastic bar on the front of the PC, press firmly on the right side of bar. Some models have a button on the front panel of the PC to the right of the hinged door. Press the button to eject the drive.
5.If the drive door button is part of the PC case and is covering the actual drive door, open the door that is part of the PC case and press the Eject button on the faceplate of the drive.
6.Restart the PC and press the Eject button on the front of the drive when the first screen appears (before Windows launches). If the drive door opens this way but does not open in Windows, another software program is taking control of the CD driver. Try shutting down or configuring any software programs that create discs or monitor the CD or DVD drive.
7. If the door still does not open, do the following:
1.Close all programs and shut down the PC.
2.Unplug the power cord from the power outlet.
3.Look for the small hole on the faceplate of the CD or DVD drive. This is the manual release. The location of the manual release hole will vary (see Figures below for possible locations).
NOTE: On some models it may be necessary to remove the front panel to expose the manual release hole. Check the documentation that came with your PC for information about removing the front panel.
NOTE: On some models the release hole and the drive activity LED look similar and are about the same size. Do not force the paperclip into the hole if it does not go in. Make sure that the hole is not actually the LED.
Figure 1: Possible location of manual release hole
Picture showing possible location of manual release hole
4.Straighten the paperclip and insert it into the manual release hole until resistance is felt.
5.Once the resistance is felt, keep pushing the paper clip until the drawer opens a little.
6.Remove the paper clip and gently pull out the drawer until the disc is accessible.
7.Remove the CD and turn on the PC.
8.If the tray still does not open, do the following steps to check the power cable for the drive. Work on a hard flat surface over a non-carpeted floor:
WARNING: The edges of metal panels can cut skin. Be careful not to slide skin along any edge of the computer's interior metal.
CAUTION: This product contains components that are easily damaged by ElectroStatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap that is connected to a grounded surface (like the metal frame of the PC).
1.Turn off the PC.
2.Unplug all power cords from the back of the PC.
3.Press and release the Power button on the front of the computer.
4.Remove the side panel.
5.locate the power cord that connects to the back of the CD or DVD tray that is having the problem.
6.Unplug the power cable and wait five seconds.
7. Find a different power cable that is not being used, plug the different power cable into the back of the drive, making sure that it fits firmly into the socket. If a different power cable is not available, replug the original power cable into the back of the drive, making sure that it fits firmly into the socket.
8.Replace the side panel and plug in the power cord.
9.Turn on the PC and press the eject button on the front of the drive.
If the optical drive does not have the manual eject feature and the CD tray will not open by using the steps in this document or if a disc has shattered inside the drive, the CD, CDRW, DVD drive may need to be replaced.
Oct 25, 2008 | HP Pavilion a1330n (EL466AA) PC Desktop
How do i install a dvd in a packard bell 551
is this a laptop or a desktop computer.if its a laptop I can check sevice manual if its desktop you only have to take off sides to install/fit dvd drive(usually left hand side)
Dec 05, 2007 | Computers & Internet
Removing the faceplate
Hi, I can help you with this. Are you trying to remove the cd-rom drive bay plate or the front panel of the tower?
Sep 16, 2007 | Compaq Presario 5000 PC Desktop
Acer Aspire M3641 Dual Core E2200  PC Desktop Logo
564 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
