I have a Sharp portable a/c unit (cv p10nc) which I need to get intothe interior. My sun room gets a lot of dust from the decomposed granite in my landscape and I believe there is build up in the unit. I've taken out the 6 screws in the back but do not know how to take off back cover w/o damaging it.
  • 615 Answers
See if you can locate a diagram of all parts on the net that may help you as it is not easy to type step by step
Posted on Sep 08, 2009
What is the meaning of all three lights blinking
That means you need to drain the tank. The manual tells you how to do that.
Jul 28, 2014 | Sharp CV-P10NC Portable Air Conditioner,...
Cool air when running; warm air when compressor is off.
It sounds as if warm outside air is being drawn back into the room when the unit is not actively cooling. Portable units depend on room air to carry the heat outside, & therefore will not work properly if the room is too airtight. Provide a makeup air passage by leaving the door slightly open, & see if this helps. Use a room thermometer to see if your desired temperature is being reached. Note that if the wind is strong & coming from the wrong direction, it may not be possible to prevent warm air drawback.
Jul 10, 2007 | Sharp CV-P09FX Air Conditioner
How do I remove plastic housing from Sharp CV-P10MX portable air conditioner to clean dust from inside.
It should be clipped on with a type "S" clip. If there are no screws visible, gently work all sides and pull towards you.
Apr 29, 2014 | Sharp CVP10MX cvp10mx 9 500 btu portable...
I am looking for the two circuit boards for the Sharp Portable Air condition Model CV-P10NC
These units are not economically viable to try such repairs out of warranty.
Mar 15, 2013 | Heating & Cooling
Mold in sharp cv-p10mc water reservoir
Dominic,
My only solution is to take the unit in for warranty service. The cooled air has a musty smell to it, too. Does yours? And did you get this issue resolved?
Sep 08, 2012 | Sharp CV-P10NC Portable Air Conditioner,...
Hi I have a sharp portable AC unit model CVp 10lc works for 1hour
I have the same problem. I have only used my unit 3 times. It keeps "triping" and shuts off. Also, I smell a plastic burning smell and the plug gets very hot.
Apr 02, 2010 | Sharp CV-P09FX Air Conditioner
I have a Sharp portable room air conditioner model CV-P10NC. The power plug RESET button and TEST button will not click in order to check out the power plug as the unit will not turn on. They did test O.K....
the fused9G.F.C.I.) cord you speak of is probably the G.F.C.I. built onto these units by design, can you or someone you know get access inside the unit and :Hot-Wire" the units cord and,bypass the power cord ( Just To Test the Unit)and see if it stays operational then replace bad unit cord if this is it.
Sep 12, 2009 | Heating & Cooling
Sharp CV-P10NC AC unit it has a puddle of water coming down.
earlier models had a pan you had to empty .. your model has a small pump that is supposed to pump the water out the hot air vent (that goes thru the window} .. since its leaking it is likely that the pump inlet is clogged ... you might have to remove a panel to get at that ... it will be near the bottom of the unit (near the drainage nozzle) ... also check the hose that goes out thru the outside vent .. make sure its not cracked, clogged or smashed ... temporarily you can use the drain nozzle to drain off the water to a lower area (it cant drain up without the pump) ...
Aug 17, 2009 | Sharp CV-P09FX Air Conditioner
My CV-13NH portable type room air conditioner won't blow cool air
If its blowing air, but not cold, the compressor isn't engaging. There are many different possibilities on this.
Bad compressor, unit out of gas, bad run capacitor, etc, all could cause this, even a bad control panel.
Hope its something simple.
Greg.
Aug 18, 2008 | Sharp Heating & Cooling
Heating & Cooling Logo
149 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
