Question about Philips SHE2650 Consumer Headphones
My right earphones piece broke off in my pocket how can i fix it?
The tip of the earpiece came off in my pocket an i want to fix it so i won't have to buy anither one
  • 530 Answers
I'm not sure if what part came off but if the wires were broke then.
I would like to to give you something. It's the gift of time. The time that you are going to spend on attempting to repair your earphones. I'm not sure how much experiences you have with taking things apart and putting back together but, I've been doing it all my life. I have a hot air pencil and a awesome soldering station. I also have two pair of Shure brand earphone. At about $200.00 a pair I was highly motivated to fix them. Although I was somewhat successful, they never did sound quite right again. Needless to say I spent way to much time trying.
There is just too many things you have to get right inside them.
Now if it's just the plastic section then it's an easy fix.
Posted on Sep 07, 2009
Replacing minijack
I use a multimeter to check the connections to the ear pieces. I set it to the diode function. The meter's test probes also have a very low dc voltage and this causes a 'click' sound in the working earpiece. Some earphones have 3 wires, others have 4 wires. In the 3-wire setup, one wire is the common wire. It goes to the ground connection of the mini plug. The 'click' sound on the left ear piece should go to the tip of the connector. The 'click' sound that you get on the right ear piece should be soldered to the 'ring' of the mini plug. The 4-wire type of earphone/ headphones cable usually have two wires that are the same colour. These are the ground or common connections for both right and left. I hope that this helps. A multimeter or vom is a necessity. Len.
Apr 11, 2014 | Klipsch Image S4a black For Android In-Ear...
How to open earpiece of UrbanEars Medis earbud
I have a pair of marshall minor headphones. They are essentially the same headphones, very similar design if not identical. I had a short occur just where the cable enters into the ear piece, i was devastated when this happened. they are a good pair of headphones and i didn't want to have to shell out on another pair.
To open the earpiece, i first removed the silicone ear-click thingy. if you look in the recessed space where this fits, you will notice a clear join between the two pieces of plastic. I inserted a razor blade into this join and after very little effort i managed to separate the two halves. In doing so i actually poked the back plate off as well, i did actually try to get this off but didn't trust myself enough with the razor blade to continue.
there is another layer of plastic covering the circuit board in the ear piece, which again i would attempt to remove via the recess where the silicone ear-click piece goes. i only had a short in the cable so i didn't go as far as getting to the circuit board.
the whole earpiece consists of at least four main pieces of plastic which are held together by a series of plastic pins. with a little Araldite/ strong superglue you would never know i had opened the earpiece.
i can't believe there is nothing online about fixing these headphones. it's a shame, they are good headphones which have now been saved from the bin.
Nov 14, 2012 | Urbanears Medis Earphones
Headphone jack has a piece of connector stuck in it and it is making my speakers not work how can i fix this problem?
You will need to remove the broken piece. Power down the computer and unplug it. The only suggestion I would have is see if you get get to the jack from inside the computer and push out the broken piece with a paper clip.
Jun 11, 2012 | Dell Dimension E510 Dual Core 2.8 Ghz...
Low volume on calls. cannot hear caller unless i'm in an absolutely quiet room. I have the master volume at max. also, the flash is so bright that the pics i take are overexposed. Can i shut the flash off...
for the low volume, the fault is from the earpiece. Trust me, I faced this same problem and when I changed the ear piece, I began to hear calls clearly.
You could also get a earphone and use it to receive and make call pending the time you get the earpiece fixed. Earphone will even be much louder.
Concerning the flash, do some adjustment settings as you rightly suggested.
I wish you the best.
Dec 31, 2009 | Cell Phones
My ear piece will not work?? did but won't now. all volume are up and the speaker works fine, but the ear piece won't
There are two things involved, Its either the earpiece is bad or the problem is from the phone board. I have seen cases like this.
Maybe you should try changing the earpiece first and let's see what happens.
You might just get use earphone to save you the stress for the main time
take care
Nov 19, 2009 | Motorola Mobility i580 Cellular Phone
Cannot get sound to come out of earpiece after pushing button on top of i870
sir u have to see that earphone i properly plugged to the phone...nor ur ear piece dameaged....
Oct 18, 2008 | Nextel Cell Phones
Cant hear out of one side of earpiece
have you tried using differnt earphones? if the problem is still the same with different earphones then it's the ipod itself that has a problem, you'll have to get it fixed.
Feb 24, 2008 | Apple iPod nano
Dell mp3 problem
On the left side next to the jack, there is a screw. Take a small screw driver and tighten the screw. On mine, I had the same problem, then was messing around one night and discovered that the screw controlled the pins inside the jack. Hopefully that helps.
Jan 15, 2008 | Dell Pocket DJ MP3 Player
Philips SHE2650 Consumer Headphones Logo
286 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
