New ink cartridge installed in printer. printer still showing no cartridges installed.Have removed yellow tags and closed and switched on printer
    Sergeant:
    Champion:
  • 255 Answers
The contacts on the printer its self are dirty or most likely bad, try to clean,if that dont work replace printer.
Posted on Sep 07, 2009
  • 1,879 Answers
-the printer no longer can recognize any cart
-try cleaning the contacts between the cart and the carriage
How do I change the ink cartridge in a Lexmark x2330
  • Turn the Lexmark printer on by pressing the power button. Usually, the power button is located on top of the Lexmark printer. If the Lexmark printer does not power on immediately, then hold the button down for a few seconds before releasing it. Once the Lexmark printer has powered on, the installed cartridges will begin to move back and forth for a few minutes.
  • 2
    Raise the Lexmark printer cover up towards you. Doing this will give you instant access to the inside components of the Lexmark printer. Lift the cartridge release lever and remove any installed ink cartridges. Be careful when doing this because the ink may leak out. It's best to have a disposable bag or paper towel near you when performing these steps.
  • 3
    Remove the plastic from the brand new cartridges by carefully cutting them open with scissors or tearing along the perforated edges. Once you have removed the plastic, there's a yellow tag located near the bottom of the ink cartridge. Take this tag off only when you're ready to insert the ink cartridges into the slots.
  • 4
    Tear the yellow tag from the ink cartridges and place them into their corresponding slots. Each one will be easily identified by its color. The cartridge release lever will have the same color as the ink cartridge. If you mistakenly place the cartridges in the wrong slot, then you'll risk having your Lexmark printer stop working properly.
  • 5
    Press the ink cartridges into the slots and listen for a clicking noise after the insertion. Although you will need to firmly place the ink cartridges into the available slots, it still needs to be done gently. Close the Lexmark printer cover when you've completed the previous steps. Wait a few minutes for the Lexmark printer to recognize that you have inserted brand new ink cartridges. After a few seconds, it will go through some diagnostic steps to make sure the ink cartridges were correctly inserted.
  • 6
    Print a test page on your Lexmark printer. This will help you to determine if the ink cartridges are properly working. You can view the newly printed images and text after the Lexmark printer has finished printing. Get rid of your used ink cartridges by throwing them away or sending them to an online store that accepts empty ink cartridges.
  • Jan 17, 2011 | Lexmark X2330 Printer
    How can i remove the cartridge?
    1. Open the ink compartment door.
    2. Press down the release of the latch that holds the ink in place. (see attached)
    3. Pull the cartridge strait out.
    4. Remove the yellow cap from the new cartridge.
    5. With label facing you install the new ink.
    6. Close the locking latch. You should hear a click.
    7. Close the door
    Dec 23, 2010 | Brother MFC 240C All-In-One InkJet Printer
    After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
    Try this procedure:
    1. Open printer lid so cartridges move to center of carriage.
    2. Lift clamp and remove black or color cartridge from the holder.
    3. Place cartridge on table with copper contact strip facing you.
    4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
    5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
    6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
    7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
    8. Open lid again, remove cartridge, remove tape.
    9. Reinstall cartridge and close lid.
    Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
    I hope this helps, if so please rate our solution.
    Buddy
    Corporate Computer
    www.ccl-la.com
    Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
    Show me how to install new ink cartridge onv305
    hi eileenoreill,
    you can try these steps:
    1. Turn on your printer.
    2. Lift the scanner base unit.
    3. Press down on the ink cartridge lever to raise each ink cartridge lid.
    4. Remove the old ink cartridge.
    5. Store the cartridge in an airtight container, such as the storage unit you received with your photo cartridge, or dispose it appropriately.
    6. Remove the sticker and transparent tape from the back and bottom of the new ink cartridge.
    7. Insert the new ink cartridge. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
    8. Snap each lid closed.
    9. Lower the scanner base unit until it is completely closed
    10. Snap each lid closed.
    just update me if the issue is not yet resolved.
    Oct 18, 2009 | Dell V305w All-In-One R840635AU InkJet...
    My printer says install magenta what does that mean
    It means for you to install the magenta ink. Magenta is a color. You have 4 colors. Yellow, magenta, cyan, black
    Oct 14, 2009 | Brother Multi-Function Center MFC-240C...
    Ink cartridges cannot be recognized in canon printer
    Hello!
    Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
    If that doesn't work, one of your cartridges (sadly) needs to be replaced.
    Apr 15, 2009 | Canon PIXMA iP1300 Printer
    HP C6280 with new ink cartridges shows cartridges empty
    First make sure you are placing the right
    color cartridge into the right slot.
    Most Printers are touchy about the
    installation of ink cartridges. If the
    instructions say to press the cartridge
    into the slot until you hear a loud click,
    that's what they mean. If at first you
    don't succeed, remove the cartridge and
    reinsert it into the slot again and press
    on it hard till it clicks.
    Then your printer should work properly.
    Hope this is of some help. Bud
    Feb 03, 2009 | HP C6280 All-in-One Printer
    Says the yellow ink needs replacing,have a new ink cartridge in
    pulled plug, removed yellow cartridge, cleaned point where yellow ink goes in, put plug back in and it worked.........Thanks
    Jan 27, 2009 | Brother MFC 210C All-In-One InkJet Printer
    Need to change the ink cartridge on lexmark model #x2350
    1- Turn the printer on by pressing the power button. Usually, the power button is located on top of the Lexmark printer. If the Lexmark printer does not power on immediately, then hold the button down for a few seconds before releasing it. Once the Lexmark printer has powered on, the installed cartridges will begin to move back and forth for a few minutes.
    2- Raise the Lexmark printer cover up towards you. Doing this will give you instant access to the inside components of the Lexmark printer. Lift the cartridge release lever and remove any installed ink cartridges. Be careful when doing this because the ink may leak out. It's best to have a disposable bag or paper towel near you when performing these steps 3- Remove the plastic from the brand new cartridges by carefully cutting them open with scissors or tearing along the perforated edges. Once you have removed the plastic, there's a yellow tag located near the bottom of the ink cartridge. Take this tag off only when you're ready to insert the ink cartridges into the slots.
    4- Tear the yellow tag from the ink cartridges and place them into their corresponding slots. Each one will be easily identified by its color. The cartridge release lever will have the same color as the ink cartridge. If you mistakenly place the cartridges in the wrong slot, then you'll risk having your Lexmark printer stop working properly.
    5- Press the ink cartridges into the slots and listen for a clicking noise after the insertion. Although you will need to firmly place the ink cartridges into the available slots, it still needs to be done gently. Close the Lexmark printer cover when you’ve completed the previous steps. Wait a few minutes for the Lexmark printer to recognize that you have inserted brand new ink cartridges. After a few seconds, it will go through some diagnostic steps to make sure the ink cartridges were correctly inserted.
    6- Print a test page on your Lexmark printer. This will help you to determine if the ink cartridges are properly working. You can view the newly printed images and text after the Lexmark printer has finished printing. Get rid of your used ink cartridges by throwing them away or sending them to an online store that accepts empty ink cartridges.
    Nov 27, 2008 | Lexmark Office Equipment & Supplies
    Don't know how to move the cartridges to replace the ink.
    Please follow the instructions below to ensure correct installation:
    1. Lower the printer's output tray and open the top cover.
    2. Connect the power cable to the printer.
    And switch on the printer.
    The print heads will now move to the replacement position. If they do not move to a change position press the Red ink button on the printer.
  • Lift up the ink cartridge clamps.
    Before you open the new ink cartridge package, shake it four or five times. Then remove it from the package.
    Do not touch the green chip
    on the side of the cartridge. This can damage the ink cartridge.
    Remove the yellow tape from the bottom of the ink cartridge.
    You must remove the yellow tape from the cartridge before installing it; otherwise, print quality may decline or you may not be able to print.
    If you have installed an ink cartridge without removing the yellow tape, take the cartridge out of the product remove the yellow tape, and then reinstall it.
    Do not remove the transparent seal from the bottom of the cartridge or the label on the cartridge; otherwise the cartridge may become unusable or ink will leak.
    Place the ink cartridge into the cartridge holder with the bottom down. Then push down the ink cartridge until it clicks into place.
    Repeat steps 4 to 6 for each ink cartridge.
  • Close the ink cartridge cover and press it until it clicks into place
      If you find it difficult to close the cartridge cover, make sure all the cartridges are firmly seated. Press down on each cartridge until you hear it click into place. Do not attempt to force the cover closed.
    1. Close the printer cover and press the ink or start button to begin charging the system. Charging can take up to three minutes and is complete when the power light stops flashing.
    While the ink system is charging do not switch off the printer.
    Sep 16, 2008 | Epson Stylus 880 InkJet Color Printer
    k24674
    jasbo
    jasbo
