Question about Lenovo 3000 N500 Notebook
When i press the @ button it returns " and vica versa for the " button which returns an @ - can somebody tell me how to change this? I have a Lenovo N500 running XP.
    President:
  • 2,678 Answers
Go to the control panel/ regional and language options.
In the regional options select UK from the drop down box then apply then go to language tab / details and do the same.
Posted on Sep 07, 2009
CAN I USE HEAD GASKET FIX ON MY PEOUGOT DIESEL ESTATE, COMPRESSION LEAK INTO COOLING SYSTEM
unfortunatly gasket fix wont work in this caseif it was water leaking into oil or vica versa the gasket sealer would work but only a temporary solution
Dec 14, 2016 | Peugeot Cars & Trucks
Lenovo Think Pad is always hibernating
Looks like somebody was trolling you. When did it start doing this? I suggest trying to turn it all the way off. Then turn it on again. Try fiddling with your power settings. Do you keep pressing the hibernate button accidentally? Press the hibernate button to wake it up. Also, Is there an obvious button that tells the computer that the screen is down. Try pressing that. Fiddle with it. If it started doing this randomly out of nowhere, you might want to do a system restore.
Feb 13, 2014 | Lenovo Computers & Internet
Discovery kids rocket clock - no manual
I can't upload a manual but I can give you instructions:
1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between m/d/y/hour/minute. If it goes to the alarm setting instead of time setting, try again.
2) set alarm: hold down "alarm set" button for 5 seconds, use up and down arrows to change, press "alarm set" button once to toggle between hour/minute. press "time set" button to return to clock
3) turn on/off alarm: press "alarm set" button once, press "up" to turn alarm on and press "up" again to turn alarm off. press "time set" button to return to clock
4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial under the lens-cylinders to select a different image
5) military time: press the "up" button when the time is displayed (not when you're setting the time) to change from 12 to 24 hr or vise-versa
Good Luck!
Dec 03, 2012 | Discovery Channel Discovery Kids - Rocket...
Could not find camera in my Lenovo laptop G460
press and hold down Fn+Esc button this should turn on the camera if turned Off vice versa.
check the camera drivers as well if installed or not.
Aug 20, 2011 | IBM LENOVO VIDEO ADAPTER-G450 32MB 22P6640...
I have had my PS3 for bout a year now and I'm using HDMI cord and all of a sudden i cant see nothing on my screen for nght to day...why could it be?
Have you tried changing the HDMI cable and making sure none of the settings have been changed on the tv or the console? try the normal AV cable on the back of the Ps3 console to see if it works but make sure you consult your manual to see how to change from HDMI to AV and vica versa.
Nov 01, 2009 | Sony Playstation 3 (PS3) Console
Characters dont match keys Choose " key and get @ and vica versa???
Goto the control panel, keyboard and choose US 101 keyboard
Sep 02, 2009 | Computers & Internet
No radio path unavaiable for blackberry pearl
All you need to do i Change it from "Line 2" to "Line 1" or vica versa. press dial to access your last dialed numbers...and at the top of the screen you will see the options
Dec 07, 2008 | RIM BlackBerry Pearl 8100
How do you set the clock nissa versa 08
Clock set
If the clock is not displayed with the ignition
switch in the ACC or ON position, you need to
select the CLK-ON mode. Press the MENU button
repeatedly until CLK-OFF mode is displayed.
Use the TUNE/SEEK button to enable CLK-ON
mode.
1. Press the MENU button repeatedly until
CLK-ON mode appears.
2. Press the MENU button again, the time will
start flashing.
3. Press the TUNE/SEEK button
or to adjust the hour.
4. Press the MENU button again; the display
will switch to the minute adjustment mode.
5. The minutes will start flashing. Press
TUNE/SEEK button or to adjust
the minutes.
6. Press the MENU button again to exit the
clock set mode.
The display will return to the regular clock display
after 10 seconds, or press the MENU button
again to return to the regular clock display.
Resetting the time
Hold the MENU button down and then press the
TUNE/SEEK button, the time will reset as follows:
c If the displayed minutes before the reset are
in the range of :00 - :29, the hour displayed
before the reset will stay the same and the
minutes will be reset to :00.
in the range of :30 - :59, the hour displayed
before the reset will advance by one hour
and the minutes will be reset to :00.
For example, if the MENU button and the
TUNE/SEEK button are pressed while the time
displayed is between 8:00 and 8:29, the display
will be reset to 8:00. If the buttons were pressed
while the time was between 8:30 and 8:59, the
display will be reset to 9:00. At the same time the
display will return to the audio.
Nov 11, 2008 | 2008 Nissan Versa
Son pressed something and now DVD won't work
well there could be two things going on here that i can think of, one the scart lead between the dvd and the tv is not i properly vica versa for the dvd player, the other thing is the button which changes the av channels could have been pushed so simply push the button while the dvd os on and find the av channel, the button looks like an arrow going right hope it helps.
Jul 04, 2008 | Panasonic Televison & Video
Technomarine watch
I can't set minute hand on omega seamaster wrist watch
Jun 25, 2008 | Watches
Lenovo 3000 N500 Notebook Logo
41 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
