Question about Kenmore Washing Machines
It washes fine but it doesn't spin every time?
  • 15,935 Answers
It appears your lid switch/door latch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
It washes fine just doesn't spin or drain
Hi. For general electric. Desenchufar la lavadora por 2 minutos volver a enchufar inmediatamente realizar 6 aperturas y cierre de la tapa superior dentro de los primeros 15 segundos despu?s de haber enchufado nuevamente la lavadora. Con esto de realiza un reset. Del sistemas se borran los c?digos de error.
Jul 28, 2013 | Washing Machines
Zanussi fj12544 fills but won't wash
see this probably cause:
t doesn't pump or spin
frozen pulley or broken belt, replace
It pumps, but doesn't spin
lid switch defective,motor coupler defective,belt broken,clutch broken,drive motor defective.
It spins only with the lid closed
lid swtich defective.
Jun 18, 2012 | Zanussi ZWF1420W Front Load Washer
Spin cycle doesn't work
bad drain pump or clogged drain line. some units have drain trap you can clean,if so you can clean it out yourself but will make a huge mess if you don't pinch close the drain hose between the tub and pump.
Nov 12, 2011 | Haier HLP21N Washer
My washing doesn't spin, It doesn't pump or spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 12, 2011 | Washing Machines
All the water does not spin out of the clothes & at times it doesn't even seem like it is spinning
heatman101
Jun 07, 2011 | Whirlpool LSR6334LQ Top Load Washer
Roper rab4132hq0 washer does not spin consistently. Most of the time, the spin will not engage, this isn't just for the spin cycle, but for the spinning during the wash and rinse cycles as well....
Sounds like a bad gearcase.You have a machine that is direct drive. The motor is hooked directly to the gearcase by a little coupler. Look under and make sure the coupler is in place if it is then you need gearcase.Again the coupler is located between the motor and gearcase. Hope this helped.
Jun 04, 2011 | Roper Washing Machines
Model GLTF167A0S0 Serial XC22704657... The final spin frequently doesn't work. I tried another wash cycle and the "high speed" spin didn't work. I can manually start the cycle and it...
If the water is pumping out fine you may need new shocks. But if it is slow pump the shaft on the pump is loose and causing the noise and possibly the spin issue. If it is loud when it does go into a spin (sounds like a jet engine) you have bad bearings. Big bucks to fix.
Jun 03, 2011 | Frigidaire GLTF1670A Front Load Washer
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
Spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
May 21, 2009 | Kenmore Washing Machines
Washing Machines Logo
12 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
