Question about Panasonic PV-DV201 Mini DV Digital Camcorder
Panasonic dv201d play back problem
My panasonic dv201d does not play back video, fast forward, rewind or record anymore
  • 3 more comments
  • Hal Dean Sep 07, 2009
    that did not work
    that did not fix it. it seems to have the most trouble rewinding than anything else.
    resetting the camera did not work. it is still having playback problems.
  • Hal Dean Sep 08, 2009
    How do I update the software?
    Quick response
  • Panasonic Master
  • 19,396 Answers
It is not a matter of updating software. If a camcorder does not play back , fast forward, rewind or recordand the camcorder is starting, then the unit is faulty.
If unit stays on, and traction is not working, then you can have one of the following faults:
Traction fault: this is often mechanic problem. Tape is not being pulled because one of the gear is broken, or because rollers are stuck.
Faulty controller board.
Controller board must be replaced.
Faulty pad touch controls or faulty touch screen control.
Fault part must be replaced.
In all situations the camcorder must be taken apart , fixed and reassembled. This must be done by a technician, as the risk of damaging the unit beyond repair would be quit high.
You can get a quote on repair ringing Pana at the number listed on the owner manual, or get a quote from third party here:
Repair
Regards.
Posted on Sep 08, 2009
  • 4,281 Answers
For that first press power button for 10 seconds.
Then pull battery cell from it.
Then pull memory card if it is attched there.
Then again put battery then start camera then reset all settings to factory defaults.
Then check sometimes settings are messed up so this problem occurs .
Then check.
Let me know if you need more assistanse.
Thanks.
Posted on Sep 07, 2009
  • So your camera software has issue.
    You have to upgrade your camera video player software.
    Thanks.
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Apr 20, 2015 | Panasonic RR-930 Desktop Cassette...
Why does my vcr play, fastforward and rewind for 4 seconds then stops for no reason?
When the mechanism is damaged the VCR will attempt to play and then shut itself down to prevent any further damage. If you remove the top cover and look around inside you will probably find the cause of the failure.
Aug 10, 2014 | Panasonic Televison & Video
Put in tape and vcr fast forwards
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
May 11, 2012 | Panasonic Pv-9661 Omnivision 4-head Hi-fi...
Cant playback tape
Videos recorded on one camcorder very seldom play back in another, due to the internal codes put on the tape by the original machine.
Aug 09, 2017 | Panasonic NV-GX7B Mini DV Digital...
Won't play tape
Sounds like contaminated heads.
Feb 11, 2018 | Panasonic PV-DV201 Mini DV Digital...
Won`t Rewind
Do you still have the remote control? Try with the remote. If this works, the button of the camera is broken and have to be replace by a qualified technician. Good luck!
Sep 27, 2008 | Sony Handycam CCD-TR517 Camcorder
Problems with recording/rewind/fast forward
You probably have a bad power supply. But as you will learn, repairing any VCR will cost more than buying a new one.
Feb 17, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Help it's going to fast
Your camera has a capstan servo problem which is more than likely being caused by the capstan motor itself.Nothing you can do youself,would suggest bring to service but reccomend getting estimate before repairing.
May 23, 2007 | Panasonic PV-GS31 Mini DV Digital...
Rn 305 doesn't record nor play
I had a similar problem and found out the batteries are weak and changed to a new batteries. Now it works
Nov 26, 2006 | Panasonic RN-305 Handheld Cassette Voice...
Panasonic PV-DV201 Mini DV Digital Camcorder Logo
60 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
