Live Chat Q: Panasonic SA-HT70 will accept disc but message says NO DISK Your Answer: Clean with cleaner disk or replace lens. I have cleaned unit with disk. WHAT is a lens and where is it located and Where can I get one?
  • 5,138 Answers
The Lense looks like a Little eyeball tiny small round glass clean with a dap of alcohol blow dry with mouth once dry retry disk or even try another disk make sure your disk are clean.lense is Located under Deck where disk is placed.
Posted on Sep 19, 2009
My cd is not being read on my panasonic cd stereo system sa-ch64m?
I afraid to say the symptom indicates your unit's laser is faulty
First of all I would suggest you to clean the laser lens to see if it solves your problem.
1) Purchase a CD/DVD laser lens cleaner disc and run it through the system 5-6 times.
If you want, you can buy a CD/DVD laser lens cleaner disc by following this link- http://www.amazon.com/Memorex-CD-DVD-Player-Laser-Lens-Cleaner/dp/B00008EM7U
2) If your unit is not under warranty then try this step otherwise it will void your unit's warranty.
If the cleaning disk does not work then remove the cover of the device, you may be able to locate the laser eye clean the laser with a soft clean cue tip or a cotton bud using isopropyl alcohol.Then check with a magnifying glass for any traces of dirt.
If cleaning doesn't helps then you will have to replace the laser diode and replacing the laser diode is very expensive because it requires the entire optical pickup to be replaced and realigned.Therefore I would suggest you to please first of all enquire about the labor,installation charges etc before going for the repair because in some cases the cost of replacing the laser inside the unit will typically exceed the cost of buying a replacement unit.
Oct 30, 2016 | Panasonic Audio Players & Recorders
Can Panasonic saht70 play blueray disc
1) you must get the support via ONLINE chat from the manufacturer to see if possible to play blue ray disc 2) the same way get the manufacturer some schem how to connect the speaker without the player.
God bless you
Nov 25, 2013 | Panasonic Sa-ht70 Home Theater Receiver 5...
Panasonic dvd player in car
see the cause and remedies:
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
  7. rollers in PLAYER car, is worn or defective.
  8. use clean disk cleaner for to clean the OPU optical pick up or lens. see the block similar to dvd player conventional
Jul 20, 2012 | Panasonic Televison & Video
Panasonic SA DK10 starts reading discs, gets to 00 and then stops
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case this don't solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 08, 2010 | Panasonic SC-DK10 System
Player shows '' No Disc'' even when inserted with a disk
When player says no disk, even if the disk inside, and you hear a whirring and clicking noise when you insert a disk, that means that the CD lens is dirty or defective, and the CD drive cannot read the initial CD track, and returns no disk.
Try first using a CD cleaner disk, if that does not work, then you will need to take the apart the unit to clean lens with isopropyil alcohol and cotton sticks.
See also the following websites on how to clean the lens, use a cleaner disk first:
Gizmo Highway DIY - Clean your CD player lens
Lens Cleaning CDR CD-RW (how?)
DVD Not Working
Mar 04, 2009 | Sony Televison & Video
The SA-1 cannot read CD and Display is off
lens is dirty ........clean the lens using the lens disk cleaner...........still problem continues the laser head is not picking up the disc...........need to replace laser assembly.......
Feb 04, 2009 | Marantz SA-1 CD Player
Panasonic SA-HT75 doesn't recognize disk
First clean the laser lens with a cleaner disc,if don't work you gotta clean it manually with a q tip wet on alcohol clean the lens then with the dry side finish the clean.Good luck
Jun 02, 2008 | Panasonic Audio Players & Recorders
Error Code:DVD HO2
try to clean it first bring cleaner cd from radio shack. put your cleaning disk in and let it run-remove cleaning disk and put your disk and try,
Nov 03, 2007 | Panasonic SC-HT75 System
Won't play
This DVD home theater system has a defect that is not being addressed by panasonic. The Optical lens and or DVD Motor will give out after 2 to 3 years for no reason. It will start saying "No Disc" and will not play any DVD or CD. To repair this it will cost you £100.00 to £135.00 to repair. An authorized panasonic repair company told me that if I repair this it will last me up to 3 years and I would have to fix the DVD Player again. The dvd player model number is SA-HT70 and the number for the system is SC-HT70. The SA-HT70 is the dvd player that is not reliable. Without warning in 2 to 3 years you will have to repair the optical lens or dvd motor which will not be covered by Panasonic.
Feb 12, 2007 | Panasonic SC-HT70 System
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
