It powers on but turns off within a second - Televison & Video
  • 3 Answers
First of all what brand is it? If it is a Samsung LCD and turns off with a beeping sound, then the red light flashes, your lamp bulb is heating up and probably has dust around it. Remove the lamp from the back, use some air duster spray and put it back in, if this does not fix the problem, you probably need a new lamp unit.
Posted on Sep 09, 2009
How do I fix a flat screen tv that powers down within seconds of powering up?
The ballast may be going out. That is the board that the lamp wires connect to.. The power supply board may have a few components starting to fail as well.
TV Parts Universal TV Stands DLP Chips ShopJimmy has all the parts for your TV.
Jul 05, 2015 | Samsung Televison & Video
Programming keyless entry to 95 landcruiser
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (Do NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Within 3 seconds the power door locks should cycle automatically indicating successful
entry into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remote simultaneously for 1 second.
B. Immediately after letting go of the lock and unlock buttons, press the lock button by
itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle once
indicating successful programming. If the door locks do not cycle, or cycle twice.
repeat steps A and B in step 6 as your remote has not been accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Close drivers door.
Oct 29, 2013 | 2008 Toyota Land Cruiser
HP dv7-1245dx laptop turns on then off within seconds
ok try this first
remove battery completely
plug in ac adapter
try power on sequence
report back here
Jun 20, 2012 | Computers & Internet
I need to know how to program a remote alarm control for a toyota 4runner 2000
f
1. Start with the following conditions: you are in the vehicle
a. Key is out of the ignition
b. Drive door is open ( all other doors are closed)
c. Driver door is unlocked (other door locks don't matter)
2. Insert the key into the ignition (don't turn it) and pull it out.
3. Perform these steps within 40 seconds:
a. Cycle the power locks 5 times. Use an even pace and try
to go relatively fast.
b. Close, then open the drivers door.
4. Perform these steps within 40 seconds:
a. Cycle the power locks 5 times (same as before).
b. Turn the ignition to ON then back to OFF.
c. Turn the ignition to ON then back to OFF.
d. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should cycle (automatically)
indicating successful entry into programming mode. Return to step 1
6. Perform these steps within 40 seconds:
a. Press the LOCK and UNLOCK buttons on the transmitter
b. Immediately after letting go of the lock and unlock buttons,
press the lock button by itself and hold for 2 seconds.
Within 3 seconds, the door locks should cycle ( LOCK then
UNLOCK) once-- indicating successful programming. If
the door locks don't cycle, or cycle twice. Repeat steps
6a and 6b--this remote has not been accepted.
c. Repeat steps 6a and 6b for EACH transmitter that will
operate the vehicle. Including any old transmitters.
7. Close the driver door.
Also can check this procedure: http://www.toyota-4runner.org/60925-post2.html
Hope this help.
Mar 22, 2010 | 1997 Toyota 4Runner
Need to program a new remote
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Here are the instructions for programming the 99-02 4Runner Keyless Entry factory remotes:
c. Driver door
6a and 6b--this
Hope this helps you, it did me greatly-- Good luck,
Mar 04, 2010 | 2000 Toyota 4Runner
Lost remote and like to program new remote. HELP. 2000 prado vx.
1. Start with the following conditions: you are in the vehicle a. Key is out of the ignition
3. Perform these steps within 40 seconds: a. Cycle the power locks 5 times. Use an even pace and try
4. Perform these steps within 40 seconds: a. Cycle the power locks 5 times (same as before).
6. Perform these steps within 40 seconds: a. Press the LOCK and UNLOCK buttons on the transmitter
Good luck and hope this helps.
Nov 04, 2009 | 2000 Toyota Land Cruiser
How to program the keyless entry for my 1996 Acura TL.
Hi, Stacie,
here's the instructions for a 97 TL - I hope they're the same.
Note:
Entering the programming mode cancels all learned keyless remotes, so
none of the previously programmed remotes will work. You must reprogram
all of the keyless remotes once you are in the programming mode.
You must complete each step within 4 seconds of the previous step to keep
the system from exiting the programming mode. You must program remotes
within 10 seconds of each other
1. Turn ignition switch to ON (II)
2. Within 4 seconds press the LOCK or UNOCK button on one of the remotes.
(An unprogrammed remote can be used for this step.)
3. Within 4 seconds turn ignition switch to LOCK (0) position
4. Within 4 seconds turn the ignition switch to ON (II)
5. Repeat steps 2, 3 and 4 two more times using the same keyless remote
used in step 2
6. Within 4 seconds press the LOCK or UNLOCK button on the same remote.
Make sure the power door locks cycle to confirm you are in programming
mode.
7. Within 10 seconds press the LOCK or UNLOCK button on same remote.
8. Within 10 seconds press the LOCK or UNLOCK button on all other
remotes you want to program. Make sure door locks cycle after you push
each remote button to confirm system has accepted the remote.
9. Turn the igniton switch to LOCK (0) to exit programming mode.
10. Test remote(s)
Hope this helps :)
John
Mar 26, 2009 | 1998 Acura TL
Keyless remote
Note:
all of the keyless remotes once you are in the programming mode. You must complete each step within 4 seconds of the previous step to keep
used in step 2
mode.
10. Test remote(s)
Dec 24, 2008 | 1998 Acura TL
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
