Acer aspire m5620 freezes, no mouse, monitor shows image but interacion. hard drive activity - none. must hard boot.
    Scholar:
  • 121 Answers
Hi..
Restart your PC and keep tapping F8.. choose startup repair and let it diagnose and fix --
Hope this helps !!
Posted on Sep 07, 2009
Acer media all in one wont go past acer screen
does it show the post screen. That screen would show the load process for the hard drive, cd-rom, keyboard, mouse and so on. If it does try to get into the BIOS and check to see if you can reset it to the factory defaults. If it won't let you into the BIOS and it just freezes there you more than likely have the I LOVE YOU virus and you will need a new mainboard because that virus destroys the BIOS. Once you have a new mainboard you can not allow the hard drive to boot you need to run the restore soft ware or the virus will hit it again because the virus is still on the hard drive and if it boots it will activate again. If you do let your hard drive boot and it happens again you will have to pay for another main board because the company isn't responsible for the virus destroying the the main board again.
Apr 24, 2016 | Acer Computers & Internet
Black screen
does it boot from the normal screen or just an external monitor?
Dec 07, 2012 | Acer Aspire One PC Notebook
When I turn on my acer aspire one d250 it says Check cable connection..! PXE-E63: Error while initializing the NIC PXE-M0F: Exiting Intel PXE ROM No bootable device -- insert boot disk and press any...
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery which will erase all user data and restore the operating system to its factory default when you purchased the netbook.
Jan 03, 2011 | Acer Aspire One D250 (99802378332) Netbook
When i turn on my Acer Aspire 9300 the power comes on but will not boot up. I have even hooked up a external monitor that worked for about a week now NOTHING!!
if nothing showing on screen graphics card problem check the hard drive light is showing during boot up or it's a faulty hard drive to
Nov 16, 2010 | Acer Aspire 9300 Notebook
Possible hard drive failure
Does the splash screen come up? Most of the time if it is your hard drive the ACER splash screen will come up and then a Hard disk 0 error after that. If nothing appears on the screen then you have a bigger issue.
Is there any noise at all (Fan, hard drive spinning)? If so try hooking it to a external monitor to see if there is any movement. You might have a problem with your LCD.
Apr 20, 2010 | Acer Aspire One PC Notebook
Aspire Notebook 5735-4774 won't display on external CRT monitor
If the video chip on the Aspire motherboard is OK then the image on the external monitor would be OK. If not then the video/motherboard is faulty.
To gain access to data on the hard disk, remove the hard disk and connect it to an USB hard drive adapter and plug it into a working computer's USB port. The computer will see this as an external hard drive.
Alternately -
You can put the hard drive in an USB hard drive adapter case and use it as an external USB hard drive.
Dec 21, 2009 | Acer Aspire 5735 Notebook
Acer aspire one - its died!!!
If it was just the hard drive, I would expect the video to come on and say something like "no boot device."
However, since you went through the steps here and see absolutely no video (even none on an external monitor), I would suspect a motherboard failure.
Be sure that when you hooked up an external monitor that you pushed the Fn key and the appropriate special function key (maybe F7) that switches between the laptop and external monitor. If you have done that (pushed the combination several times to switch displays), then you can be pretty certain your video card (if a separate card) may be bad.
I'm not really sure if this machine has a separate video card. The specs say it's a ATI Radeon Xpress 1100. This leads me to believe it may be a separate card.
If it's just the card that went bad, you can replace it. Otherwise, the motherboard will have to be replaced.
Good luck. You can do that, but if you're not confident, you best take the machine to a repair shop.
Apr 26, 2009 | Acer Aspire 3100-1405 Notebook
Computer will not load up - frozen on acer start screen?
Are you sure the monitor is plugged into the correct port? Also, check the monitor cable for bent pins. A small move shouldn't make this kind of difference. Eliminate that power strip and just plug the computer and monitor into an outlet.
Mar 24, 2009 | Acer Aspire™ T180 PC Desktop
Acer x223w issues- freezes
I think it could be an issue with resolution. Since the monitor is so big, some video cards, I noticed, can't support the high resolutions that the monitor can, if that doesn't work try 16-bit instead of 32-bit.
Feb 25, 2009 | Acer 22" X223w LCD Monitor
Acer aspire 5520-5334
press insert usually solves the problem
Jul 13, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
243 people viewed this question
David Payne
David Payne
