i am not able to open any file with finger touch mouse at the lap top. cursor moves but does not get command when i try to open a document with finger touch at the click pad. even now when i have to ask this question and submit it to u i have to take theassistance of the left click key.pl solve
Try opening system preferences and looking at the settings for mousepad. If that all appears to be set correctly try resetting the power manager.
1.Shut down the laptop
2.Remove the battery and disconnect from the power
3.Push the start button and wait 5 seconds.
4.Reinstall the battery and reconnect the AC power.
5.Reboot the macbook you should be able to confirm that the power manager has reset when the light on the magsafe adapter turns off briefly as the power manager resets.
If that fails to correct the problem consider replacing the trackpad.
Hope that helps
My apple aluminum keyboard works when plugged into my Powermac G5, but my macbook air does not...
(More)
My apple aluminum keyboard works when plugged into my Powermac G5, but my macbook air does not recognize it Any idea why?
Power up and get the sound and then a white screen on a MacBook Air without a disc drive. Have tried...
(More)
Power up and get the sound and then a white screen on a MacBook Air without a disc drive. Have tried the things mentioned in chapter 3 of the manual to no avail. Would a software reload work using another PC at this stage or is it a terminal hard disk problem as somebody has suggested to me?
