Question about Echo Garden
Replacing rotor cover on Echo SRM-210 trimmer - need installation help - installs OK - sticks when trying to open throttle
5 Suggested Answers
SOURCE: How can I remove Echo 230 SRM trimmer head?
Remove the top off the string housing and remove the nut in the center.
Replace the top, as if you have finished loading string, Lock it in place as you normally do and the turn the entire housing pulling up at the same time. Spring and the white mechanism will pop out and then all you have to do is lift the string housing base off the trimmer head. Note it will take you a few tries but once it comes off you will see how easy it is to remove. I was amazed. Got my info from a sales person at Home Depot.
Posted on Aug 01, 2009
  • 10 Answers
SOURCE: What is the correct ratio for fuel mix for a ECHO
A 50:1 ratio with 89 Octane fuel can be used in all ECHO 2-stroke equipment, provided the oil is ISO-L-EGD and JASO M345 FC/FD certified. ISO-L-EGD and JASO M345 FC/FD oil must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines.
A 50:1 Ratio = 1 US Gal. 89 Octane + 2.6 fl. oz. ECHO POWER BLEND OIL
Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more.
Use only fresh gasoline with a minimum octane rating of 89 through 93 (mid-grade to premium) at all times. The gasoline suppliers blend mid-grade and premium gasoline with greater amounts of detergents and anti-oxidizing additives to keep the engines clean. Lack of these detergents and additives in a 2-stroke engine will cause a heavy build-up of varnish and gum deposits on the piston surface and ring grooves. Regular unleaded 87 octane or lower gasoline may not contain enough of the detergent additives that are needed in a 2-stroke engine to keep varnish, gum, and tar deposits from forming. Use of 87 octane fuel may shorten the life of the engine.
ALL TWO-STROKE OILS ARE NOT EQUAL!
ECHO POWER BLEND OIL, is manufactured exclusively for ECHO, Inc. and meets the (ISO) International Standards Organizations highest performance rating of ISO-L-EGD for Air Cooled 2 Stroke oils and is JASO M345 FC/FD REGISTERED. Years of research and testing have resulted in an oil that is fully compatible with fuels containing 10% ethanol and can be used in all air - cooled, outdoor power equipment 2-Stroke engines at 50:1 ratio. ISO-L-EGD and JASO M345 FC/FD rated oils must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines. Always look for the JASO M345 FC/FD square logo and registration number to ensure you are using the highest quality 2-stroke oil for your ECHO product.
ECHO POWER BLEND OIL is made for high revving, (7,000 RPM and up) air-cooled 2-stroke engines that are E.P.A. and C.A.R.B. emissions certified. Make sure the oil has a EGD and FC/FD certification. Oils that meet ISO, EGA/EGB/EGC and JASO FA and FB are of lesser quality, designed for applications such as water-cooled boat engines, low RPM lawnmower engines, or snowmobile engines and should not be used in ECHO Engines. Prior to 1997, oils were not manufactured to these higher standards. Some or most of the oils were simply 30 or 40 weight 4-stroke engine oil with minimum amounts of additives. ECHO POWER BLEND OIL is the highest quality 2-Stroke oil available and will provide maximum protection against engine wear and carbon buildup.
Posted on Sep 05, 2009
Dolfoff
  • 148 Answers
SOURCE: need to install new lever trigger lockout but
Navigate to your exact model using Echo's public website.
Click the "WEB-PLUS PARTSEARCH" link at the bottom right of their homepage.
Posted on Sep 26, 2009
SOURCE: Need Help Installing U-Turn Trimmer Head on Echo SRM-210
It is ridiculous, there are a bunch of bolts, and then a multi-fit brochure showing a grid of nonsense.
There are instructions on the inside of the package, however that is how to string the line.
Posted on Feb 06, 2011
Echo SRM-210 Boggs down when at full idle
Hi Bobbi Jo:
Here's a link that will get you the user manual.
http://lawnandgarden.manualsonline.com/manuals/mfg/echo/srm210.html?p=1
Page 24 details exhaust carbon removal, and Page 25 gives carb setup info.
Hope this help.
Cheers
Jun 22, 2016 | Echo Garden
Echo trimmer model SRM 210 I'm trying to install a brush blade but cannot get the plastic 3/4" nut off. Any advice?
There is a hole in the dust cap on the side of the bottom of the gear box. Stick a small screwdriver, or a 1/8 drill bit to lock the gear box. Once you have locked it, you simply unscrew the nut.
Hope this helps.
Nov 04, 2010 | Garden
How to add line to an echo srm 210 weed trimmer
See pages 27 and 28 of the owners manual here:
http://dl.owneriq.net/8/854215d5-44e4-4b5d-b773-77b331fd73b3.pdf
This certainly explains it better than I can.
Oct 01, 2010 | Echo Garden
Sep 19, 2009 | Echo Rapid Loader, Trimmer Head
Need to install new lever trigger lockout but can't figure out how to install spring on echo trimmer srm 210
Sep 17, 2009 | Echo Garden
Open Questions:
Garden Logo
183 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
