Question about IBM ThinkPad R40e Notebook
Can'd access bios and can't boot from HDD
How do I access the bios? I had previously disabled the Hard Disk from bios and now can't boot from HDD and Bios is also not accessible. I am using XP. I don't have a recovery CD but have a bootable disk, but can't load XP from it, it stops at reboot. Currently accessing the drive using Linux Mint Live CD
Thanks
  • 916 Answers
To get into the BIOS as the machine is starting up Tap the F2 key. It may also be F1, Delete, or Esc so try all of them until one works.
Posted on Sep 07, 2009
    Problem Solver:
  • 14 Answers
Tap The Access IBM Button T
Posted on Sep 22, 2009
RESET HARD DISK DRIVE LOCK FOR ACER ASPIRE
Step 1:
Which model of acer laptop ? there are many
The BIOS (Basic Input Output System) is designed to check the integrity of the computer hardware and launch the operating system. The BIOS also has basic security features that prevent unauthorized access to the computer by locking the hard drive with a password. The password is required in order to launch the operating system. That option can be disable without an changes to the operating system.
Turn your computer on. Press "Esc," "Del," "F2" or "F8" to access the BIOS. Use the arrow keys to go to the "Security" tab. Press "Enter." Highlight "HDD Lock," Boot Password" or "Hard Drive password" using the arrow keys. Press "+" until "Disable" appears. Go to the "Exit" tab, highlight "Save and Exit" and press "Enter." Press "Y" when prompted to reboot your computer without the hard drive password.
Feb 19, 2013 | Acer Aspire Computers & Internet
Compaq Mini 700EL hdd not recognised
If you are installing Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Oct 08, 2012 | Computers & Internet
7at startup my laptop says ( press the ESC key for startup menu.. and when I do it says ( ESC...pause startup
Hi there.
Please do the following:
  1. Press F10 immediately upon turning it on. See if it will enter BIOS. If it does, go to Diagnostics and run Hard drive test.
  2. If it will not let you enter BIOS, boot up using the recovery disk.
  3. If it will not let you do the above, I suggest that you remove the hard drive and re seat it. The video will give you an idea on how to remove the hard drive.
Let me know what happens.
Thank you!
Aug 25, 2011 | HP Computers & Internet
I forget the hdd password
to remove the hdd password do the follwing
1) Restart your computer. Note that during computer restart, the screen goes blank for 3 to 5 seconds. Text then appears and the operating system boots up.
2) As soon as the first text lines appear on the screen, press the "Del" key on your keyboard to enter the BIOS setup
3) Navigate to "Security" in the BIOS menu using the arrow keys on your keyboard
4) Navigate to the option "Hard Disk User Password" and press "Enter
5) Navigate to a hard drive, press "Enter" and select "Disable" to remove the hard drive password.
6) Press "F10" to save and exit the BIOS settings. Computer booting resumes.
this will remove the hdd password
Jan 15, 2011 | Computers & Internet
I am trying to replace my HD in my Acer aspire 5520 from 160GB (Hitachi of 5400 rpm and 8 MB) to 500GB (Hitachi of 7200 rpm and 16 MB). Acer sent the recovery cd. I used an enclosure hard drive to format...
first ..Im not sure I understood how you installed windows on the new Hdd..but I sow that you didn't do it in the laptop ..
the correct way is to see if the laptop is seeing the Hdd..and to install the windows directly on the hard disk installed into the laptop ...by using boot-able installation disk with the operation system ..Cause if you install it on another device ..or other way ..it will not recognize the devices present on the laptop ..and most likely to give you a blue screen ..and errors like the one you just got ..
Another thing ..you have to go to bios settings ..advanced st-up ..most likely ..and see the Hdd in there ..and on its settings to disable the AHCI function ..cause if you do not have a disk with sata drivers ..the laptop with the AHci function enabled will not see the hard disk ..and this is the error and what it means ...basically it didnt found the boot device ..cause of this function probably enabled in bios..It is not hard to disable ..just press F2 on start up ..and go to BIOS settings ..and look for the feature that allow you to see the Hdd and disk drive ..and set them u ..it is either the device .or the advanced settings..Im not remembering exactly ..its the second or the 3rd feature..and in there you will find a function named...AHCI...this have to be disabled in order that the laptop to see and function with the HDD ..otherwise it will say that the HDD is missing or the boot device is not present ..
Aug 29, 2010 | Acer Computers & Internet
Cant boot
If you are sure no one has tampered with it and entered a HDD password and it is not prompting for a password then it is most likely a HDD failure. It is possible the BIOS will still recognize the HDD. Try disconnecting and reconnecting the HDD if you can access it there should be screws on the bottom marked with a cylinder symbol.
Jan 24, 2009 | Toshiba Satellite A205-S4617 Notebook
Cant boot
In your bios you should be able to change your settings for the hdd. Make sure everything in bios matches your hdd & then save changes & reboot. Hopefully that will allow you to enter windows.
Jan 24, 2009 | Computers & Internet
PC won't boot if SATA drive connected, drive works fine if plugged afterward
Try Hirens Boot CD. It has a lot of programs on it to detect format etc.
I think your hard drive has a missing or corrupt MBR and it needs to be replaced.
When I have had a hard dive not recognized I hve used Super Fdisk to format and reset hard drive.
On the boot disk
Nov 03, 2008 | ASUS K8N-E Deluxe nVidia nForce3 250...
Hp dv6000
There is option in BIOS called something about automated SATA recognition or similar - disable it. It is under System configuration. And if you are putting new drive in then run full test from BIOS (Hard drive selftest - takes about 79min.)
I tried to reinstall Windows Media center on my HP dv6000 because my previous hdd crashed - When I put in installation cd - it said that it can't find hdd. I spent week to figuring that out. The thing is - as far as you haven't disabled that SATA thing in BIOS - PC doesn't recognize hdd. But only with Windows media center edition. With all other windows xp - there is no such problems. Strange.
Feb 11, 2008 | Computers & Internet
Hard Disk and Booting issue
go into your BIOS and on the bottom of your screen there should be a (last good config) of (fail-safe config) value for one or=f the F1 to F12 buttons. also. are you running a 4gb hdd??? or is that a typo? anyhow, XP REQUIRES 2GB at all times free if your hdd is running at less that that (cause its full) your boot up could be messed around. finally make sure that the little plug on your hdd is across the Master or cable select pins not the slave as this can cause probs too. good luck.
Sep 22, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
IBM ThinkPad R40e Notebook Logo
696 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
