Question about Hitachi 65S500 65" HDTV-Ready Rear Projection Television
I have a 65 inch hitachi 65S500. Can I tip this
I have a 65 inch hitachi 65S500. Can I tip this unit 90 degrees and stand it on end during moving it or is there a way to detach the bottom section from the top to move it around a corner into a tight area? It would be nice to dissassemble it to move it but I do not want a mess getting it back together. Is it Modular?
  • chino0365 Sep 20, 2009
    I turned on my Hitachi 65S500 tv and it says locked on the screen. What can I do to unlock it?
SOURCE: HITACHI 65XWX20B - How to disassemble the cabinet?
The 65XWX20B comes apart in 2 pieces - there is a top half and a bottom half.
- The bottom half houses all of the electronics, projection lenses, etc. It is very heavy and should be moved with care.
- The top half is basically just the screen.
I have moved this Television multiple times, even up and down from a 3rd floor apartment!
- First remove the screws holding the top and the bottom, the important ones are on the sides of the TV.
- This is important, I suggest 3 people do this part: Slowly lift the top away from the bottom half of the TV, but -not- very far. There is small wiring harness that that attaches the top of the TV to the bottom to a circuit board. This must be unplugged by one person while the other 2 hold the top half of the TV slightly above the bottom half. Note carefully where this plugs in so that you can reassemble easily.
- Once this is disconnected the TV is much easier to move, although still quite heavy and bulky. Do not turn the TV on its side - keep it upright while moving.
Reverse this process to put it back together.
Once you have done it once it is quite easy.
Good luck.
Posted on Aug 10, 2008
SOURCE: Moving my TV
I had the same situation. You can't take it apart, but you can cut it in half!!! Take the rear panels off, disconnect the wiring (simple clips), cover the lenses (plastic wrap and elastics) and then a take a reciprocating saw! You will see the best line of attack. Moved the bottom half down first, put some Elmer's wood glue on it, then placed the top half back on. Waited for it to dry, reconnected and everything worked fine!!!
Posted on Sep 15, 2008
Ecollier2012
  • 3459 Answers
SOURCE: cant adjust the blue its all over screen its a
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
  • 33 Answers
SOURCE: need to move a 57 inch hitachi rear screen proj TV
No, do not attempt this as you will damage the unit if you try to take it apart and reassemble it. They are not built for dis-assembly and re-assembly. They are easily damaged. Rather, rent a large industrial hand truck and use several straps to secure it to the hand truck and about three men to help you. It is about the only way to do it.
Be careful... there is a fragile mirror inside which can be broken if bumped abruptly.
Posted on Apr 29, 2009
techman
  • 3130 Answers
SOURCE: 50 inch hitachi tv, shadow behind writing and crooked screen
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon, senior tech/tvrepairkits.com
Posted on Jul 06, 2009
How do i replace the plexiglass on the 65in hitachi, it was cracked while moving. Also where can i buy the plexiglass to replace the cracked one
According to Sears Parts Distribution, the panel (which unfortunately is not a piece of plexiglass) can be purchased at this website:
http://www.searspartsdirect.com/partsdirect/part-model/Hitachi-Parts/Television-Parts/Model-65S500/0505/0333200/50022581/00001?blt=06&prst=&shdMod=
at a price of $468.15
It may be worth investing perhaps in a new Mitsubishi DLP, which can cost as little as $999 at places like Costco. Though I did read that your particular TV has an excellent picture.
Jan 21, 2011 | Hitachi 65S500 65" HDTV-Ready Rear...
2002 audi tt 225 bhp cranksharft torque settings
Crankshaft torque settings for 2002 Audi TT 225 BHP:
1. Main bearings: Renew bolts = Yes
2. Main bearings: Stage 1 = 65 Nm
3. Main bearings: Stage 2 = 90 degrees
4. Big end bearings: Renew bolts / nuts = Yes
5. Big end bearings: Stage 1 = 30 Nm
6. Big end bearings: Stage 2 = 90 degrees
7. Flywheel / driveplate = 60 Nm + 90 degrees (use new bolts / nuts)
8. Crankshaft pulley / damper centre bolt = 90 Nm + 90 degrees (use new bolts)
Nov 25, 2010 | Audi TT Cars & Trucks
We have an approximately 6 year old Hitachi 65S500 TV that was damaged beyond repair from a power surge. We are currently in small claims court w/ our village in an attempt to seek damages. What would be...
Hello. Surfing this site 'cause mine's broke. But, maybe a non-technician can help just the same. If you're going to court, try asking some of the paralegals how values are determined for court cases. OR, what kind of depreciation the judge may use by taking the value at purchase less a percentage per year owned. I say ask paralegals because you'll find them in civil courts records departments (places like a register of deeds office). You could also try asking an insurance adjuster, but not anyone you do business with as they often use simple inquiries to blackmark you in the national insurance database sending your premiums up. Hope this helps!
Sep 05, 2010 | Hitachi 65S500 65" HDTV-Ready Rear...
What is the torque settings on the head bolts for 2002 nissan x-terra 2.4litre?
① Step 1: 22 ft. lbs. Step 2: 59 ft. lbs. Step 3: Loosen completely then retorque to 22 ft. lbs. Step 4: 18-25 ft. lbs. Step 5: Plus 86-91 degrees ② 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs. ③ The cylinder heads and the lower intake manifold are installed together Step 1: Tighten the cylinder head bolts to 22 ft. lbs. Step 2: Tighten the cylinder head bolts to 43 ft. lbs. Step 3: Loosen the cylinder head bolts completely Step 4: Tighten the cylinder head bolts to 84 inch lbs. Step 5: Tighten the intake manifold fasteners to 35 inch lbs. Step 6: Tighten the intake manifold fasteners to 13 ft. lbs. Step 7: Tighten the intake manifold fasteners to 12-14 ft. lbs. Step 8: Loosen all intake manifold fasteners completely Step 9: Tighten the cylinder head bolts to 22 ft. lbs. Step 10: Tighten the cylinder head bolts 60-65 degrees Step 11: Tighten the cylinder head sub-bolts to 80-105 inch lbs. Step 12: Tighten the intake manifold fasteners to 35 inch lbs. Step 13: Tighten the intake manifold fasteners to 78 inch lbs. Step 14: Tighten the intake manifold fasteners to 70-84 inch lbs. ④ 10-12 ft. lbs. +60-65 degrees ⑤ Step 1: 72 ft. lbs. Step 2: loosen completely to 0 ft. lbs. Step 3: 29 ft. lbs. Step 4: Plus 75 degrees clockwise Step 5: Plus 75 degrees clockwise ⑥ Step 1: bolts 11-22 19 ft. lbs. Step 2: bolts 1-10 29 ft. lbs. Step 3: bolts 1-10 Plus 60-65 degrees ⑦ Step 1: 20 ft. lbs. Step 2: loosen to 0 ft. lbs. Step 3: 14 ft. lbs. Step 4: Plus 85-95 degrees ⑧ Step 1: 31 ft. lbs. Step 2: Plus 60 degrees ⑨ 83 inch lbs. ⑩ Stud bolt: 11 ft. lbs. Nuts: 31 ft. lbs. ⑪ Step 1: 72 ft. lbs. Step 2: loosen completely to 0 ft. lbs. Step 3: 29 ft. lbs. Step 4: Plus 90 degrees clockwise Step 5: Plus 90 degrees clockwise ⑫ Bolts: 17-24 (M8) 16 ft. lbs. Install rear main seal Bolts: 1-16 (M10) 26 ft. lbs. Bolts: 1-16 (M10) Plus 90 degrees clockwise ⑬ Step 1: 33 ft. lbs. Step 2: Plus 84-90 degrees clockwise ⑭ Intake manifold collector: Bolts and nuts: 8 ft. lbs. Stud bolts: 61 inch lbs. ⑮ Intake manifold: Bolts and nuts: 5 ft. lbs. and than to 21 ft. lbs. Studs: 8 ft. lbs.
Jan 10, 2010 | 2002 Nissan Xterra
Where to buy hitachi projection screen
First, I can tell you most of the Hitachi sets sell both inner and outer screens as a unit--most of the time it is the only way they are available.
Get me the exact model number and I will try to get you part number, cost, and place where it can be ordered if it is available.
If this is helpful rate this solution as I do this here for free.
Regards, SD TECH
Dec 17, 2009 | Hitachi 65S500 65" HDTV-Ready Rear...
I was moving my 65' hitachi tv and the wind busted the screen
You can buy the replacement screen from www.searspartsdirect.com I ordered one for mine the part number is UX26083. When you order look for online coupon codes because I got 20% off of mine when I ordered and came out to $300 with shipping included.
Jul 11, 2009 | Hitachi 65S500 65" HDTV-Ready Rear...
I would like to know if I can use the DVI-HDTV input terminal to plug in my computer and use my Hitachi 65S500 as my monitor with a wireless keyboard and mouse.
Yes. You need to have a DVI connector on your PC for direct DVI-DVI connection or you can buy a DVI-VGA cables for around $25 bucks. Then, after connected, go into your display properties and adjust your settings. Hope that helped.
Dec 22, 2008 | Hitachi 65S500 65" HDTV-Ready Rear...
PROTECTIVE SCREEN
I need to buy protective and projection screens for my 65" hitachi hdtv due to tare in both sreens done by maintenance people.
Mar 26, 2008 | Hitachi 65S500 65" HDTV-Ready Rear...
65S500 will not turn off
Check to see if you have it set to do the Magic Focus on turn-off. It is in the menu under setup.
Nov 06, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Hitachi 65S500 65" HDTV-Ready Rear Projection Television Logo
176 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
