Question about Pentair 400k Minimax Ch Ng Mv Heater
No power to heater minimax 400 pentair
I was heating my pool for about three hours and everything was fine.Now i have NO power to my heating unit at all and my pool pumps won't turn on even though i have power to the jandy box.I checked the breakers and nothing tripped.Checked all the gfci plugs tested and reset still nothing.Tripprd the breakers and waited 15 minutes and reset still nothing.
    Champion:
  • 246 Answers
Turn all breaker off that are related to the pool equipment even the one at the main panel. if not check for power 220 v at the timer if power check the wires if not power the breaker may need to be replace
Posted on Sep 13, 2009
Pentair Minimax NT heater -- panel doesn't respond.
if connected to control make sure heat is enabled
Jun 22, 2017 | Pentair Minimax NT Heater
We have a Pentair 400 heater. First time to heat
You probally just need to increase your water flow. On the pipes going to the heater their should be a valve bridging the inlet and outlet pipes. This valve should be closed about 80-90% so it forces more water through the heater. I hope this helps.
Jan 01, 2010 | Pentair MINIMAX NT TSI IGNITER
Minimax 400 heater not operational
what is ok on the water pressure? th heater need from 40 to 60 gpm in order to work properly clean the filter and let me know
Sep 10, 2009 | Pentair Minimax NT Heater
I have a Pentair MiniMax NT heater about three years old. The unit is making a loud "popping" sound when heating. I think its the heat exchanger from what I am hearing. Can a heat exchanger be cleaned out?...
the heat exchanger can be reamed or replaced but it is quite a job; replacing the heat exchanger is very expensive and time consuming. unless your pool chemicals are extremely out of balance, most especially low ph from using tablet chlorine or too much acid the heat exchanger should not have worn out this quickly. the best solution if you do not have a pool serviceman is to call Leslies Pool Supply or a trained Pentair service tech. It may be worth the service call to have the problem diagnosed by a pro.
Jun 24, 2009 | Pentair MINIMAX NT TSI IGNITER
Pentair Minimax NT 400 heater. fan keeps coming
Sounds like the controller is the problem. This is the circuit board that has the display and controls on it. You can swing that panel open and try tapping on the white plastic cover the controller is under that. This might get the fan relay to release but you will have to replace the controller it will stick again
Jun 06, 2009 | Pentair Minimax NT Heater
Pentair Minimax Nt heater wont turn on and heat,
Bad thermistor. The yellow wire that plugs into the control board. Lick finger and touch prongs. Heater should come on
May 29, 2009 | Pentair Minimax NT Heater
Pentair Minimax Nt heater wont turn on and heat, "err" message
temp sensor get the new one with yellow wires.should do the trick.
Jan 19, 2009 | Pentair Minimax NT Heater
Pentair 400k Minimax Ch Ng Mv Heater Logo
523 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
