Question about JVC Video Cameras
Warning 3300 unloading failure
I have a JVC HD 100u. I was shooting a couple of days ago and ran the camera until the battery went dead. After I changed to a new battery and turned on the camera, "warning 3300 unloading failure" started flashing. Once I tried to take the tape out, it started to open but stopped. If anyone has a suggestion I would appreciate it!
SOURCE: camcorder tape door opening
I had a problem the same as yours and I found the problem on the ribbon wire connected to the board where all the control button is located ( stop, rew, play, fwd pause). The problem occur because everytime you eject the tape from the loading mechanism the ribbon wire also move like your cutting it into pieces. sorry for my english hope you get the idea.... wait for the photo and i'll show you what i mean.. hope this will give you the solution you need.
Posted on Sep 15, 2006
  • 221 Answers
SOURCE: Stops during rec, error code E - 5 in display
E-5 is a "reel lock" error. This means that one or both of the reels that move the tape through the deck have stopped turning and are not sending a feedback signal to the system control cpu. This deck does use a drive belt, and has a clutch mechanism to transmit power to the reels. Check the belt and clutch for wear (the belt has a tensioner; the tension screw may be loose.).
Posted on Aug 22, 2007
  • 13433 Answers
SOURCE: Lens stuck open
hey, I had the same problem when I accidentally droped my camera, some parts in the mechanism are probably broken or jammed.
Most likely repairs required.
Posted on Apr 13, 2008
welcomejee
  • 10594 Answers
SOURCE: Playback problems started suddenly
Hello Bob92116 & PenName,
Camcoder needs lapping of video head, because it became dirty and this can be done at nearest Sony repair shop. I think it doesn't cost much.
In my point of view, reason of this clogged head is your Old Tapes having enough amount of dirt on tape.
Posted on May 27, 2008
SOURCE: Aiptek won't turn on
This may sound a little daft but have you fitted the battery the right way in the slot. My wife didn't. Caught us out
Posted on Jun 21, 2008
Screen went black, except for narrow band at top
If your camera is not dead, It is surely dying. Perhaps just a flat cable lost connection inside your camera, But more likely the electronics is on the end of life. My DX7590, started to act strange a few year ago, but I managed to shoot pictures still. I could not look back what I had shot, but I still made lots of pictures, till also shooting was impossible. (I could get the pictures from the memory card with an external card reader on my computer. My next step was again (a better) compact, but since over 2 years now I'm using a DSLR. I have learned a lot about digital photography with my Kanon camera's.
Jan 22, 2014 | Kodak EASYSHARE Z1285 Digital Camera
97 HD Dyna wide glide electrical system dead
Hi Anonymous, check your main fuse/circuit breaker for continuity and check your battery ground cable at both ends. Good luck.
Jan 31, 2013 | Harley Davidson FXDWG - FXDWGI Dyna Wide...
Jvc lt-z32s2 went dead and makes a static sound at back of unit.
check weather the power cord or component at the power supply board get burned.
Oct 02, 2012 | JVC Televison & Video
Doesen't turn on
Check If the old batterys did leave oxidation or battery fluid from leaking , could Cause bad connection, as the got Very hot , or 2 check If the New batterys are ok ,
Oct 26, 2017 | Canon Speedlite 430EX TTL Flash
I have a 1995 Jeep Grand Cherokee with a 4 month old battery.A couple of the power door locks quit working a while back and my husband went out a couple of days ago and sprayed them with WD 40 but they...
check the voltage on the battery with a volt meter, it should be around 12.6 to 13 volts, if not charge battery with a charger, after charge try to start vehicle, if the vehicle starts use your volt meter at the battery again, the voltage should be around 14 to 14.5 any lower and the battery isn't being charged and the alternator should be checked and or replaced to solve the problem..
Feb 28, 2011 | 1995 Jeep Grand Cherokee
A couple of weeks ago I went out to start my Kia Sedona 08, however, found it was dead. I connected up battery to another car and jump started first time (and ran it for 30mins). It then started fine for...
Sounds like a battery to me. The cold doesnt drain the battery it just makes it more difficult to produce enough energy to crank the car. If the battery is weak already, the cold just makes it worse. Replace it and move on!
Dec 08, 2010 | Kia Sedona Cars & Trucks
Car ran four days, went to start it and 'click', nothing. Went to repair shop who said it needed a new battery, installed. Ran another four days, went to start and 'click', nothing. Repair facility now...
If there is no power from battery to altenator, than the altenator is bad. Even some new ones can do that. Do check all your battery cable wires including ground wires. Make sure they are all clean. also tight.
Sep 08, 2010 | 1995 Lincoln Mark VIII
I've had my camera for about 3 years now and have never had any problems until a couple of weeks ago. When I turned the camera on, it forced me to reset date/time and would occasionally show aperture 00...
Try getting new trusted brand batteries like duracell, And also if it forces you to change the D/T just change it. Also try getting a new memory card. (trusted brand). If none of this works then there might be a prob. Maybe someone dropped it. Try asking the company 2.
Hope this helps
Jun 26, 2009 | Canon Digital Rebel XT / EOS 350D Body...
Using up batteries in two days
if you are using "AA" size, do NOT use typical alkalines in your camera, they die too fast. Buy rechargable NiMH batteries and a charger at Walmart or somewhere. These will hold a charge longer for you. Also be sure to turn off teh camera when not shooting because the camera is always draining battery life when "on."
Apr 27, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
*istD battery problem
Battery charge indicators don't measure actual charge but voltage because there is no cost-efficient method to measure battey charge directly. Instead, batteries are designed so that voltage goes down with charge. Now, the difficult thing is that not all batteries behave in the same manner. It is actually very hard to predict how a battery menufactured by xyz behaves. I would guess that Pentax engineers did not have Energizer AA's in their mind when they defined the voltage alert level. I would suspect that the battery status indicator is calibrated for the CR-V3 batteries that were included with the camera body, or something else. Only wild guesses above... And yes, I have encountered weird inidicator behavior with AA batteries, too. But not with CR-V3. I bet your mobile phone battery indicator plays tricks, too.
Sep 08, 2005 | Pentax *ist D Digital Camera
Video Cameras Logo
349 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
