Question about LG RZ-42PY10 42 in. HDTV Plasma
I removed the back cover and powered the unit up. Neither if the fans is functioning. I can trace these back to a small (regulator) board to the lower left of the chassis. Does this offer us any clues?
  • arnaud73 Sep 07, 2009
    The screen is working fine at start. The fan do not turn at all. Is that could be an issue of over heating, the screen to go red and make it to switch off for security?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The red tint on the screen is due to a bad lamp or a faulty inverter board. It could also be a dry joint somewhere in the drive electronics. Lamp faults are often intermittent as they can be dependent on temperature among other things. This can make internal shorts come and go. Service Engineers will often take the back off the set and gently tap the neck of the tube to prove or disprove the lamp problem.
Please get this checked as disassembling the TV could be very dangerous as it has very high charge even when it’s switched off.
There is an internal short on the circuit board of your TV & due to this the TV screen first turns red and then after overheating (due to short circuit on the board) it turns itself off. However, these kinds of short circuits on display board cause the lamp to go bad.
If you can't see the fans moving and neither anything appearing on the screen then due to shorted connections and which resulted in overheating of lamp. Further checking the TV circuit is not advisable as i have earlier told you that the TV contains very high voltages even when it’s switched off and fiddling with any unknown part/circuit can be fatal.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 07, 2009
Why outdoor unit not coming on even after setting temperature too low
First thing check your ciruit breakers or fuses and make sure you have power to the outside unit. Remove the small cover on the outside unit that covers the contactor, capacitor, circuit board, etc. Then set the thermostat to call for a/c. Check and see if the contactor is pulled in supplying power to the fan and compressor. If it isn't check for 24vac that powers the coil in the contactor. If the contactor is pulled in supplying power then your capacitor could be the problem. You can check it with a multimeter with the capacitor check function. If it looks swollen then it is probably bad. Let me know what you find and I can give you some more stuff to check if that isn't it.
May 29, 2010 | Heating & Cooling
New unit just quit no compressor, no fan, breaker not trip, blower unit working fine
Remove the access cover from the outside unit. Find the contactor. It is the part that has the high voltage incoming wires attached. There is a button/bar in the center of the contactor. Use a insulated screwdriver or a wood pencil and push the bar in. If the unit starts you will have to trace the low voltage circuit from the thermostat and air handler to the outside. 24 volts should be present at the low voltage contactor terminals via the defrost board. If you have 24 volts to the defrost board,turn off the outside power, remove the red low voltage wire from the defrost board then reattach it. The board may be tripped on a low voltage fault.
Report back here with your result.
Oct 18, 2009 | Carrier 38BRC036 Air Conditioner
Duo-therm fan only runs on low
useually a sticking fan relay in the controll board this is the closeest unit to a home based cenral air system and i would leave this one to the experts if you want to trouble shoot there is a detailed wiring diagram on the back side of the pc board cover on the fan and compessor unit it self there is a seperate relay for each speed on your unit make sure getting power to selected relay if not trace wiring and do continutity tests back to themostat
Jul 28, 2009 | Dometic Rooftop RV Air Conditioner
Projector turns on the power light flashing and lamp light solid
Here's the fix: Take off the top cover of the projector. Unplug the wire leading from the two fans in the back of the unit to one of the circuit boards in front of you. Just trace one wire from fan to board. Unplug at board. Turn unit on and it will again turn on, show HP splash screen and then shut down, like it should, because the fans are now disabled. After it completly shuts down, plug the fan wire back into the board. Turn the unit back on and, presto, its working again. It will not turn off.
Try it!
Jun 12, 2009 | HP Digital Projector Vp6120 Multimedia...
Magic Chef MCO153UW
You absolutely need the magnetron cooling fan to be working, or the magnetron will be destroyed!
It is part # 3511800100 and you can order it for less than $20 here.
Far less than a magnetron.
Aug 28, 2008 | Microwave Ovens
Self check
Unfortunately, none of that will fix your machine, as this is a common fault with these units.
Fortunately though, it can be fixed.
In 99% of cases this is caused by a faulty regulator on the main power board.
The power board is located on the right hand side of the unit. The regulator is IC001 which is mounted on a thin metal strip which acts as a totally inadequate heatsink. This means that this component constantly works at temperatures beyond its tolerance.
Because of this it usually lasts a couple of years and then starts causing problems. The Self Checking syndrome is typical. If the regulator burns out completely, it can take other components with it, blow fuses and scorch the circuit board.
If you are competent in using a soldering iron with care, order an STRG 6353 regulator. These can be obtained online from a number of suppliers.
Disconnect your DMR E55 from the power source and remove the lid. Next, remove the fixing screws from the circuit board on the right where the regulator is located. Carefully remove the multi connector on the left side of the board. Remove the screw above the power connector on the rear of the unit. The power board can now be removed from the cabinet.
Using a small pair of wire cutters, clip all five pins from the old regulator as close the the top of the board as possible. Undo the screw securing it to the heatsink and remove the old regulator which can now be thrown away.
Next, using your soldering iron, remove what's left of the pins from the printed board and with desoldering braid, clear the holes ready to accept your new regulator. Be careful because if you over heat the print it can lift away from the board.
Use a little heatsink compound on the back of your new regulator, poke the pins through the circuit board and then secure it to the heatsink. I usually fit an extra heatsink on these units which helps to reduce heat and prolong the life of the new component.
Next, resolder the 5 pins on the print side of the board. Use a magnifying glass and make sure you haven't missed anything or bridged connections in error and caused short circuits.
Now put the board back. This can be a little tricky but it's easy enough if you take care. Refit all the screws and carefully reconnect the multi connector.
If you have followed this correctly, switch the unit back on, pop in a DVD and give it a try. Unless you are very unlucky, Your DMR E55 will no longer repeatedly self check and will operate correctly.
Whilst it saddens me to hear that some of you guys would toss your DMR E55s into the trash can for such an easily repairable problem, please do not attempt this unless you are confident in your own ability.
If anyone tells you the laser is shot or the drive needs replacing, take absolutely no notice of them because they don't know what they are talking about. The above solution WILL fix your machine if you follow the instructions correctly.
Finally, do check that the fan operates but remember it is temperature controlled and will not activate until it is needed. Do not assume it is faulty because you do not see it working straight away. I have repaired lots of DMR E55s and I have never found a single fan or fan control circuit to be faulty. That's not to say it can't fail. good luck
May 22, 2008 | Panasonic DMR-E55 DVD Recorder
2001 525 AC fan
The indoor and outdoor unit have separate breakers,so one can run with the other.It would not cool. Check the separate breakers to be sure their on.Take the cover off the t-stat, you will see a red and a green wire.remove these and touch them together.If the fan runs you probably have a bad thermostat.If it does not .The problem is inside the indoor unit.There is a disconnect or breaker on the cover. remove it, pull the cover off and put the dis connect back in.If the fan hum ms or turns slowly you have a bad capacitor or fan motor. Try the cap. first,if still not running the motor is most likely the problem.Should the motor not try to run or hum,it could be a blown fuse, you will see it in a small circuit board if you have one.It could be the circuit board itself,or a bad fan relay.A meter can help you trace this if you have one.Be careful as there is 220 volts powering this unit.Good luck
May 21, 2008 | 2007 BMW 525xi Sedan
Stuck in self check mode
Hi
Unfortunately, this is a common fault with these units.
See my earlier solution show below.......
Ok guys, you asked for a fix for the DMR E55 Self Checking cycle. Here goes.
Next, using your soldering iron, remove what's left of the pins from the printed board and with a solder ****** or desoldering braid, clear the holes ready to accept your new regulator. Be careful because if you over heat the print it can lift away from the board.
Finally, do check that the fan operates but remember it is temperature controlled and will not activate until it is needed. Do not assume it is faulty because you do not see it working straight away. I have repaired lots of DMR E55s and I have never found a single fan or fan control circuit to be faulty. That's not to say it can't fail. good luck...
May 01, 2008 | Panasonic DMR-E55 DVD Recorder
Hp Laserjet 8150 LVPS replacement
It is located in the back of the printer on the bottom. Remove the back cover. With the power off, remove the formatter board by loosening the two big screws and pulling out. Remove the plastic cover by the side of the formatter cage. Remove the fan housing by the power connector by removing the two screws, disconnect the cable and pull straigt out. Now remove the big cable at the top and unwind from the high voltage ps. Remove the white connector in the middle of the low voltage ps. Next trace the white cable wires running from the ps to the dc controller and remove the cable from the dc controller. Now trace the fan cable for the fan in the front of the ps and remove it from the dc controller. Remove all the screws which secure it to the frame and pull straight out. Move the fan in front from the old ps to the new and reverse instructions...
Take off the large metal side cover. Look down at the bottom of the printer. The large box is the LVPS. Remove the screws holding it and follow the wiring up to where it plugs in and pull the connectors off. You'll also have to remove the fan above the LVPS on the top right side of it. You will have to take the fan mounted on the LVPS off and put it on the replacement LVPS as they don't come with fans.
Oct 23, 2007 | HP LaserJet 8150 Printer
In 99% of cases this is caused by a faulty regulator on the main power board. The power board is located on the right hand side of the unit. The regulator is IC001 which is mounted on a thin metal strip which acts as a totally inadequate heatsink. This means that this component constantly works at temperatures beyond its tolerance. Because of this it usually lasts a couple of years and then starts causing problems. The Self Checking syndrome is typical. If the regulator burns out completely, it can take other components with it, blow fuses and scorch the circuit board.
If you are competent in using a soldering iron with care, order an STRG 6353 regulator. These can be obtained online from a number of suppliers. Disconnect your DMR E55 from the power source and remove the lid.
Next, remove the fixing screws from the circuit board on the right where the regulator is located. Carefully remove the multi connector on the left side of the board. Remove the screw above the power connector on the rear of the unit. The power board can now be removed from the cabinet. Using a small pair of wire cutters, clip all five pins from the old regulator as close the the top of the board as possible. Undo the screw securing it to the heatsink and remove the old regulator which can now be thrown away.
Next, using your soldering iron, remove what's left of the pins from the printed board and with a solder sucker or desoldering braid, clear the holes ready to accept your new regulator. Be careful because if you over heat the print it can lift away from the board.
Now put the board back. This can be a little trick but it's easy enough if you take care. Replace all the screws and carefully reconnect the multi connector.
If you have followed this correctly, switch the unit back on, pop in a DVD and give it a try. Unless you are very unlucky, You DMR E55 will no longer repeatedly self check and will operate correctly. Whilst it saddens me to hear that some of you guys would toss your DMR E55s into the trash can for such an easily repairable problem, please do not attempt this unless you are confident in your own ability.
Jan 03, 2007 | Panasonic DMR-E55 DVD Recorder
LG RZ-42PY10 42 in. HDTV Plasma Logo
116 people viewed this question
Computer Repairing
Computer Repairing
