Question about Sony (ICSSP20) TV Input
I am changing from 75ohm to compisite cable hook-up and need to set tv to proper input, how do I do that?
    Genius:
  • 1,027 Answers
The TV should have an input that is called 'video 1' or 'source 1' etc. consult the TV's operating manual.
Posted on Sep 07, 2009
Sound robotic on samsung ln22a450c1d
change the sound volume in channels settings /avc and try
Jan 01, 2014 | Samsung LN32A330 32 in. LCD TV
Can I install an external antenna to this TV?
it is located next to the power plug and if you have more than one tv in the house you will need to use a splitter
Oct 16, 2013 | Sony KLV-S23A10 23 in. LCD HDTV
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How to install with time warner cable box
If your tv has auxilary RCA audio and video inputs on it (red, white, yellow), you can go directly from the dvd player into the TV. Choose the corresponding input (video 1, aux 1,2 or similar) on the TV to watch dvd, possibly controlled by the TV remote. Therefore it doesn't run inline with the cable box via a 75ohm cable.
Apr 15, 2010 | Philips Magnavox DVD/VCR Dual Player
I am trying to hook up my Philips 19PR19 (made in 1998) tv to the dish network receiver, it has 3 prongs diff. colors attached and the cable cord is already to go in the wall...I don't see anywhere on the...
Because your TV is an older one, it might not have, what they call RCA inputs (the 3 colored cable) Red-audio right, White-audio left, Yellow-video. If I understand you.
You do have the option of using the 75-ohm coaxial cable inputs. Signal comes in from outside to the 722k, Output of the 722k to the 75ohm coax input on the back of the TV. Tune your TV to ch. 3 or 4. Make sure the switch on the back of the 722k is set to the same.
If you really want to use the RCA colored cables, then you need to buy an RF modulator, which integrates older tv's to newer products. But usually dvd players, not necessarily cable boxes, but it would work if hooked up correctly.
You plug the RCA red, white and yellow from the 722k, into the rf modulator, choose channel 3 or 4 on the modulator
Connect 75ohm coax cable from rf modulator to TV 75ohm coax cable input. Choose channel 3 or 4 on the TV.
Hope this helps.
Apr 07, 2010 | Philips 19PR19 19" TV
The HDMI doesn't work properly
HI
The resolution is only set by the sending unit, in your case the cable box. You need to change this to at least 720P something the your TV can handle.
Now once you have down this, to try and solve your HDMI problem I suggest you do the following.
Switch-off your cable box and the TV set, unhook the HDMI cable.
Now reinsert it carefully to make sure it connects properly on both sides.
Now first switch on your TV and set the input to Video 6 ( your HDMI channel )
Now wait for 30 secs. Switching on your cable box.
Do not press anything and check if your picture now stays on without shut-down.
if the menu and other startup screens on the cable box is not flickering, but the normal picture you might have a HDMI conflict with your TV set.
O, you cannot change the input types.
Hope this helps!
Dec 28, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a toshiba 27a41 model tv where do i hook up an antenna
hok it to the cable in connector that says "in from cable or VHF or Ant in" You may need a 300-75ohm adapter depending on your antenna
Sep 27, 2009 | Toshiba 27A41 27" TV
ONKYO TX-SR606 Single output to TV
Hi there. for your receiver, the only time it can upconvert is when you go out as HDMI. In your current hookup (component out to tv) the signal from your cable (using a composite) will not be able to pass through the component cable. This means you either have to hook up your cable box using a component cable as well or add a composite cable (yellow) from monitor out of the receiver to the tv. Page 22 of the manual will show a diagram of the video signal flow. hope this helps.. ^_^
Dec 02, 2008 | Onkyo TX-SR606 Receiver
Co-ax input broke off in back
Good Day, aprilpatino;
If your TV has video, components or HDMI inputs you can by pass the 'rf' connector. You must have a cable, sat box or vcr in order to do so. Hook cable output from 'box' to the TV's input. Change TV's input with remote for the proper 'hooked-up' input.
Good Luck, Big Irish.
Jul 09, 2008 | Televison & Video
No video
Is the video cable composite or s-video? the output from the receiver to the sets line input (1,2,3,s-video) must be the same on most receivers. If the game console uses composite (yellow rca connector) to the receiver, the same cable must be the same from receiver to TV. Some receivers do "up convert" to s-video or to Progressive scan (red,green,blue rca connectors) and do not follow this rule. Yor set needs to be switched to the correct input as well. None of the receivers I have services thus far hve the 75ohm cable lug for RF. Check all the cableing and repost if you find something new or different.
Jun 06, 2007 | Panasonic SA-HE70 Receiver
Sony (ICSSP20) TV Input Logo
51 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
