Question about Sylvania LC370SL8 37 in. LCD Television
Picture quality is terrible...not sharp and crystal clear
This is a brand new TV. The picture is not sharp and clear on any channel. We purchased the new "gold" cables and that helped only a little. Fiddling around with the settings options doesn't help at all. It's almost as if there is a film over everything. Also, the top and bottom of the picture is cut off.... We are totally unhappy with this TV...PLEASE HELP.
  • laurdel Nov 22, 2008
    I have the same problem, a pixelated image that cannot be improved by changing Contrast, Sharpness, or any of the other settings.  I get the same poor resolution whether watching cable, satellite, or DVD.
  • matthewbrami Feb 01, 2009
    Same thing as all of you
How do you switch the aspect ratio?
Posted on Jan 12, 2008
Set the aspect ratio to 16:9 and the top and bottom of the picture will reurn. Promise.
Try adjusting your contrast to help the filmy looking picture.
Posted on Jan 02, 2008
TV picture not clear
First we need to know a little more details about the kind of TV you have, the kind of service (Cable, Satellite or off Air).
Comparing showroom to your home is also something we need to know. Was the showroom using Cable or Satellite. Satellite will always have a better picture quality wise.
If you are using composite input for the signal path between TV and source this would not produce a High Dif picture Composite = Yellow for video, red and white for audio. If you are using Component source that will produce a HD signal cable is RED/BLUE and Green with different audio.
The best quality is using an HDMI cable, this is all in one cable and the sources is the best. One last thing, if you are using the RF *cable as source it will not give you a quality signal.
Apr 22, 2014 | Intellian i9P US HD System with 85cm Dish...
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
I have a 1080 with 120 and my picture is not clear. If it's not a hd channel it really is terrible and if it is hd channel it still is not in full focus. The picture is not sharp. I am really disappointed...
I am assuming your set is new. Ask for it to be serviced under warranty. This sounds like your set is defective for some reason.
LCD TV sets are known for their exceptional sharpness and performance when having a good quality signal source, and especially with an HD programs.
Jerry G.
Nov 14, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Do we need to buy an antenna to get this TV ready for Digital TV?
LCD TV refers to the substance that creates the picture quality (it would be either LCD or Plasma or Tube) and HD refers to a crisp clear picture that can be attained. So your TV is an LCD (Liquid Crystal Display) TV that is capable of receiving and displaying HD (High Definition) Picture.
What you need to check for is whether the TV has a built-in Tuner. This will either be SD (standard definition) TV Tuner or an HD TV Tuner. The box it came in will tell you or you may still have stickers on your TV.
If it has a built-in SD tuner you will be able to pick up HD channels but in a lower quality. In this case you will only need to plug the TV into a Wall-socket antenna or rabbit-ear antenna.
If it has a built-in HD Tuner you will be able to pick up HD Channels in full HD quaility picture. Simply by plugging the TV into a Wall-socket antenna or rabbit-ear antenna.
If your TV does NOT have a built-in TV-Tuner then this TV is clasified as "HD Ready". Which means that you have to purchase a Set Top Box (STB). you can get either HD or SD set top boxes. In this instance you will plug the cable from the wall socket into the STB then from the STB into the TV using either an HDMI cable (as long as your TV has an HDMI input) or through RCA cables which will be coloured Green, Blue and Red (i think red)
By the Way - best picture quality is from a wall-socket antenna.
HDMI = High Definition Multimedia Interface
STB = Set Top Box
High Definiton RCA cables will also be refered to as YPbPr/YCbCr (depending on equipment)
LCD = Liquid Crystal Display (the method used to make the picture on your TV screen)
If you have anymore questions, ask away.
May 26, 2009 | Philips Televison & Video
Just purchased tv and the quality of the picture is still fuzzy tried to mess around with the resolution but it still isnt very sharp at all
The TVs produce picture using entirely different methods. Usually the colors and especially level of black color are better on plasma, LCD will have some trouble various shades of gray and black especially shading on peoples faces etc.. This is not a defect in the LCD just a limitation in current technology.
Apr 26, 2009 | Televison & Video
Poor TV Reception
I bought an antenna at my local dollar store and have been satisfied since. I use mine in my office at a hospital, only for the television. I just cannot get cbs for some reason. try the converter box, which I will be purchasing soon.
Dec 19, 2008 | Haier (PDTB7) 7 in. Portable Television
Picture quality poor/ picture not varying in menue
PURCHASE A NEW TV AND THROW UR OLD ONE AWAY
Jan 12, 2008 | Sharp 25L-M100 25" TV
Picture quality
i have a similar problem, when watching football the picture is terrible,but when im watchin ordinary tv its great
Dec 28, 2007 | Samsung LN-R409D 40 in. LCD Television
Picture not HD quality while watching HD channels
Make sure you are using an HDMI video cable for optimal picture quality. Also, you must be using an HD reciever.
Jun 12, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sylvania LC370SL8 37 in. LCD Television Logo
344 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
