There is a big blue blog on the screen that has gotten bigger over the past six months. it is a projection tv
  • 8,457 Answers
Ur convergence is dead.U know how to solder? Tries this website.Tv Repair World.com buy ur model of tv.The convergence kit use the parts in it,replace it.
Posted on Sep 07, 2009
Blue circle in the center of picture
I need to know what color you got the circle in because one of your lamps went out and needs to be repaired this circle is only going to get bigger an bigger and shall i go on? Easy fix buy the new one and have it put in around $90 bucks plus labor.
May 24, 2009 | Hitachi 46F500 46" Rear Projection...
Samsung HCN4226W yello stain around the screen
Its a problem with the screen, Plasma depends upon a chemical and eletrical impluses to create a display... I think you might just want to change the screen.
Jan 10, 2008 | Samsung HCN4226W 42" Rear Projection...
I have a big green and blue circle on my screen
You are facing this problem due to a burnt polarizer filter just past the blue filter for the blue chip.
This TV has a three chip design with red, blue and green chips.
Get new polarizer for your tv from panasonic .
Mar 02, 2009 | Panasonic PT-50LC14 50" Rear Projection...
52'' sony tv rear projection turns blue
it sounds like the blue crt is failing Pull the front off and turn the tv on
When it still has a good picture tap the blue crt
if it flashes blue with lines across the screen then you know it is a bad crt
It might not be worth fixing
Good luck
Jan 26, 2009 | Sony KP-57HW40 57" Rear Projection...
Blue dots and blue cloud. Sony 55" LCD
Sounds like magnetic interference,Do you have a speaker close to that corner?If so you need to relocate it a little farther away.
Jan 06, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
HDTV is getting blue dots and the right side has turned blue
These issues are problems in the light engine (optics block)
the dots are called "starfield" and the geometric is "roadmap"
replacing the light engine will fix the issue. for awhile, sony was extending the warrany on the engine for these issues only, but that may have expired.
part # A-1606-008-A
Nov 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Yellowish spot on the lower left hand corner of tv screen
Good Day, There is a device that can be used to correct your concerns. Symptoms can be correct by EE PROM CORRECTION TOOL:
LSUQ0100. Instructions included. Try calling 1-800-458-6053. It's under $100.00 and takes about 1 hour from start to finish. Good Luck, big IRISH.
Jul 07, 2008 | Panasonic PT-52LCX65 44" HDTV
Mitsubishi ws65613 no picture or sound, blue screen only
Good Day;
Blue screen that has gotten worse over the past few days, I would suspect fluid on your signal board.
The three CRT's in the TV has coolant that tries to keep them cool but they have a problem with the 'glycol' leaking out of it's chamber.
Take speaker grill off, remove panel and look on the right side of opening. Look for fluid on the board, shinny substance, it's hard to see so look closely. That is the most common problem.
2&3 are the CRT's or the CRT's drive circuit.
Good Luck, Day,let me know, Big Irish.
Jun 13, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Red Green Blue Across The Screen
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm · http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Dec 06, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Picture size too large
Did you try chaging the aspect ratio in the setup menus yet?
Feb 19, 2007 | Philips 46PP9302 46" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
