Question about Samsung RS265LABP Side by Side Refrigerator
Fridge md #rs255basb showing a compressor fan error, freezer works fine fridge will not cool, stays at 50f
  • hangerking Sep 07, 2009
    Thanks, Will check it out
  • 430 Answers
I am making an intelligent guess since I am not there....I think the start relay is going out and I would have this checked real soon. If you feel capable, remove the rear cover and check the connections at the compressor. Look for a burnt or discolored wire and let me know what you find. Or the capacitors or the condensor has been flawed. Can you tell me the symtomps. Such as any sound.
Posted on Sep 07, 2009
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
Hola: my GE PSC25PSTBSS sometimes is not cooling in the fridge side. some days it is at ~50F and other days at 37F. one year ago it was not cooling anything and GE technician replaced the fan unit from the...
edtorres: if the freezer side and ice maker are working fine then the problem may be the damper that allows cooling into the refrigerator side is having trouble opening or the controls to the damper are defective.
Mar 06, 2010 | Refrigerators
Model gss20iepcbb freezer side works fine ...fridge
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
Fridge is not cool enough 12 degrees C. Freezer is -3 degrees
The cooling air outlet is clogged or blocked. Cool air is not entering the fridge section as indicated by the low temperature in the freezer section. It shows that the compressor is working fine and the system is good. If your unit has a brushless DC fan motor that circulates air to the fridge section, it may not be working properly or not working at all. You have to replace it.
Nov 08, 2009 | Refrigerators
Freezer working but fan not on in fridge - where to locate fan?
May be ice build up - happened with mine. Had to defrost completely (unplug for 24+ hours) then it worked fine on restarting.
Aug 15, 2009 | Amana ABB1927DE Bottom Freezer...
Can't get temp in fridge to go below 50 F. Freezer works fine and makes ice. It started when our area had a heat wave and the inside of our house was 85+ most of the day. The ice maker stopped working,...
Have you checked the evaporator fan(freezer fan), This problem is hard to detect because the fan spins but not fast enough to circulate the chilled air thru the freezer and refrigerator.
Aug 01, 2009 | Refrigerators
Freezer works fridg dosent stay cold
When plugging it back in, check to see if you can feel air circulation (from vents in the top-rear) on the refrigeration side.
Check again after the fridge starts to warm.
There is a fan which is supposed to distribute the cooled air from the freezer to the fridge; this may be failing after the fan has warmed from operation. The bearings in these is primitive and can get sticky impeding the fan's rotation. Replacement of that fan is not covered by the (longer) compressor warranty.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge not cooling down stays at 68 degrees
you may be low on freon..thats one thing about fridges if you are low one side will still stay cold while the other side gets warm
Jan 12, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer is staying cold (below 0), but Fridge won't cool
could need re-gasing but all f/freezer have 2 thermostats 1 for the fridge and 1 for the freezer
Aug 15, 2007 | Kenmore 63074 Top Freezer Refrigerator
Refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
Samsung RS265LABP Side by Side Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
