Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
I have a lawnmower with a tecumseh 173 cc engine that has experienced a sudden loss of power what could be causing this and how do i fix it
  • rugrats1 Sep 08, 2009
    It only has one throttle speed. It starts fine but sounds like it is running at half speed or less. It runs fine just no power, is easy to start, doesn't miss etc. Air filter is clean, oil is good and clean.
  • bulldogchief
    bulldogchief May 11, 2010
    When you say "loss of power", what do you mean? Does it start but at full throttle it runs like it's at half-throttle? Will it not start? A "loss of pwer" can mean several different things.
  • 388 Answers
Ok, on the left side of the engine at the rear part of the block is a speed governor on Tecumseh vertical shaft engines. there is a spring that connects the governor to the throttle, if that spring is somehow broken or disconnected it can cause the problem you are experiencing. Check for that spring...if necessary, you can order a replacement through your user manual...cheers!
Posted on Sep 08, 2009
Car has lose of power. slow to 60 then wont go any faster.
Sudden Loss of Power while driving 65+ on the freeway ' Forums ...
www.teslamotors.com/.../sudden-loss-power-while-driving-...
Tesla Motors Dec 16, 2014 - 31 posts - ‎21 authors
My car is back at the factory getting "worked on"...sudden loss of Power and control while driving on the freeway...has anyone else experienced this? ... My son was driving his '04 Volvo on the highway, when all of the sudden the car started slowing down, despite how much he ... Last I heard they were 60.
Engine Intermittently Loses Power - Avensis Club - Toyota Owner
Nov 30, 2015 | Cars & Trucks
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
Mowing at mid throttle, suddenly the engine started over revving. Acts like governor isn't working. Every time I try to restart it instantly starts to over rev.
According to Amie Taylor on http://homeguides.sfgate.com/lawnmower-revs-up-down-100220.html "Airflow Issues A lawnmower that hunts and surges may be experiencing something as simple as an airflow issue. If the air that the engine requires to run is blocked, especially sporadically, it can cause the engine to slow down. When the blockage moves or clears, the engine may suddenly rev up in response. To fix this type of problem, check the air filter to ensure that it's not clogged with dirt and debris. Check the vented gas cap as well. Both issues can cause reduced or sporadic air flow, and clearing them will fix the problem.
Spark Plug Problems Another problem that can cause revving and dying of a lawnmower engine is a faulty or poorly adjusted spark plug. Check the spark plug to see if the wire is connected to it firmly and not wobbling about. If it is connected correctly, remove the spark plug to see if it's covered with corrosion. If so, a simple scrubbing with a wire brush can restore it to working order. If necessary, replace the spark plug with a new one. Check the spark plug gap with a spark plug gauge to ensure that it's adjusted to the proper setting recommended in your owner's manual.
Carburetor Adjustment A carburetor that's incorrectly adjusted is a common cause of poor engine idling that results in hunting and surging. Fortunately, most lawnmowers have two screws that allow you to adjust the carburetor yourself. One screw controls the idle speed while the other adjusts the idle mixture. Check the manual if you're unsure of the location of the idle adjustment screws. Start the mower and allow it to run for 5 minutes. Then slowly adjust the screws tighter or looser in turn until the mower runs and idles smoothly.
Fuel Problems A particularly simple fix that can be at the bottom of many lawnmower idling problems is old or contaminated fuel. If the fuel has been left in the mower while it was stored over the winter or while the mower has remained unused, drain it and replace it with fresh fuel. If you have gas-powered blowers and trimmers that use a mixture of 2-cycle oil and gasoline, check to see that you've not placed that mixture in the lawnmower inadvertently."
May 10, 2015 | Garden
Why wont briggs & stratton 173 cc Engine yard man walk behind mower wont start when hot
Try replacing filter element. May swell when hot causing loss of air.
Check with Partstree.com 877-970-2662. They may have an answer for you.
Jul 17, 2014 | Briggs & Stratton Garden
22 in persoal pace 195 cc Tecumseh oil leaks onto
There is a crankcase vent on top that may be cracked or out of place causing the oil to leak or the upper crankshaft seal may be leaking.
Jun 03, 2010 | Toro Lawn Mower With Toro Power Tools
Just looking for the oil typ and amount for this engine 173 cc ohv
if its a briggs and stratton engine of older vintage always use straight 30 wt. about a litre will do then check level
Apr 02, 2010 | Mtd 19 In. 173 CC OHV 3-In-1
Brand new lawnmower. Trouble starting and when it does start it has no power. When you move it to cut grass it konks out
Does it have a Tecumseh engine? If so it sounds like a broken or bent flywheel key. It may be a flywheel key on any engine but the Tecumseh seems to break easier. That is not a bad thing because the reason they break is to reduce other, more expensive breakage in the engine. If you need help replacing it, write..Good luck...Lee
Sep 20, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Oil leak tecumseh engine OVRM120-22053F
oil seal is worn out from durbis wrapped around crankshaft need to replace oil seal by removing blade and hub
clean cranksaft with fine sand paper
a sharp awl punch in the outter edge corner of seal on a 45 degee angle then slide seal off
heres the manual.pdf page 75
Mar 23, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
714 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
itsman
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
