Question about Nintendo DSi Black Console
Dsi low on system memory even with new SD card inserted
Does that mean that mean that you have to delete stuff on main screen?
Posted on Sep 15, 2009
    Sergeant:
  • 161 Answers
You have too much memory block used in your dsi system, that doesn't mean the SD card is full, its your system like you said.
Posted on Sep 09, 2009
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
I have forget my memory card password which use in nokia 2690
If you lose or forget the password for your phone's memory card, there is no way to recover the password or access the data, even by taking your phone to a Nokia Care Point.
However, you may still be able to use the memory card if you can successfully format it. Formatting the card will not work in every case.
Formatting will erase all the data on the card.
To format you memory card:
1) Select Menu>Memory. Your phone shows the details of the memory card.
2) Select Options>Format memory card.
Thanking you
davevipul197
May 11, 2011 | SanDisk 2GB microSD Memory Card
My son has a ds lite with an r4 card, i am thinking of getting him a dsi, i know his r4 card will not work but would i be able to remove the sd card and insert it into a new r4i card? would his games work?...
Yes, his games will work, as the DSi will be fully backwards compatible. You should be able to use the same memory card that he uses in the DS Lite.
Mar 10, 2011 | Nintendo DSi White Console
What is the maximum size of SD card for a dsi?
The Nintendo DSi and Nintendo DSi XL are compatible with most SD Cards with the following specifications:
    Memory Capacity: Up to 32 GB (Gigabytes)
    Type: The Nintendo DSi and Nintendo DSi XL support standard SD cards as well as high-capacity SD cards (SDHC) up to 32 GB in size. This includes miniSD and microSD when used with their respective adapters
    Speed: SD Cards with a slow speed may experience slow transfer time when loading files, or may not work at all. Slow transfer times can also occur with SD Cards that have a great number of files on them.
Feb 20, 2011 | Video Game Consoles & Games
DSI not recognising SD card
Can you use that SD card for your photo digital camera or any other device such as card reader ,so you can check quality of that SD card?
Also check brand of that card. In many cases consoles such as playstations, nintendos , have their own brand memory cards, so if your card works on other devices but not on your DSI , you probably need to use their brand.
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Nintendo Game Boy Advance SP Console
For downloading dsi games do I need to get an SD memory card? Is this where the downloaded games are stored? Just bought this so need help! thanks
The DSi only has 256 MB of internal flash memory. If you intend on downloading many games from the online store, you will need an SD card. They can be purchased used from Amazon.com for a low price, though.
Feb 13, 2010 | Video Game Consoles & Games
R4: An error has occured
The DSi has a firewall. The DSi blocks your card. Not a new SD, but a new R4, mate.
Aug 12, 2009 | Nintendo DS Console
I hav htc t-mobile wing i have inserted micro sd card in the sd card slot of it but in the storage card memory it says "total storage card memory : not installed" i have also tried other cards (witch...
Take out the SD card.Turn off the phone and take out the battery. Now insert the new SD card and then insert the battery. Turn it on and then new card should get detected.
Aug 08, 2009 | T-Mobile Wing™ Smartphone
Nintendo DSi Black Console Logo
567 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
