Question about Dryers
HEating element just went out
The Heating element went out and the timer stopped working, can we fix this at home?
    President:
  • 1,922 Answers
Sounds more like either you lost one leg(120)volts to the dryer or the neutral lead could also be open,this would be associated with both your problems,I doubt the element is bad unless you have checked it visually and done a continuity check on it,because the timer doesn't operate either you could have one live leg(120)volts,but with open neutral it wont operate the 120volt timer
Posted on Sep 10, 2009
My machine stopped heating but everything else functions. Can that be repaired?
There is an element in the bottom.
Google
make model element
They appear to be available
Find Bread Maker Machine Heating Element ' eBay www.ebay.com > ... > Small Kitchen Appliances > Bread Machines Bread Machine Parts Finder is the place to find a Heating Element for your breadmaker. Bread Machine Parts Finder has a breadmaker Heating Element ...
Bread Machine Heating Elements - By Bread Machine Parts ...
www.breadmachinepartsfinder.com/catalog/25 Element-ABM300, Welbilt Bread Machine Heating Element ABM300, $9.99. Element-ABM300, Welbilt Bread Machine Heating Element ABM300-1, $9.99.
Bread maker Heating Element ' Bread Machine Parts Finder
www.breadmachinepartsfinder.com/taxonomy/term/696 Skip to main content. Bread Machine Parts Finder logo. Main menu. Home · Comments. You are here. Home. Bread maker Heating Element. Subscribe to Bread ...
Bread Machine Heating Element - Alibaba
www.alibaba.com > Home Appliances > heating > heating element Bread Machine Heating Element, Buy Various High Quality Bread Machine Heating Element Products from Global Bread Machine Heating Element Suppliers ...
What To Do If Your Bread Maker Stops Working? ' Mr ...
www.mrbreadmaker.co.uk/.../what-to-do-if-your-bread-maker-stops-wor... Apr 12, 2013 - Read our guide on dealing with common bread machine problems. ... are colder and the heat element is not working right then your bread will ...
Morphy Richards Breadmaker Parts ' Partmaster
www.partmaster.co.uk/morphyrichards/breadmaker/catalogue.pl?... Morphy Richards Breadmaker parts - repair your Morphy Richards Breadmaker with a Breadmaker spare part from Currys Partmaster. Worldwide and Next Day ...
Morphy Richards 48280 FastBake Bread Machine Heating ...
www.fixya.com > ... > Morphy Richards 48280 FastBake Bread Machine ...heating element for my SDYD 250 bread maker ? After three uses, the unit no longer heats up......I think it is either a bad control board, or a defective heating ...
Breadmaker Spares ' Spares & Accessories
www.morphyrichards.co.uk > Spares & Accessories Buy a Morphy Richards Breadmaker part. Spare parts for Morphy Richards Bread machine.
and a video of how to change.
How to replace the element in a breadmaker - YouTube
How to replace the element in breadmaker
Feb 06, 2016 | Kitchen Appliances - Others
Frigidaire AEQ8700FGO dryer will run (and heat) for about 30 to 60 seconds then stop. 3 lights above start button will flash rapidly. Depressing cancel and start buttons at same time will not work for...
follow this steps and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it
Sep 30, 2013 | Electrolux AEQ8700F Electric Dryer
Dryer wont stop buzzing
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and need replaced. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. replace the heating elements
Jul 09, 2013 | Dryers
I have a Maytag Model LDE4916ACE dryer that recently the timer stopped woking two days ago, the next load it did the same went and went now today it does not heat. Any clue?
the heating element has overloaded and shorted out - new heat element is required along with a new timer switch .
Jul 23, 2011 | Dryers
Dishes come out all wet. Maybe the heating element but would there be any other potential?
You are right -almost-. When the heating element is not working properly and dishes doesn't dry, I don't think the heating element went bad. It's more likely that other part is causing the problem. Perhaps the timer went bad.
When the timer is broken, the heating element doesn't get power to dry the dishes. By the way, the timer are also called electronic controls or control panel. I believe it needs to be replaced.
Aug 29, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
Oven elements just stopped working
If I understand your use correctly, you were using the oven to heat the space? Or for baking?
Regardless, it sounds as though the elements have failed. If you used the oven for heating the space (with the door open) the broiler element comes on during preheat of the oven to get the oven to temperature more quickly. The elements are NOT designed to heat a space, and will quickly burn out if used in this manner.
Jan 23, 2009 | Ovens
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
