Question about Panasonic PT-47WXC43 47" Rear Projection Television
0 characters
1 Points
Color settings for an older panasonic tv trying to adjust the color setting for this older panasonic tv, it seems the dark colors are really dark and there faces are really red. Model# CT-32g19j
This is not a projection set; but a picture tube set or CRT (Cathode Ray Tube) technology. If the set is working correctly you should be able to go into the menu and set the color, brilliance and contrast to get the right color and picture intensity. If the controls don't give you what is correct viewing it may be over age and need an adjustment of the internal chroma circuits - which may cost more than the set is worth since it is quite old. Hope this helsp.
Oct 08, 2014 | Projection Televisions
a model number would help to give an informed answer.
Dec 04, 2012 | Panasonic Projection Televisions
How do I know the model of my projection panasonic tv
All sets made by Panasonic and others have a label on the back with model number, serial number and date made. The serial number only is used for non technical purposes.
If you have a problem be sure to post the model number so I or another expert can give you help.
regards, sd tech
Sep 29, 2011 | Panasonic PT-52LCX65 44" HDTV
I need advice or help ect...
Greetings babygirl4,
Most likely you need to perform convergence on your unit. It can be found in the setup menu of your television.
I hope this helps!
Go Ahead. Use Us.
Jun 23, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic Television
The CT-32G19 is a standard TV you will need a converter
Mar 19, 2008 | Projection Televisions
I need a jumbo universal remote code for my Sanyo ds25520 tv
May want to call the manufacturer:
Sanyo MC Customer Service: (English only)
Phone: (800) 877-5032
Fax: (870) 630-4223
7:30 am - 7:00 pm CT Mon-Fri
7:30 am - 4:00 pm CT Sat
Of course, you can check with your local Best Buy, Wal-Mart, etc. Or see what's for sale online.
Mar 17, 2008 | Projection Televisions
Color spots on 61" LCD Panasonic rear projection tv
had the same problem on my 52" LCD rear-projection Panasonic,
contacted Panasonic support (number is on their website) and after
several transferred calls, they set up a service call with an area
service rep, who callled the house that evening to confirm appointment.
He came to the house, removed the set back cover, and installed an
EEPROM upgrade, problem is fixed and was told problem will not re-occur.
No cost due to Panasonic extending the warranty to fix known issue with
sets. (Mine was over 3 years old).
Mar 11, 2008 | Projection Televisions
Panasonic PT-47WXC43 47" Rear Projection Television Logo
515 people viewed this question
Top Panasonic Projection Televisions Experts
Jaime Hernandez
Josh Whitehead
Josh Whitehead
Are you a Panasonic Projection Television Expert? Answer questions, earn points and help others
