Question about KitchenAid 24 in. KUDS25SH Built-in Dishwasher
I have a KitchenAid dishwasher model#KUDC25CH.The problem that I am having is the touchpad control panel all of a sudden is lit up like a Christmas tree. Just about every red indicater light is lit. The DW will run but I dont know what kind of wash it is performing or at what stage the cylce is in. I have tried canceling the cycle,I have tried child lock/unlock,I have cut the power to the unit for a few minutes hoping the computer panel would reset itself. I am affraid to run the unit in fear that it might short out or cause a a fire. I know it is an older unit, however,it hasn't actually been in operation more than two(2)years because it was used as a nonfunctional display at a kitchen design showroom in my town that had to go out of business.
5 Suggested Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
Have u chked for any reset button in dishwasher?
Posted on Sep 21, 2008
jumptrout51
  • 3361 Answers
SOURCE: the kitchenaid dishwasher (model KUDC25CHSS1)
Press and HOLD the HEATED DRY button for 5 seconds.
Posted on Jul 07, 2009
  • 6 Answers
SOURCE: Dishwasher KUDC25CH; Control Panel is not working
WASH THE DISHES URESELF U LAZY ****!!! :)
Posted on Oct 17, 2009
rickead1
  • 1998 Answers
SOURCE: I have the KitchenAid undercounter
Did you try holding the energy save button for 10 seconds I thought that was how you were supposed to unlock the child lock on the unit. Also did you try unplugging the unit as well for 7 minutes this usually causes the control to reset in the unit. I await your reply to how you make out with these suggestions. If this does not work then one or more of the pads on the control panel is stuck and if this were the case then you would have to replace the control panel if you have any further questions message me back. Thanks Rick
Posted on Jul 11, 2011
I have a Fisher&Paykal DD6031 drawer dishwasher. Stopped running mid cycle. Lights flashing on drawer front green,red,yellow,red green,red,yellow . I don't know what that code means. On the inside Heavy...
follow this steps and fix it. GOD BLESS YOU
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
Regency problems
follow this steps and fix it. God bless you
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 | Maytag Dishwashers
The dishwasher will not work. It appears to have no power.
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the HEATED DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 14, 2011 | KitchenAid KUDC25CH Dishwasher
I have a Kitchenaid dishwasher model#KUDS01J, Icann't get it to start the rinse only cycle is stuck with a light blinkin and we cann't press any other functions on the panel.
I suggest having a qualified service tech diagnose your situation. The most likely issue would be a shorted touchpad. However, a failed control board could give you the same scenario. Both parts are expensive, so you would want to know which is failed prior to changing a part.
Nov 04, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
No power on kitchenaid kudc25 dishwasher
I have the same problem on my 2000 KUDC25CHSS1 DW. I thought it was the control board so I replaced it ($150). No dice. Still have the same problem. Since the next step is to replace the keypad ($450), I am having someone come out an take a look.
Couldn't find a tech sheet in the unit. Found one online, but there is not much in the way of diagnostics in it.
Mar 08, 2009 | KitchenAid KUDC25CH Dishwasher
Is there a removable filter on the KitchenAid KUDC25CH
Again, check the routing of the drain hose. The drain hose should belooped up in the cabinet under the sink. If it is not the water may be backing up into the Dishwasher
Feb 06, 2009 | KitchenAid KUDC25CH Dishwasher
KitchenAid model KUDS25SH (Stainless) latch has come loose.
Remove the six or seven screws that secure the entire control panel to the door (screws are located inside of door around the top. Pull out the control panel and the door latch mechanism will be right there for you to work on.
Jan 31, 2009 | KitchenAid KUDC25CH Dishwasher
Kitchaide Dishwash Door
There is normally 2 heavy springs & cables that control the "falling" of the door located in the bottom of the machine or it the door itself. Sounds like one (or both) have snapped.
Jul 25, 2007 | KitchenAid KUDC25CH Dishwasher
KitchenAid 24 in. KUDS25SH Built-in Dishwasher Logo
140 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
