Question about Mitsubishi VS-45607 45" Rear Projection Television
Pip will not turn off can not reset - Mitsubishi VS-45607 45" Rear Projection Television
This worked for us...
The pip just showed up on its own. When we went to the pip setting with the remote, it told us that pip was "unavailable," but there it was!
We tried unplugging the TV to let it reset, but that didn't work. Then we found that the pip disappeared when we turned on the Blu-ray, so we figured that the problem wasn't in the TV, but rather with the cable.
So we unplugged the cable box and let it reset itself. Ta-da!!! It worked.
(We have had several weird problems since we got the new high defe cable box. Unplugging and letting it reset on its own has worked with each problem so far.)
Hopethis helps.
Posted on Jan 17, 2009
  • 934 Answers
Either the micro is failing or the eeprom has become corrupted.. You can try unplugging the set for 15 minutes - not less - and allow the eeprom itself and see if that cures the problem. If not the micro has failed and it's best to take it in because usually something else probably caused the failure (cap, diode open resistor, etc.) and the tech will have to trace test to find out what..
Good Luck!
Posted on Dec 19, 2007
How to take of pip with out remote
unplug the tv from the wall and plug back in. it might reset it to the way it was before the pip was turned on.
Sep 15, 2012 | Televison & Video
The picture is stuck in pip cant get it to go away
Turn it off manually (unplug the power cable), it should reset itself after several minutes (10-20).
Dec 08, 2011 | Mitsubishi WS-55513 55" Rear Projection...
I have a sony (model KP61V75) a split screen came on (two pictures) and I cannot figure out how to get it back to one screen. Im going crazy!
Some television remote controls have a PIP OFF button, while others only have a PIP button that needs to be pressed repeatedly until the PIP/Twin-View window disappears.
  • Some Sony rear projection televisions have a FLASH FOCUS button that will turn off the PIP/Twin-View feature.
  • Some Sony universal remote controls, if programmed to operate a Sony TV, can disable the PIP/Twin-View feature by pressing the REC or ENT button.
  • If the original TV remote control is not available or is not functioning properly, auto programming the television tuner orperforming a power reset may deactivate the PIP/Twin-View feature.
  • If pressing the appropriate buttons on the TV remote control does not work, then the PIP/Twin-View window might be from a two-tuner cable or satellite set-top box. If this is the case, use the remote control provided with the set-top box to remove the PIP/Twin-View window.
Jan 25, 2011 | Sony Televison & Video
We have a universal remote and the picture in picture was turned on do I turn it's a hitachi tv
Usually the PiP button scrolls through the PiP modes, so your best chance is to find the button that did it and give it another press or two. If you're unlucky, you might find that on the original remote the button to turn off PiP was a seperate one that doesn't correspond to the universal remote... In this case, try unplugging the TV fro the power and leaving for a few hours before turning on again. This might reset the PiP setting.
Jul 11, 2010 | Televison & Video
I dont have a pip button on my remote to reset my
if you do not have the (PIP) button on your remote look for for the (split) button and try the volume down and (PIP/split) trick again. it worked for me!! good luck..
Oct 06, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Cant turn off panasonic PIP
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
Jun 12, 2008 | Panasonic CT-36D32 36" TV
32 xbr vega trinitron PIP wont turn off
Just press any channel number and PIP will disappears :)
Dec 25, 2007 | Sony KV-36XBR400 36" TV
Lamp reset
This also works for the Panasonic PT-61LCX65. You hold the volume button down on the projection display, then hold down the Split/ DVD button on the remote control at the same time. I just did it after reading the advice posted. Thank you!
Oct 11, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Turning off PIP without remote
To turn off the "stuck" pip on a Panasonic tv without a remote:
1) Turn off the tv.
2) Then hold down the "Action" button on the front of the tv and press the power button.
2-b) Continue to hold down the Action until the tv powers all the way up, and the reset menu comes up - be patient.
Expected Reslut: Self check menu should appear.
Expected Reslut: The pesky pip screen will be gone!
If the self check menu does not appear, you did not hold the Action button long enough.
Simply begin from step one.
Thanks to Imhiro
Sep 28, 2007 | Panasonic CT-36D32 36" TV
PIP for Sony KV-27XBR45 television trouble shooting
If you have the original remote for this TV on the pip menu (left side slider on remote all the way up) there is a pip off button. If you unplug the unit long enough it should go back to normal. If you go into demo mode and then exit mode you will again be out of the pip. With out the original remote you cannot easily turn pip off.
Apr 13, 2007 | Sony KV-27XBR45 27" TV
Mitsubishi VS-45607 45" Rear Projection Television Logo
77 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
