Question about Intertherm P3RA-048K Air Conditioner
Compressor froze on a 1999 oldsmobile silhouette. can you install another belt bypassing compressor
  • 1,238 Answers
Go to your local auto parts place and see if they offer a belt that is for you auto that does not have a/c. That usually works.
Posted on Sep 11, 2009
I have a 2002 Oldsmobile Alero what do I do to change the bypass pulley do I replace the ac compressor
You evacuate the AC system. You remove the serpentine belt. Then you remove the compressor. But the hoses and secure the cut ends so they don't rattle around. The bypass pulley will fit in place of the compressor. Then you install the serpentine belt
Sep 21, 2017 | Oldsmobile Cars & Trucks
Can u show a diagram on how to bypass ac compressor on a 1999 Oldsmobile Intrigue
If you mean Electrically bypass, simply disconnect the lead to the power clutch. If you mean by pass the serpentine belt? Good luck with that.
Apr 02, 2015 | 1999 Oldsmobile Intrigue
Installing bypass pulley on 1999 chevy blazer
Unbolt the a/c compressor. bolt in the a/c bypass pulley and install the belt. Its pretty straight forward.
Feb 13, 2013 | Cars & Trucks
Can I bypass the ac compressor with a smaller serpentine belt?
I have a 1990 Olds 3.8 V6. Installed a 715k6 belt bypassing the frozen AC compressor using the stock belt routing. Working great.
Thanks for the above advice
Aug 07, 2012 | 1994 Oldsmobile Ninety Eight Regency
Replacing the air conditioning unit with a bypass pulley. where do i start?
Why do you want to bypass it? Is the unit froze up? If not, try unplugging the unit form the electrical source. It should still turn but not kick in unless the compressor is froze.
Dec 05, 2011 | 1996 Oldsmobile Cutlass Supreme Coupe
I need a diagram for serpentine belt replacement on 1999 oldsmobile silhouette
Check this for SILHOUETTE Engine V6 3.4L 207ci GAS FI N E
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Nov 02, 2011 | 1999 Oldsmobile Silhouette
CAN THE SERPENTINE BELT BE REROUTED TO BYPASS THE A/C COMPRESSOR?
No. The bearing on the compressor can be replaced without buying an entire compressor.
Jul 27, 2010 | 2000 Oldsmobile Silhouette
Rear ac does not blow cold air on 1999 oldsmobile silhouette
# 5 on front ac has to work for rear to work..if it works then there is a switch that controls the rear cost about $80..and the blower back by compressor also was out on mine...there is a fuse that can make #5 setting on front ac work check that first
Jul 26, 2010 | 1999 Oldsmobile Silhouette
My ac compressor is squealing. is there a cheap solution to this, can i put a smaller belt on and by pass the compressor?
It could be the belt, but also be the bearings squealing, it will lock the compressor down and snap that belt. But you can bypass the compressor with a smaller belt.
Jan 15, 2010 | 1999 Oldsmobile Intrigue
Air ride problems '99 Silhouette
u can't change the just the valve u can change the compressor head but still costly the only other way would be and easier buy a used one
Apr 25, 2009 | 1999 Oldsmobile Silhouette
Intertherm P3RA-048K Air Conditioner Logo
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
