Question about Samsung SGH-d807 Cellular Phone
Speaker not working properly
Sometimes when I receive a call, there is not audio, and sometimes I can get the sound to come when I slightly twist the phone. The same holds for using the mp3 player. Is there any way to clean the contacts that read when you slide it open? I think that may be part of the problem...
    Brigadier General:
  • 7,752 Answers
Your phone needs to have the microphone and speaker replaced, you can also upgrade the firmware on your phone all of which can be done by taking the phone to a mobile service center and have that done or a mobile tech that is close to you.
Posted on Jan 29, 2008
I have sony radio model no STK-KM22 it display flashing protector messege and I cant play any thing ,how I can solve thi ploblem?
Unplug for 30 seconds unplug speaker cords.twist all wire ends together tightly for each set of little wire not twisted tightly with the rest can short out throwing receiver into surgery protection mode.plug receiver back in or reconnect it.test each wire set to see if external speaker wire issue.wire sets are twisted good you will know as each speaker will come back on.twistem tight soldier them or use liquid tape to keep connection working properly.use surge protector to protect unit receiver.
Apr 09, 2017 | Sony Audio Players & Recorders
Pioneer receiver no sound
Check for badly connected/disconnected speaker cables and interlinks. Speaker cables must be properly twisted and connected to prevent short circuiting. I've provided an instruction video below:
Jul 09, 2016 | Pioneer Audio Players & Recorders
Not working
If you are usiing windows, should checl Cotrol Panel, audio and sound device and verify is sound is bot on 0%. also should check in Advanced Properties if speaker not silenced. Sometimes Windows silences ithe computer without any apparent reason. Steps might be slightly different, depending o version of Windows.
Missing or lost sound in Windows
How do verify that sounds are playing properly on Windows 7 Vista
Windows XP Audio Settings
Sep 17, 2015 | Audio Players & Recorders
The sound on my garmin zumo 550 is not working right it has been working fine. But this morning when I hooked it to my Harley ultra classic it was reel low upon further check it was only coming through...
sounds like the Audio patch cord, i had around 5 of them that do that ...sometimes i hear the music thru one speaker, cracking noise sometimes it works when the wire is twisted, but i would try a new patch cord patch cord worked fine on some stereo units others break up
Nov 07, 2010 | Garmin zumo 550 GPS Receiver
No sound from speaker on the right with power led and digital audio port for tht SP08A11 speakers
Check the wires for tiny cuts. The Auxiliary cord on the speakers are most likely at fault
Apr 11, 2010 | Computers & Internet
Only 2ch sound on sony strde898
I understand that you have tried connecting different audio source to the Receiver as some of the audio source will output only 2 channel audio. I hope you have tried changing the Input mode and Input selector to get the surround sound.
Please disconnect the speakers with the receiver and clean the edges of receiver and speaker cables using solution like alcohol and try.
If the issue persists, please interchange the rear speakers with front speakers and vice versa and check if audio is coming to make sure that the speakers are working fine.
If the audio comes after replacing the speakers but not from surround speakers, the receiver requires service.
Sep 22, 2009 | Sony STR-DE898 Receiver
I have a Denon AVR-488..Can you help?
Sounds like you may be clipping your speakers. Check all speaker connections and make sure they are not touching, at all. If you are not using speaker ends and are simply twisting the wire and connecting to the speakers, just one strand touching the other post will cause this. Good Luck
Jun 02, 2009 | Denon AVR588 Receiver
5.1 surround problem
Hi Zamorano,
sounds like your problem could be either with the wiring of your speakers, or the receiver. How long have you had them?
check the wiring going from the sub woofer to the speakers- do you see any creases or damaged (frayed) looking wires?if you fiddle with the wiring where it connects to the speakers or sub when you play music, do you hear the speakers act up? if so, you may have the problem right there. I'd also try fiddling with it where it connects to your soundcard, moving it, and twisting it *gently* to see if you experience the same.
if you at any time hear the speakers acting up when doing this, then you have your problem right there. (from there, you should considering purchasing replacement cabling. if the affected cords are permanently attached to the units, I'd recommend calling in to Logitech, and seeing what they can do about replacing them).
otherwise, it is most likely a receiver problem, which you would also have to call Logitech for repairs/replacement.
Hope this helps!
Jan 03, 2008 | Logitech X-530 Computer Speakers
Samsung SGH-d807 Cellular Phone Logo
23 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
