Question about Polaroid TDX-01530B 15.4 in. LCD HDTV
15.4 inch polaroid hdtv has sound but no picture. just a white screen.
  • farloughd Sep 07, 2009
    yes,thanks.
  • 3,230 Answers
Most likely it seems a failed power supply,there must be some failed capacitors and cold solder joints. Check for bulging and leaking capacitors these capacitors are located on the main board of your TV to check them you need to screw up your TV. Not all capacitors will show damage but many will. The only way to know for sure what is causing the problem it the proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment.
If you need to precede further then add some comment....
Thanks
Posted on Sep 07, 2009
Tv has sound but no picture
I had similar problem with my Polaroid 42 inch. The screen would be fine for 10 minutes or so then go black. I found a work around that solved my problem and maybe you can to. What I did was remove the back panel of the TV. Make sure it is unplugged first. You should be able to see the electical board. Somewhere on the board may be a switch that says "Burn" or something with "Burn" in it. I set the switch to the "Burn" setting and the TV has worked fine ever since. Good Luck.
Sep 29, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
Poloraid hdtv 36 inch model FLM 3201 PICTURE
FAULTY POWER SUPPLY OR INVERTER PANEL ON BACK OF SCREEN
AVERAGE REPAIR COST £60 TO £80+
Aug 25, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
TV Has Sound but no picture
Change or move yellow one, of the cables, or component. if not then something you need from expert..
Dec 31, 2009 | Polaroid TDX-02610B LCD TV
My 19 inch Polaroid FLM-1911 900t shows a white screen
your t-con board has failed check shop jimmy/com see uf they have a replacement
polaroids are hard to find parts
Sep 20, 2009 | Polaroid FLM-2011 Television
Screen goes black after about 10 minutes...POLAROID TLX-04240B
Simple Fix Repaire the backlight
repair man sure www.teexp.com
dont shoot the messanger!
Jun 13, 2009 | Insignia 42" LCD Flat-Panel HDTV
Polaroid flm373b
Try several different inputs.
Sep 08, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Programing Remote
Most Polaroid flat-screen TVs won't program to the Uverse remotes. Try buying a different universal remote that shows coding for both Uverse and Polaroid.
Apr 19, 2008 | LG 47LC7DF 47 in. LCD HDTV
Polaroid TDX-01530B 15.4 in. LCD HDTV Logo
44 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
