Question about Brother HL 5250DN Laser Printer
My hl-5250DN does not wake up when I send print jobs from OS X 10.6. I have to cycle the power
I've installed a new drum AND a new toner cartridge. have followed all directions to reset the drum and the light still flashes and I can't print, this is for a brother HL-5250DN printer
Try this....
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Jul 20, 2010 | Brother HL 5250DN Laser Printer
HL-5250dn ona Bonjour network will not work with Leopard
have you already tried reinstalling the driver of the printer?
Oct 21, 2008 | Brother HL 5250DN Laser Printer
My Brother hl-2040 is just running paper through, even after power cycles, and won't stop. How can I purge its memory to be able to start printing an acutal document again?
disconect the usb from the printer, then power cycle.
cancel all jobs on the computer. reconnect the usb, if you send a job and the problem starts again i'd try a new cable
Mar 23, 2010 | Brother HL-2040 Laser Printer
Brother HL-5250 printer toner Light on but Cartridge has Toner it
Try this....
Mar 08, 2010 | Brother HL 5250DN Laser Printer
Brother HL-5250DN Laser Printer making noises and not printing
some gears are not in proper position , pull out the paper tray and closed it strongly .
Nov 17, 2009 | Brother HL 5250DN Laser Printer
All the Lights are flashing on my HL 5250DN
If printer is blinking all the LEDs then try to turn off the power switch, wait a few seconds, and then turn it back on and try to print again. If all the LEDs are still blinking, press Go and Job Cancel buttons together and let me know what LEDs stay on.
Jun 23, 2009 | Brother HL 5250DN Laser Printer
All lights on solid, not flashing, wont print
Recommendation: See HL-5240/HL-5250DN USER'S GUIDE: Section (4), Control Panel: LEDs, (light emitting diodes) starting on pg. 44.
Apr 14, 2009 | Brother HL 5250DN Laser Printer
Brother HL-5250DN printer on Linux operating system
you have to set it in the printer settings to do that
Mar 05, 2009 | Brother HL 5250DN Laser Printer
Computer goes into Hybernate Mode after each print Job.
Try plugging the printer power cable into a different power outlet, preferably an outlet that is not shared. I had a similar problem but in my case, the computer would crash. For some reason, the HL-5250DN demands so much electricity on starting a job that it doesn't play nice with the other equipment.
Mar 04, 2009 | Brother HL 5250DN Laser Printer
Brother HL 5250DN Laser Printer Logo
227 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
