Question about Dryers
My Whirlpool Imperial Series Dryer is 4 years old. NO Heat.
My Whirlpool Imperial Series Dryer is 4 years old. It has all of a sudden stopped heating up. The dryer just spins and spins with no heat and clothes still wet. Is it the heating element and can I replace it myself?
Sure there is. The cheapest I have found is on amazon. click here Dryer Heating Element 279838 For Whirlpool Kenmore and take a look. I hope this was helpful. cheers
Posted on Nov 24, 2014
  • 5,911 Answers
It may not be the heating element causing your problem. There are other components that can fail that will cause the same symptoms. The following link explains how to troubleshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer will exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the washer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum. All dryers are not constructed the the same. Regardles of location, the Heating Element is located inside the heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals. If either the TCO or Hi-Limit Thermostat are determined to be bad, replace both components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace. All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
If you have any questions, please let me know. Please inlcude your complete model number (located on a nameplate around the door opening) when asking questions. I hope you find this information helpful.
Posted on Sep 07, 2009
Whirlpool Imperial gas dryer won't heat up.
There are two thermal cutoffs. If you pop open the top of the dryer and find the heating element the bigger one is mounted directly on top of it and the other one is located below it. Those are the thing to check first. You can test with a multimeter set to test continuity. If those are bad that means that the exhaust vent is getting clogged. Those run about 34 bucks for the set. The other piece to check is the element itself. You can test that the same way. Those run between 50 and 70 bucks. Good luck.
Jun 28, 2012 | Whirlpool Dryers
We have an eight year old dryer that all of a sudden just stopped heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 08, 2011 | Whirlpool LER4634J Electric Dryer
10 year old Kenmore dryer Series 80 suddenly has stopped producing heat. Vent is clean. What else can I try?
On a gas model dryer those coils seem to die when heated when they have a little age on em. So if the ignitor works and the dryer does a little bit of heating then fails and it is gas then those coils are the problem. On an electric model the element will get brittle with age and die but if your dryer is suffering from air restrictions it may have had a limit trip on it.
I have a service manual and more of a Kenmore /whirlpool style dryer HERE
Jan 18, 2011 | Dryers
My dryer is not getting a heat. Its an Imperial Series
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Oct 24, 2010 | Whirlpool Dryers
My Whirlpool dryer LGT7848AQO imperial series does not heat up. HelP!
Check the fuse/circuit breaker box, you need 220/240V to heat the dryer. If there is proper voltage going to the dryer, then you will need to goe inside and check the limiters and element.
Feb 17, 2010 | Dryers
Dryer will not heat
Model number needed to look up fuse location or simply use Repairclinic.com to look up the fuse location yourself. These newer models have not been out long enough for a retired old dude like me to come across one. But I bet I could repair it.Since yours is this new you might want to get factory service to take a gander at it before you attempt a DIY to prevent voiding any warranty you may have left.
Jan 10, 2009 | Whirlpool LEQ9858P Electric Dryer
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryers Logo
3,200 people viewed this question
Top Dryers Experts
