How to remove the control panel on a whirlpool washing machine
  • 5,911 Answers
If this is a TOP LOADER, the operator console comes of in various different ways:
1. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
2. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. On some consoles there will be a screw located in the rear on each end that you need to remove in order the lift the console.
Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
If this is a FRONT LOADER, the console is removed in the following way:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator consolehow to remove the control panel on a whirlpool - 2.gif by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
If you have any questions, or need further assistance, please let me know. please include a model number so that I may be able to provide you with better assistance.
I hope this helps you.
Posted on Sep 07, 2009
Testimonial: "what a quick responce, i am impressed"
I want to replace a timer on a Whirlpool washer Model# LSN1000KQW
Good day Mr.james dant..
Whirlpool manufactures many types of washing machines. Whirlpool's top load models rely on an analog timer that controls the cycle used to wash the clothes in the washing machine, rather than a digital control board found in most front load models. The timer contains a number of moving parts and is physically turned to choose the wash cycle. Because of the high usage of the timer, it will eventually break, requiring replacement. Rather than calling a service technician to repair the timer, replace the timer yourself to save both time and money.
Instructions
1. Unplug the washing machine from the wall outlet
2. Turn the dial to the "Off" position and then unscrew the knob from the timer. To unscrew, hold the dial with one hand and turn the knob counter-clockwise.
3. Lift the dial off of the washing machine.
4. Remove the two mounting screws securing the timer into position. 5. Remove the two screws from the bottom left and right sides of the control panel, then rotate the control panel up 180 degrees.
6. Remove the wire harness from the old timer and remove the old timer
7. Connect the wire harness to the new timer.
8. Place the timer into the control panel. Hold the timer post with one hand and rotate the control panel back down. Secure the timer into place using the mounting screws that were removed from the old timer
9. Place the dial back onto the timer post and then screw the knob onto the post.
10. Plug the washer back into the wall outlet
Try to watch this video:
Nov 25, 2011 | Washing Machines
Whirlpool duet washer door will not unlock or complete the cycle
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
  • Oct 13, 2011 | Whirlpool Washing Machines
    How do I remove the control panel on a whirlpool duet wfw9500?
    remove the top covers screws in the back then you can access the screws that hold the control panel on
    Aug 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    I have a F6 code problem with my Whirlpool Duet FL Washer, any ideas?
    F6 is an issue with the motor drive tachometer. Most often this is caused by poor connections at the machine control or motor controller. Locate the main machine control by removing the top panel and the motor control by removing the rear panel. Remove each connector, ONE AT A TIME, and reinstall. If this does not work, you likely have a faulty control.
    Kelly
    May 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    How do i remove the mcu in my whirlpool duet
    you will need to remove the upper rear cover behind the control panel on the back side of the machine and remove the four screws securing it,then remove the wiring harness connecting it to the machine electrics
    Jan 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet WFW9400SW00 - How do I remove the control panel?
    The ccu isnt behind the panel. The ccu is under the top of the washer. Who will be repairing this? This is a non- reparable part.
    Jul 01, 2009 | Whirlpool Washing Machines
    Reset whirlpool front loader
    Power shd be on. Right side of control panel, "end of cycle", hold this down for 3 seconds.
    Mar 21, 2009 | Whirlpool Washing Machines
    Code F 01 come up on my Whirlpool front load washer and won't do any thing?????
    must be a duet sport ..change control module ..remove screws along rear of top panel remove panel by sliding back .control is white or gray box on right near front
    Aug 28, 2008 | Whirlpool Washing Machines
    Washing Machines Logo
    470 people viewed this question
    Top Washing Machines Experts
