Question about Frigidaire GLWS1649A Top Load Washer
Motor rotates but motor pulley does not rotate.
  • Frigidaire Master
  • 8,404 Answers
Check the allen set screw on the pulley. You will probably need a long allen key to reach it. You will also need a flash light to find it. Hopefully, the shaft has not been damaged beyond reasonalbe use.
Posted on Sep 07, 2009
Oscillator is not rotating
make this test and fix it. God bless you
Belt
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt , and often the idler pulley, because the pulley tends to wear out at the same time. . If you hear the motor running but it does not tumble it is most likely the belt.
Motor
If the dryer motor only hums when you press the Start button, the motor may be burned out.
Remove the belt.
Check for obstructions in the blower fan housing.
Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Check our videos on testing a motor and capacitor.
Door switch
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity. When Door is open no continuity when closed you should have a reading. If it's defective, you need to replace it.
Jul 30, 2013 | Dryers
Clothes dryer drum will not spin. open it up and belt looks ok. now what?
You need to check the blower fan and make sure there's no obstructions (you probably would have noticed by now though).
Remove the belt from the motor pinion and try to rotate the shaft of the motor manually. To remove the belt, you will need to relieve the tension of the belt by moving the idler pulley over to slip the belt off. If it is stiff, or almost impossible to rotate manually, the blower fan housing is clear, then you need to replace the motor. IF.........
The motor shaft rotates freely, try to run the motor with the belt removed. If it does run with the belt removed, then you need to check the idler pulley and the drum itself. The idler pulley is the little wheel that the belt runs around to keep tension on the belt. It may be stiff or frozen.
If you've gotten this far, try to rotate the drum by hand, if it is difficult to do, focus your attention to the rollers and pulley.
If the motor doesnt rotate, even with the belt removed, yet you can turn it freely by hand. You usually need to replace the motor or the motor start capacitor.
I hope that you have found this helpful.
Thanks,
Mike
Jul 24, 2011 | Kenmore 76832 Dryer
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
May 26, 2011 | Bissell 3591 CleanView Bagless Upright...
WHEN PRESSING START UNIT JUST HUMS
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor.If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Nov 26, 2010 | Amana Dryers
Dryer has electricity but the drum will not spin
Hello there:
If your dryer doesn't tumble, check these:
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Sep 27, 2010 | Whirlpool LER4634J Electric Dryer
WHY DOESN'T MY DRYER TUMBLE
Hi, If your dryer doesn't tumble,The problem might be from three different reasons,which are described below,check these:
1.BELT; Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
2.MOTOR; If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt.Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
3.DOOR SWITCH; Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Thanks and good luck
Jun 21, 2010 | Dryers
The dryer does not turn, but will turn by hand, how do you unlock heller cd55 dryer?
It won't tumble If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dec 31, 2009 | Dryers
My dryer has power but the drum will not turn
Belt, Motor, motor start capacitor or Door switch. you going to have to open the back cover off and see what is taking place. check belt making sure good and tight, idler pulley may be worn also. If motor only making a hums sound when you press start it may be burnt out. you can check if the motor is good or bad by removing the belt and manually rotate the shaft motor pulley, if the motor is stiff and impossible to rotate manually, it also a sign the motor burnt out. if the motor turn and run freely without the belt, the problems maybe with the pulley or the drum, try to rotate the drum and making sure it rotate freely using very little effort. if door switch faulty, the unit will not work.
Sep 01, 2009 | Maytag Dryers
Dryer wont spin
If dryer does not spin it is usually a problem with the belt or the motor. Check also door switch.
See also following indications from Repairclinic:
Belt
Motor
Door switch
Click here for a belt installation diagram.
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
Aug 27, 2008 | Dryers
The drum on my dryer stopped turning it was heating and it just stopped turning, I just want to get instuctions on how to take it apart.
Belt
Motor
Door switch
  • Remove the belt.
Jun 15, 2008 | Magic Chef Dryers
Frigidaire GLWS1649A Top Load Washer Logo
26 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
