Question about Sony VAIO PCG-K35 Notebook
Charging or power problem
Hi my vaio pcg-k315s will only run for a few mins on ac (with battery removed) then shuts down, its not overheating, can it be the charging/power board, ive replaced the power jack already, its solderd good to my knowadge anyways, help plz
  • Justin Royce
    Justin Royce May 11, 2010
    When you turn it on, how far does it boot? Do you see any errors? Any recent problems with it and has it been dropped, even if it was a few inches?
  • 674 Answers
Check the cpu and that is shortage.., check the other power ic something bad ic need to replace..
Posted on Sep 08, 2009
Sony vaio PCG-7142L keeps freezing
Can check if the battery is low ... or is not (or cannot) holding a good charge ... when you unplug it (from the charger) ... when this happens ?
If that is the case, it may "freeze" while it is busy trying to store the contents of your memory before it shuts down (or hibernates). Does it shut down (or goes into hibernate if you let it continue to "freeze") for a while ? If so, then it's your battery.
If the battery doesn't hold a good charge, the laptop will run only a short time (while unplugged) before it has to shut down due to low battery. And if this is the case, consider getting a replacement (new) battery. And follow the initial charging instructions (for a new battery) to lengthen the life of the battery.
Apr 03, 2014 | Sony VAIO Computers & Internet
Sony vaio model pcg-61611L it turns on for 4 seconds and then it turns off using the ac adapter . help please
The charger may be bad, will it charge the battery? a common problem is the DC jack in the laptop breaks connection on the motherboard internittent operation or no power and shut down. If you can sub the charger that will tell if the power supply is bad or the problem is in the laptop. If the computer is the issue I recommend a professional because it will require extensive parts removal.
Mar 04, 2012 | Sony Vaio PCG-71318L
Sony vaio pcg-frv27 turns off after a while, I'm using ac power with batteries not in it.
Most likely overheating, check if it is getting hot as it shuts off, by hot I mean hard to touch the base.
If it is, you will need to remove the bottom cover and clean out the accumulation of any dust by the heatsink
Mar 26, 2011 | Sony VAIO FRV27 Notebook
I am looking for a USER'S MANUAL for my SONY VAIO PCG-K315S.
The manual for the PCG-K series is found here:
ftp://ftp.vaio-link.com/pub/Manuals/Notebooks/K3/K3_H_EN.pdf
The specifics of the K315S model don't appear to be anything but minor variations of each other (such as more ram, different hard drive, or larger/smaller screens) so this manual should cover all the basic functions of the laptop.
Since this appears to be a laptop made for European markets you can use this website to find drivers and other documentation: http://support.vaio.sony.eu/computing/vaio/index.aspx
You will need to enter your serial number off the labal on the bottom of the machine.
Hope this helps!
Mar 18, 2011 | Computers & Internet
Charging problem
If your computer runs correctly on AC power (without the battery), the power adapter is fine. So the problem may rest with your battery. If you have been using the same battery for 3-4 years, I suspect that it may not be holding the charge (end of life)
Try charging you battery and run the computer on battery alone and see how long it lasts.
Hope it helps
Sep 07, 2009 | Sony VAIO PCG-K35 Notebook
Sony PCG-F340 keeps shutting down
Old Sony laptops do this when the battery is dead, or the charging system is below required voltage. A battery with a dead cell (which this sounds like) can damage your external PSU and internal battery/power regulator circuit. Remove the battery (shut down and disconnect PSU first). You can run the laptop forever, without the battery, if you cannot find a battery replacement, or do not like the cost. Obviously, though, the laptop will not run at all without the AC/PSU connected when the battery is removed.
Feb 08, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Sony Vaio PCG-K86P laptop
hi, the problem seems with the RAM, remove and clean the contacts with an rubber/easer, this should fix ur problem,let me know
Dec 20, 2007 | Sony VAIO PCG-K25 Notebook
Sony VAIO PCG-K35 Notebook Logo
285 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
