Question about Frigidaire Microwave Ovens
I do not have the manual. How do I change the poiwer level on a Frigidaire Microwave model FMT116E1W
    President:
  • 1,564 Answers
After setting the time amount before you hit the start button, push the power button with each push it should indicate a different power level if not you've got to use the keypad, for example, 50 is 50% power etc.
Posted on Sep 08, 2009
I have a FMT116E1W made a loud pop and now no power or anything.
This sounds like the magnetron has failed, the pop sound is a classic sysmptom.
May 18, 2012 | KitchenAid KHHS179LSS Convection /...
Fmt116e1w microwave not heating, how do I fix
The problem may be a defective magnetron, or the inverter board, { if 7 years old or less } keep in mind these are pricey parts,
May 15, 2012 | Frigidaire Microwave Ovens
No power at all checked fuse yd ok
The problem is the inverter board,"if 7years old or less" or the keypad control board.
Apr 25, 2012 | Frigidaire FMT116E1W Microwave Oven
Rmicrowave runs but does not heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
May 03, 2011 | Frigidaire FMT116E1W Microwave Oven
We had a power outage and the display is blinking and there is no response to pressing any button
First, try unplugging the microwave for 2 to 5 minutes and then plugging it back in. Sometimes, a very brief power outage will be sensed by the control as an internal error and the control will lock itself out.
If it continues to blink and does not respond to key presses after this "hard reset", it is likely a portion of the control board could have been damaged from the power outage.
FYI ... the touch panel for this model is no longer available. I mention that because no response from any key press can also denote a shorted key pad.
Apr 15, 2011 | Frigidaire FMT116E1W Microwave Oven
Frigidaire gallery microwave 1998 need instructions
You can download most Frigidaire owner's manuals and installation instructions here or here..
Normally you press Cook Time, 1, 2, 3, then Power Level, then 5 (for 50% power) then Start.
Dec 06, 2008 | Microwave Ovens
Frigidaire FMT116E1W - Issue
I suspect a problem with a door switch mount, but here is my full standard reply on this symptom:
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Aug 16, 2008 | Frigidaire FMT116E1W Microwave Oven
My microwave doesnt work at all
If the micro is completly dead and the outlet is OK... check the main fuse inside the cover. Unplug unit, remove cover (screws in back) and check the fuse where the power cord comes in through the back.
I am not sure what region you are in but in the States it is usually a 15A fuse. REPLACE ONLY WITH EXACT FUSE. Most hardware stores have these for microwaves.
MM85
Jul 22, 2008 | Frigidaire FMT116E1W Microwave Oven
Microwave Ovens Logo
221 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
