Question about LG LSC26905TT Side by Side Refrigerator
Ice depensing door will not close on LG model LSC27926ST
The ice door opens to allow the ice to fall, but will not close when not in use unless to push it close manually. If you forget to close it after getting ice the room temp heat causes the ice to melt and drip making you think you have a leak. This also causes the ice to frezze together, and causes a problem with getting nothing but crussed ice only.
This is the first and last time I buy an LG refrigerator. The refrig. is only two years old and the handle is also coming off the door.
    Problem Solver:
  • 4 Answers
It is probably frozen in place. The old ice tray bend and spils in the Ice Bin and eventually leaks out that door. Have you changed the ice tray with the update? This might fix your problem. Do you know if the door has illumination for the buttons? Mine doesn't and I think there should be somethng cause it is hard to read the buttons in the dark.
Posted on Sep 11, 2009
LG Freezer ice maker makes ice but wont dispense
There is a mechanical flap (trap door) that should open to allow ice that is being pushed by the auger in the bottom of the bin to fall out. Possibly the solenoid that opens the door does not work, or you just have an obstruction (piece of ice) preventing the door from opening far enough to allow the ice to pass through. Here is some helpful information and instructions.
Mar 19, 2014 | LG LSC23924ST Refrigeration : Refrigerator...
Lg lmx25984 ice chute flap will not open automatically
On Mine, the solenoid connection fell off that allows the ice to dispense, Thank you so much!
Aug 04, 2012 | LG LMX25984ST 24.7 Cu.Ft. French 4-Door...
I have lsc27926st. The water tube to the ice tray froze and I used a hair dryer to unfreeze it. After the tube was clear the water will not refill the tray. I have turned the on/off switch a couple of...
from the ice freezing tube may have caused valve to burn up on unit... these are normally plastic water valves on back side of unit lower right side... very common problem... i am a lg oem authorized servicer parts usually come from lg electronics in alabama unless you have a local supplier that you can go to...        the ice makers themselves have been problems on these models as well... 1 year warranty is all they give and usually 1 year 2 days they go out...   let me know if i can help anymore    ACHEATINGUNLIMITED@YAHOO.COM         TEXAS BASED APPLIANCE /HEATING AND AIR COMPANY
Dec 31, 2010 | LG 26.0 Cu. Ft. Side-by-Side Refrigerator...
My ice depenser is freezing up and the hole the ice goes through in the door
BET IT'S A GE? YOUR SOLENOID THAT OPENS AND CLOSES THE ICE FLAP HAS RUSTED AND WILL NOT CLOSE ALL THE WAY LETTING AIR IN AND FREEZING THE CHUTE,CALL LOCAL REPAIRMAN.THANKS-MIKE
May 04, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
The hole where ice comes throuh door freezing is freesing up
Flap closes under spring pressure and may not be closing fully causing ice/snow build up . Bend the spring to adjust the tension and lubricate with a little vaseline
May 04, 2008 | GE GSS22JFMWW Side by Side Refrigerator
Icemaker flap/door does not mechanically open
The description says you have an LG fridge?  I may need the entire model # from the sticker inside the fridge to tell for sure, but there is a motor behind the dispenser controls that opens the door.  Let me know if you need more help.  Also, you can view parts and diagrams at http://www.appliancepartspros.com/.
Oct 21, 2007 | LG LFX25960ST Stainless Steel French Door...
Ice despenser door not opening
I had this problem. There is a piece of ice jammed in there that is blocking the door. try pouring some warm water into the hole from the inside and naking sure the path is clear.
Apr 14, 2007 | LG LSC26905TT Side by Side Refrigerator
LG LSC26905TT Side by Side Refrigerator Logo
187 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
