Question about Philips 42PF7421D 32 in. LCD HDTV
Our 50" Philips Plasma wide has a red light that flashes also.
We replaced the panel board on the far right but the red light still flashes 7 times. No swollen areas and all parts were checked by an electrician that knows about computer panels and does that work for a living. Mystery still not solved. Any suggestions for what we could try next?
    Problem Solver:
HOW DO I KNOW WICH RESITORS TO CHECK OR REPLACE CAN YOU SEND A PICTURE
Posted on Mar 07, 2010
  • 59 Answers
Normally that sounds like a power supply failure
even if the caps look ok check the secondary side of supply rails for ripple or voltage outside of specs.
this is a common problem on these units the caps are (as far as i can remember) are 3300 10v , 100 16v , 1000 35v 330 16v
the other problems i have had with these sets is the resistors that drive the relays going high in value.
Posted on Sep 07, 2009
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
7 red flashing lights, won't power up..
Check the power board for capacitors with the tops bulged up. They are 3300uf 10v. There are either 2 or 4 of them depending on your set.
Jun 01, 2009 | Philips 42PF9631D 42 in. Plasma Television
Check the power board for caps with the tops bulged up. 3300uf 10v.
May 16, 2009 | Philips 42PF9631D 42 in. Plasma Television
Philips 50" plasma ysus board troubles
Check for shorts, blown fuses on ysus, if blown replace entire board, easier than locating many of the parts installed on the board.
Nov 26, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
Red light flashes
This is a well known and very common problem with all Philips plasma tvs 42 and 50 inch. The problem is they used under rated capacitors in the power supply. If you have electronics experience or a friend that is, remove the cover and look in the back for malformed or leaking capcitors. Replace them and see if that takes care of the problem. The caps only cost $2 or $3 each, so the cost to try this is pretty reasonable although you might have an added cost of buying beer for your electronics friend. If this does not fix your problem you are down to replacing boards that can be purchased around $300 ea.
I have found my set will come on "finally" after I get the back of the set warmed up and the bad caps finally charge up. Hope this is useful.
Oct 24, 2008 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Set dosen't power on/off.
Replace the small signal board 310432842611.
Oct 02, 2008 | Philips 42PF9630A 42 in. Plasma Television
Red light flashes & times
7 blink error is 8.6 volt error usually tied to y main board. would advise to disconnect y main from power supply and verify vs voltage. if vs is present replace y main and general protocol is to replace y upper and lower buffers as well as they complete circuit
Aug 10, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Replacing the Y-MAIN or Y-SUSTAIN Board in Philips 42PF9630A/#&
I called PTS 1-800-844-7871 they told me it was an easy fix. The part is $162.75. Im gonna try it.
Jun 27, 2008 | Philips 42PF9631D 42 in. Plasma Television
Philips 50PF9631D Plasma
First step....check power supply components.....research
similar Model & problem.................T.
Mar 22, 2008 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Philips 42PF7421D 32 in. LCD HDTV Logo
85 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
