Question about Samsung Eternity Cell Phone
Same I have the same problem, I haven't been able to turn my phone off for the past 3 days. When I press the end button though, and try to touch the screen it doesnt vibrate or move or anything.
My phone will not power up past the tracfone blue logo screen what should i do??
The below steps will resolve many small issues.1.Power off the phone.
2.Press and hold "Vol+", "Menu", and "Power" key until the phone goes to recovery mode.
3.Use "Vol+" and "Vol-" to move the cursor up and down.
4.Move cursor to "wipe data/factory reset", press "Back" key to select it.
5.Now move cursor down to "Yes - delete all user data" and press "Back" to select it.
6.The data will be erased.
7.The cursor will be on "reboot system now" at the end, so just press "Back" key to reboot the phone normally.
WARNING: All user data will be completely cleared; the phone will be in a factory reset status.So before you reset backup data first!! gud luck!!
Feb 23, 2013 | ZTE Cell Phones
I have the KitchenAid microwave oven model KBHC109. For the past few weeks the microwave has been beeping on its own. Sometimes it seems as though we are pressing buttons when we aren't and sometimes...
I am sorry but this is usually the signs your touchpad is going out and the part alone retails for a lil over $300.00. You know your needs better than anyone but in my home we would just keep dealing with it untill it drove us crazy, or quit being usable. Basically the buttons you press are worn and making contact without being pressed.
May 26, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
How can i formate htc touch viva
do these steps:
Remove the back cover and then pull out the stylus.
2. With the device turned on, press and hold the TALK/SEND and END buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the TALK/SEND and END buttons until you see this message on the screen:
This operation will delete all your personal data, and reset all settings to manufacturer default. Press Send to restore manufacturer default, or press other keys to cancel.
4. Release the TALK/SEND and END buttons, then press the TALK/SEND button to perform the hard reset, or press any other button to cancel the reset.
Jan 18, 2011 | HTC Touch Viva Cell Phone
My htc touch p3450 is stuck on "windows mobile" screen and will not go past that screen at all, once the phone is turned on. I have tried removing the battery, the same screen comes on when phone is...
the only solution here can be a firmware upgrade but that may damage your warranty doing yourself.. i can suggest try connecting it with your computer with the usb cable and leave it like that for a while. then let it drain out its battery.
if it does not work, keep it off for some hours maybe a day, still does not work then use your warranty to get it fixed.
Dec 14, 2009 | HTC Touch P3450 Smartphone
Hi, How do you change the time on a Panasonic KX-T7633 CORDED PHONE
There are several way that may adjust the Panasonic phone clock, please try the following suggestion method:
Method 1:
1) Press PROG soft button, follow by HOLD button.
2) LCD show direct the time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press END or HOLD to end the setting.
Method 2:
1) Press PROG soft button, follow by HOLD button, follow by # button.
2) LCD show time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press again # button to select between AM and PM mode.
4) Press again STORE to save the setting.
5) Press END or HOLD to end the setting.
Method 3:
1) Press PROG button, follow by key * * 1 2 3 4.
2) Press key 0 0 0 to display the day/time setting.
3) Press |> or SP-PHONE button if u wish to change the date.
4) Press |> or SP-PHONE button to change the time.
5) Press CLEAR or TRANSFER button to change current hour entry.
6) Press |> or FWD/DND button to change current minutes entry.
7) Press |> or FWD/DND button again and AUTO ANS button to change between AM or PM.
8) Press STORE to save the setting.
9) Press END or HOLD to end the setting.
Hope these help.
YBC (/\)
Oct 19, 2009 | Panasonic KX-T7633 Corded Phone
Clock on Phone
To set the time of the phone, there are several way that may help, please try the following suggestion method:
Method 1:
Method 2:
Method 3:
Hope these help.
YBC (/\)
Jun 24, 2009 | Panasonic KX-T7633 Corded Phone
I cannot set the clock And don't know how to get AM on the Radio?
To set the clock:
1) Turn the system off (standby)
2) Press the Play/Pause button
3) Turn the left knob until the proper day of the week appears.
4) Press the Play/Pause button
5) Repeat steps 3 and 4 for the hour, minute, AM/PM and clock is visible options.
To switch from FM to AM (and back again), press the Stop/Band button.
I had the same problem as you this past daylight savings time. I though I could figure it out on my own, but it was not at all easy to guess. I ended up going back to my file cabinet where I keep the users guides for everything I own to look it up.
May 17, 2009 | Audiovox 100-Watt 20-CD Music System -...
How to change time
Method 1:
Method 2:
Method 3:
Hope these help.
YBC (/\)
Nov 06, 2008 | Panasonic KX-T7633 Corded Phone
Touch pad is not working in HTC touch phone
I had a stubborn version of the dead touchscreen problem. Screen was dead this morning upon power-up and no combination of hard or soft resets made any difference. Removed screen protector (which had worked fine for a year) and cleaned out seam of screen too - still no change. Ten days past warranty expiration - figures!! Eventually I concluded there was nothing left to try but a ROM upgrade, even though I didn't expect that to help... IT DID!! I'm a Bell customer in Canada, so I downloaded the latest Bell ROM from here: http://www.htc.com/us/supportdownloadlist.aspx?p_id=70&act=sd&cat=all and did the install. Lo and behold - touchscreen working like new!!! My original version was factory 1.<xxxx> and newest was 3.<xxxx>. Fix cost me a day of surfing, but better than $400!!
Sep 17, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
UNCOMPLETED MDA UPDATE
this is a sw boot up screen. this is what the screen will look like with no sw on the device, so you guessed it....the download was unsuccessful and corrupted the firmware.....if you tried to reinstall the sw again, and it does not work, you might need a new phone....contact t-mobile to do that.....OR, you can try to do a master reset by pressing the sw keys.
to do that, turn off the phone, and press and hold the soft keys (buttons located beneath the touch screen that have the lines on them on top of the green call button and the red end call button).....while holding these down, press the power button for 3 seconds and release the power button.....all this time you are holding those soft keys down....the phone SHOULD turn on and go to a black screen with white writing.....at this time you can relase the two buttons......press the green button and reset. if this does not work.....my friend, you need another one......good luck!
Dec 16, 2007 | T-Mobile MDA
Samsung Eternity  Cell Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
