Question about NetGear WGR614 Wireless Router
Netgear Wireless light not working
I transferred my netgear from my own laptop with my own dsl connection straight from the wall, no modem, to my mom's desktop that also has a different login dsl, with a modem. I used this router on this computer before which is what puzzles me.
I plugged it in. My laptop recognized the router, but there was no internet connection. I went to the netgear set up and changed the login information. Still did not work. Then after tinkering some more I decided to do a hard reset. Now, the wireless light is out and I cannot connect to the set up page again. I've hooked up everything the correct way. The wireless light blinks when I do a hard reset and the check light is on, but once that light goes off, the wireless light does too. Please help..
  • devijann Sep 07, 2009
    Hi,thanks for helping. I tried to do everything you described. The two default gateways did not match, which is good. However, when I try to connect using the IP address 192.168.1.1 It does not give me a box for the user name and password. It simply does not connect in any way.
    I'm not sure what to do next. Or what else I should be checking.
  • devijann Sep 08, 2009
    Yup. I did exactly as you said and got absolutely nothing. No username/password box. Nothing. Just the cannot connect to server page.
  • 3,153 Answers
This sounds like a common conflict fault.
There are a few things you can do to help reliability
You should first make sure that the modem and router are individually
set up correctly.
Read the guide for router and modem first and if any of it may apply to you then try and do it.
Try the following procedure and write down anything you change so that if you need to go back you know what was changed.
Connect ONLY the MODEM to a pc by wire and nothing else
Go to the start menu and select RUN
In the box type "cmd"
Now in the black screen that has come up type "ipconfig /all"
Take note of the numbers that are in 4 groups e.g. 192.168.1.1
Also take note of the name in front of those numbers !
Write down any numbers where it says DNS too as they may be useful (you only need the ones with numbers not the ones with letters)
Now do the same thing with your modem
If that too has the same IP as your router in "default gateway" then you need to fix that issue as that is probably a part of your problems.
The fix for router modem conflict is to set the router to use a different IP range.
To do this only have the router connected (by wire) and open an internet explorer page (it will fail but that's ok)
In the address bar type the number you got for default gateway above for the router e.g. 192.168.1.1 and press ENTER
When it asks for the user name, give it the one you gave it when you set the router up or the default one from your manual
Also give it the password you gave it when you set it up or once again the default one from the manual.
You now need to look for a box that has the number you just used to get into the router.
It may just say IP address or Starting IP or something similar
That is the number you should change. I usually change the third block e.g. 192.168.2.1 as opposed to 192.168.1.1
You should also have some DNS numbers from the checks further up with the MODEM
You should find the DNS boxes and place those numbers in there. This will allow your computer quicker access to finding things on the internet
Now look for the save settings button and do so.
Reconnect the modem and router. The cable from the modem should go to the YELLOW socket on the router.
Power up the modem and WAIT until all the correct lights are on.
Then do the same with the router.
Now power up a pc and check that you can surf without problems
If not then the problem may lay elsewhere. Go back and re-check.
That should help you out
Posted on Sep 07, 2009
  • 1 more comment
  • Project NOMAD
    Project NOMAD Sep 07, 2009
    The IP for default gateway that you got when you only had the ROUTER hooked up is the address you need to get into the router.
    clear the address bard in an internet explorer window and type that in.
    Make sure you pu the full stops / periods in the correct places.
    That should get you to the router log in page.
  • Project NOMAD
    Most of what you need to know is also here
  • Project NOMAD
    Project NOMAD Sep 08, 2009
    Thsi is really odd as you verified the router address from the IPCONFIG /all command when you only had the router connected..
    I have never ever seen that method fail. (always a first time I guess)
    Ok nothing else connected to router and if you have wireless disable that for now
    only one computer connected to router and thats the one you should work from that computer connected only to a LAN port with a regular (not yellow crossover) cable.
    Then go from the top.
    let me know how you get on
    Master:
  • 441 Answers
There is a posibility that the router is bad. have you tried pressing the reset button for 30 seconds while its on and then plug it back it.
Can i use a wireless cable modem gateway (netgear) to make my current dsl modem connection wireless.
If your DSL-modem has one Ethernet port, then use an Ethernet cable to connect from that port to the WAN port on your NetGear router. Then, the router will provide both "wired" and "wireless" connections to your computers & devices.
Feb 13, 2011 | Computers & Internet
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    Netgear DG834G wireless router wth built-in modem doesn't connect
    Check if you have types all the configurations properly, namely Encapsulation / user name n password.
    Jun 21, 2010 | NetGear DG834G 54 Mbps 802.11g Wireless...
    How to connect netgear fs108 to cable modem
    leeb..... switches cannot be connected to the Cable modem.... because NAT will not be enabled in cable modem....so there wont be any DHCP server present in the cable modem....
    Nat will be enabled only in DSL modem like AT&T verizon etc....So DHCP server will be present inside DSL modem...that is the reason why switches can be connected only to the DSL modem....
    With NAT enabled modem, switch will work as a switch.... With NAT disabled modem, switch will work as a hub.... This is the difference....
    Any doubts further ? please clarify with me.... I am ready to help you....
    May 09, 2010 | NetGear FS108 8-Port Ethernet Switch
    Could not make router to work, Netgear modem adding router.
    i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
    Nov 10, 2009 | NetGear WGR614 Wireless Router
    I connected my new netgear as per the cd, and now it's not going into wireless mode, I still have to plug my ethernet into the computer to get networking... None of the DSL, Internet or Wireless lights...
    you have a modem /router setting page if you ring your isp give them your model number they will tell you how to check your router settings it will load up in internet explorer for you 2 veiw
    Aug 04, 2009 | NetGear DG834G Router
    Don't have home phone and looking to buy router/modem.
    Yes it requires a phone line for AT&T, or a cable modem, or a community wireless modem to hook up to the internet
    May 08, 2009 | NetGear DG834G Router
    Home Network Problem with Netgear MR814 and Netgear FS105
    Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
    Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
    NetGear WGR614 Wireless Router Logo
    434 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
