Question about SanDisk Sansa e200 MP3 Player
Sreen frozen-sort of
Ok when i turn on my sansmedi player it only goes as far as the sandick logoit doent turn on i only sa on that logo for ever!!! the blue scroller works but the screen doesnt. and when i plug it into the computr it oesnt conect so i cant do anythin like that!!!! plz help
  • 8,596 Answers
Re: sreen frozen-sort of
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
0 characters
3 Points
Kubik Edge 4gb 'frozen' screen on boot up.
Hey guys, I'm gonna cut to the chase, the little hole on the bottom right hand corner or the kubik edge get a sewing needle and press it 2 times! Hope it works guy xxx
Mar 08, 2010 | MP3 & Digital Media Players
Zune frozen with logo
Let the battery drain completely and then plug into computer. There was a leap year glitch from Microsoft and the fix is working today. Ours froze yesterday and it's OK this morning. This only fixes those that froze Dec. 31st.
Jan 01, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Sandick sansa e250 player
Download the Sansa Recovery Tool and run it.
Dec 18, 2008 | SanDisk Sansa e250 MP3 Player
My sreen is frozen and wont reset or turn off
my philips ipod does not charge does not on and cannot be reseted please help to solve it
Dec 01, 2008 | Philips GoGear SA3125/37 MP3 Player
Nano frozen
Did you try resetting it? (Turn the hold switch on, turn it off again, then hold down "Menu" and the center button at the same time for 6 seconds or so.)
Apr 21, 2008 | Apple iPod nano 3rd Generation
Ipod nano and ipod video 5th generation
First off, simply press the center and menu buttons at the same time to reset the iPod video. That is the common way to fix a frozen iPod.
In regards to the Nano, sounds like the scroll wheel is defective. We would recommend replacing the scroll wheel if a reset does not do the trick.
EverGreen Electronics
Feb 18, 2008 | Apple iPod MA446LL/A MP3 Player
Archos 605
try fully recharging the bettery
Jan 26, 2008 | Archos 605 WiFi Digital Media Player
My ilo MP3 player needs help
when i turn it on it stays on the ilo logo sreen and just blinks
Jan 23, 2008 | iLO (2 GB) MP3 Player
MP3 turns on but shuts off at the sandisk logo
The battery is dead. Leave it connected while the computer is on for about 3 hours and if the battery is still good that will charge it.
Jan 16, 2008 | SanDisk SDMX1-1024-E18 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
21 people viewed this question
Top SanDisk MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk MP3 and Digital Media Player Expert? Answer questions, earn points and help others
