Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Need to replace front left tire. Can't get it off
  • 389 Answers
If you have removed the hub cap (dust cover), the E-clip or cotter pin and washer from the outside of the wheel, it should just slide off the shaft but you may have a burr of some sort stopping it, try some sanding cloth, about 220 grit and smooth out the circumference of the shaft. If this still does not work, try pumping the wheel full of grease if it has a grease zerk on it. If the wheel turns freely when off the ground, you have something not clean or perfectly round stopping the outer race of the bearing
Posted on Sep 14, 2009
Noise from right front tire
jack up front left on level ground ,support and chock rear wheels and set park brake ---look and check the cv axle for leaks,tears or damage -put in neutral and watch axle should turn smoothly turn steering wheel to left and rotate tire again watching axle if their is binding or grinding or studder movement than axle is damaged and needs to be replaced
Apr 08, 2014 | 2005 Ford Freestar
Wearing outer edges of front and back left side on 2006 toyota tacoma
tires need to be balanced that will fix vibration. tire wear is a camber problem. get a four wheel alignment
Mar 24, 2013 | 2006 Toyota Tacoma PreRunner
2005 saturn vu pulls to left even after alignment
try swapping the front tires from side to side meaning left front on rt front and rt front on left front. if it pulls the other way this is known as a tire pull and you will have to replace tires to get rid of it. or rotate to rear sometimes rotating front to back will not eliminate because the other tires have same problem. if it does not go away it is an alignment problem and i would recommend having another shop look at it
Nov 03, 2011 | 2005 Saturn VUE
My dodge stratus is wobbling when i drive slow
There are three things that will cause this.
#1 bubble in a tire - check all tires and make sure that there are no bubbles. Also check that the tires are level all the way across, all the way around.
#2 Wheel bearings. If you can determine which area (front left, front right, back left, or back right) is the most affected, check that tire by jacking up each tire and grab the tire from each side. Wiggle it back and forth. Do this from top to bottom as well - if the tire (wheel) feels solid, you're good. If there is any play at all, you may need to have the wheel bearings replaced.
#3 - the front end alignment may need to be done - a shop can inspect the car and determine this, as well as determine the condition of your struts.
Please let me know if you need any further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
May 17, 2010 | 1995 Dodge Stratus
Had a flat tire on my GMC Sonoma. Changed the
wheel rim damaged ?? locating pin for wheel not lined up
May 16, 2010 | 1993 Nissan Altima
Left front vibrates at 120kph
check tire air pressure, both tire should have equal air pressure!
if pressure is OK, your car left front tire may have part that are worn out already and needs to be replaced. Ex: tie rod end or bearings.
Jun 18, 2009 | 1996 Mazda 626
I have a 2002 daewoo nubira cdx
Well without seeing it I don't know whats bent or not but your caster angle causes a pull since it is pulling right you need to add more caster to the right side or make the left side caster less.If it is the tires rotate left front to the right front and the right front to the left if it goes straight or pulls left its in the tires if it still goes right its in the alignment.
Jun 15, 2009 | 2002 Daewoo Nubira
Tires
Front and rear tires are different. Check your owners manual for the correct tire sizes.
Nov 20, 2008 | 1990 Suzuki RGV 250 L
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
1,251 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
