Home | Dell | Axim X30 Pocket PC | My dell axim x30 bac...
Dell Axim X30 Pocket PC
Problem for Dell Axim X30 Pocket PC
My dell axim x30 backup battery needs replacing.
By olivermoon on Sep 07, 2009
My dell axim x30 backup battery needs replacing. Is this something I can do myself?
Best Solution
posted on Sep 28, 2009
Very Helpful)
paranz
Rank: Guru
Rating: 86%, 37 votes
i believe if you are a bit of a hands on type of person you should be able to do this yourself.
but not without researching !
read this page, should tell you everything you need to know, from the perspective of someone who had to do the same changing of the CMOS battery.
http://www.mobilitysite.com/boards/x3-x3i-hardware-troubles/96005-x3-backup-battery-revealed.html
or read below:
quoted from: Tenc hi4U
DISCLAIMER : I take no responsibility for any damage you may cause to your Axim. The parts and proecedures described in this guide refelct my own experience with my own Backup Battery (BuB) in my girlfriend's Axim X3. Your mileage, parts, anbd experience may vary.
Tools needed for successful BuB replacement:
1. fine tip jeweler's screwdrivers (helpful if you slightly magnetize the tip)
2. Varta V20HR rechargeable NiMH battery
3. electrically conductive silver epoxy
4. strong needlenose pliers
5. electrical tape or heatshrink (razor blade or scissors to cut to shape)
But here it is step-by-step:
1. Pop little rubber caps from 4 corners of back covers. Disassemble Axim X3 with small jeweler's phillips head screqwdriver. Be sure to plave all parts in a plastic bag or other container (4 scres rear cover, 2 screws near port). Disconnect the ribbon connector towards the bottom of the PCB and the speaker wire (also on the lower portion of the PCB). Backup battery should be the green covered circular item under the pcb).
2. Locate backup battery, Cut away BuB cover, & CAREFULLY use strong needlenose pliers to grip and "roll" the leads off of BuB.Be very careful with the leads.
3. Mix dime sized batch of silver conductive epoxy (do NOT hot solder this battery, heat will lead to BuB damage and destroy lead connection to wire).
4. Apply epoxy to both sides (not too much)and afix respective leads to respective side (red lead goes to +, black lead goes to -). Secure connections with some type of clamp (I used a binder style paper clip, but a wooden close pin or something else that will hold the leads to the BuB while the epoxy cures (Mine took 24 hours to cure).
5. Recover new BuB with protective covering (I use electrical tape cut to the shape of the BuB. Covering WILL have to be form fitting to fit back into Axim BuB "slot".
6. Reassemble and charge Axim and charge.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Dell Axim X30 Pocket PC
Questions and Unsolved Problems for Dell Axim X30 Pocket PC
Do you recommend Dell Axim X30 Pocket PC?
Answer
Answer
I have vertical lines all over my screen.
Answer
The screen froze and now I can't even turn it on.
Answer
can the windows mobile new os setup for dell aximx30
Answer
how do i connect my dell axim x30 to my bt home hub so i can surf the internet? I am totally lost.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Axim X30 Pocket PC:
Top PDA Experts
Rank: Guru Guru
Solutions: 551
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
