Question about HP Photosmart 850 Digital Camera
Will not tturn on from battery or ac power - HP Photosmart 850 Digital Camera
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
1999 durango vent control switch will not let AC blow threw vents only defrost
Usually this is a problem with the blend doors under the dash. You either have a vac leak, a dead motor, or a faulty door.
The control opens and closes the doors to direct air thru the heater core and evaporator core along with directing air thru the vents.
When a problem occurs, the default position is the defrost vents to make sure the windshield remains clear.
You can do an internet search for "repair durango blend door" for more info.
Jul 29, 2012 | 1999 Dodge Durango
Won tturn on
Having received no response in over a month, I assume this is no longer a problem.
May 08, 2010 | Texas Instruments TI-83 Plus Calculator
CANNO TTURN POWER ON FOR THE deh-p8500MP
The ribbon cable under the radio face is broken
you can get one from pioneer parts or oemautosound.com
good luck
Mar 30, 2010 | Pioneer DEH-P8500MP CD Player
Sd card reader doesnt seem to work
I had the same problem as you describe on my Medion P6611 laptop (and on a previous Medion desktop that was, sadly, stolen from my apartment in early December. But I digress...) I called Medion tech support (which I have never found to be anything less than excellent), and the representative said:
The problem *may* be due to a buildup of static electricity, either on the card itself or in the card reader (I forget which it is). To fix it, do the following:
  • Tturn off your computer, remove the battery and unplug the AC power adapter from the laptop if it's also attached.
  • Press and hold the power button for 60 seconds or so. (This discharges the electricity from some internal component[s]--capacitors, perhaps?)
  • Replace the battery, reconnect the AC adapter (if you use it) and turn on the computer.
With any luck, that should fix your problem.
P.S. One slightly related tip: When you remove a card from the card reader, just remove it. There's no need to click on "Safely remove hardware" and select the card reader's drive letter. If you do, it won't recognize cards again until you reboot or turn the machine off and back on. Different problem, but same behavior.
Dec 22, 2008 | Medion md40298 Notebook
Philips Model # 30PW850H37A Won't turn on
Likely power supply failure. This could be on a separate board that can be removed and repaired or replaced. Look for a smaller board with larger components that look like transformers and accepts the incoming AC line.
Dec 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
Battery Cable Replacement help?
whell now you have two problems but try to jump start the car and let me know what happens, also did you replace the batterie cable with the conector at batterie? or just the cable, if it was just the cable remove the conector and clean it inside
Jun 21, 2008 | 1993 Chrysler Lebaron
HP Photosmart 850 Digital Camera Logo
109 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
